DTX2023Tremor's Money Pit Build and other miscellaneous topics
Last week, I was able to get the Leitner Bed Rack installed. I put the sides on when it was sunny and dry and then was planning to put the cross load bars on, and sure enough it was raining. Had to put them on in the rain as I needed to go somewhere and thought it unwise to do so without the structural integrity that the load bars provide to the rack.
Ended up adding a 1.5" riser as that raises the top of the load bar to the height of the cab roof.
I have a third load bar that I still need to install, might wait until I have a rooftop tent before I put It on.
Either way, happy with the fit and finish of the Leitner bed rack. Wife's main complaint is that she thinks it makes my truck look like I work in construction.
Your wife is correct. It's only in this circumstance would I ever say "Get rid of that rack!" 🤪
Working in construction is dumb.
It's hot, and knot the Paris Hilton good hot.
It was 106 F on the jobsite today
Follow me on the Tremor forum for more advice.
Kids, stay in skool or Learn a trade.
I thought I'd take a few minutes to go through my list of mods and gear for the truck. While the list was a lot longer than I expected, there are so many other things planned and gear to add. For example, I have some holes in my recovery gear kit that I need to fill (winch extension, snatch block, traction boards, etc.) and a bunch of other mods I want to do to the truck. I'm also slowly building out an overlanding set-up. So many things, so little money...
For those who are curious, there's 116 items on the list below.
Communications + Electrical:
  • RONIN FACTORY Truck Antenna (12 Inch) TuffLock
  • WeBoost Drive Reach Overland Cell Signal Booster
    • Currently removed. Considering whether or not to reinstall
  • NOCO GCP2 15A AC Port Plug
  • Makevivi Outdoor Waterproof On/Off Switch Extension Cord, Heavy Duty 125v/250v Black SJTW Cord
  • NOCO Genius GEN10X1: 1-Bank, 10A Onboard Battery Charger
  • Motohorn 3.0 (x2)
  • Midland Radio MXT575 MicroMobile®Two-Way Radio
    • MicroMobile® MXTA25 3dB Gain Ghost Antenna
    • MicroMobile® MXTA31 Microphone Extension Cable
    • Midland – MXTA24 Low Profile Antenna Cable with NMO Connector – CB Antenna Cable Extension – 6 Meters
    • MXTA55 Radio Bracket Mount – MXT575
  • Bulletpoint Mounting Solutions:
    • CB Radio Holder with 20MM ball
    • Matte Color Carbon Fiber Mounting Arms
    • AMPS Compatible 20mm Ball with Metal Mounting Plate
  • Bullet Proof Diesel Third Brake Light Antenna Mount - 2017-2025 Ford Super Duty
  • Midland - MXTA26 MicroMobile 1.5 inch Base Diameter 6DB Gain Max Power120W Boost Signal Output - 5/8 Wave - 32” Antenna
  • Z-Flash BCM 2300 Vehicle Flasher
  • Starlink mini
Exterior:
  • Line-X spray bedliner
  • Llumar PPF full truck
  • BFN Truck Shop paint matched tailgate applique panel
  • BFN Truck Shop paint matched tow mirror caps
  • Signville Tremor bedside decal
  • Bushwacker Black OE style fender flare kit
  • Tufskinz hood letter inserts – black/silver American flag
  • Front license plate relocation bracket
  • Super Duty 2023-2024 Black 2-Piece Set Front Wheel Well Liners
  • Tmat Truck Bed Organizer
  • TruXedo TruXSeal tailgate seal
  • Builtright Bedside Rack MOLLE Panel System
  • Builtright Bridge Panel for MOLLE Bedside Racks
Interior:
  • BuiltRight rear seat release
  • 4Knines floor hammock
  • Canvas back door covers
  • Tuffskinz door sill protection overlays front/rear doors
  • Llumar ceramic tint 15% front/30% rear
  • Llumar clear 80 windshield film
  • Stickerfab upfitter switch labels
  • BuiltRight rear seat back storage panel
  • BuiltRight dash mount
  • Ford Premium 4pc Locking Bed Cleat Kit
  • Open Trail Creations GearVault Organizer – Super Duty 2023+ Upper Glove Box
  • Desert Does It front multi-mount panels – Driver + passenger side
Lighting:
  • SwarfWorks Switch-Pros SP-9100 mount kit
  • BMC Lights Fog Pocket Kit – S2 Pro / Squadron Pro
  • Baja Designs XL80 + S1 mounted as ditch lights
  • SDHQ Built A-pillar light mount
  • Bad Ass Mounts 360 degree swivel mount
  • Baja Designs 7XL linkable sport bumper light kit
    • Planning to upgrade to the @Toxophilite “sun” light bar
  • Legmar Bumper light mounts
  • Rear facing: Baja Designs S2 Pro Flush Mount LED Light Pod, Work/Scene Pattern
  • Side facing: Baja Designs S2 Sport Flush Mount LED Light Pod, Work/Scene Pattern
Mechanical:
  • Stahlbus Engine Oil Drain Plug Valve
  • Transferflow 58 Gallon fuel tank
  • Borla Cat-back exhaust system S-Type
  • PPE Sterling 11.6”– 16 Bolt Heavy-Duty Cast-Aluminum Rear Differential Cover
  • PPE 2020-2024 Ford Super Duty 6.2L/7.3L 10R140 Heavy-Duty Cast Aluminum Transmission Pan
  • Powerstop Z36 Truck & Tow Upgrade Kit + Rotors
  • Wicked Trucks AC drain relocation kit
  • Open Trail Creations AirGuard Pro Filtered
Off-roading and Overlanding
  • Over Sand Tire Deflators
  • SKÖG Chuck Mates Premium Speed Clips for Automatic Tire Deflators
  • BougeRV Rocky 55QT dual zone 12V portable fridge
  • MORRflate TenSix PSI Pro 12v Portable Compressor - Gen2
  • MORRFlate Braided Mega Quad (4-6 Tires, Up To 200" Wheelbase)
  • Leitner Designs ACS forged tonneau Bed Rack
  • Leitner Designs ACS roof over cab platform rack
  • Leitner Designs Gear Pod Roof (x2)
  • Leitner Designs Star Link Mini mount
Recovery Gear
  • Rough Country hidden winch mount
  • Rough Country winch
  • Factor 55 Hitchlink 3.0
  • Rhino USA 1” x 30’ Kinetic Recovery Rope
  • Rhino USA 3" Ultimate Recovery Tow Strap 20’
  • Rhino USA 3/8” Syntheic Soft Shackle
  • Yankum Ropes 7/16” x 10” soft shackle
  • Yankum Ropes 7/16” x 20” soft shackle
  • Factor 55 Tree Saver Strap 3” x 8’ (x2)
  • Factor 55 rope retention pully
  • Factor 55 Ultahook winch hook
  • Factor 55 Ultrahook rope guard
  • Krazy Beaver Shovel
  • Gluetread Expedition Kit
  • Nilight Shackle Hitch Receiver 2” with 3/4" D Ring w/Trailer Pin
  • Autobots 3/4" Heavy Duty D Ring Clevis Shackle with 7/8" Pin & Isolator Washers (x2)
Road-side Assistance Gear
  • Hulkman Alpha100,4000A 118.4Wh Smart Jump Starter
  • QUINN 1/2 in. Drive Extendable Breaker Bar
  • TEKTON 1/2 Inch Drive Impact Lug Nut Socket Set (9-Piece) | SID92415
  • Suercup 1/2-Inch Click Torque Wrench- 40-320FT.LB/54.2-433.6Nm Dual-Direction Adjustable 72 Tooth Drive Click Torque Wrench
  • Ecoangel USB Rechargeable LED Road Flares Emergency Lights-Roadside Warning Car Safety Beacon Flashing Disc Flare Kit with Magnetic Base
  • Safemate 3 Pack Warning Triangle DOT Approved, Foldable Emergency Safety Reflective Triangles
  • Black Jack TIRE Repair Truck Repair Kit w/ 35 Rep
  • Milwaukee M18 Compressor
  • Turokacase Air Compressor Hard Storage Case for Milwaukee M18 Inflator 2848-20
Security + Safety:
  • IGLA
  • Drone X1 max LTE
  • Blackvue DR970x 2 channel dashcam
  • Mounted on Blendmount rearview mirror mount
  • Talons Garage skid plate / catalytic coverter shield
  • Coated both sides with Line-X
  • Plate Keeper security screws
  • Retrax Powertrax Pro XR tonneau cover
  • Geno’s Garage OBD-II port lock/tune saver
  • Omaha Bravo Designs Hood Guard
  • Omaha Bravo Designs Tail Guard
  • Omaha Bravo Designs Cover Guard
  • Omaha Bravo Designs Light Guard
  • Element E100 Fire Extinguisher
  • Amerex B410T 2.5 lb. Purple K Dry Chemical Fire Extinguisher
  • Amerex B500, 5 lb ABC Dry Chemical Fire (x2)
  • Prepared Hero Fire Blanket
Suspension / Weels:
  • Carli Front Ford Super Duty 2.5" Leveling Coils
  • Carli Signature Series Custom Tuned Shocks
  • Carli 17+ Ford Super Duty Front Stainless Braided Brake Lines
  • Caster Correction Shims
  • Carli Leveling Front Bump Stop Drops
  • Carli Adjustable Track bar
  • Factory Load Scale / Headlight Sensor Lift Brackets (Front/Rear)
  • Carli Torsion Sway Bar
  • Carli High Mount Steering Stabilizer
  • Carli Low-Mount Steering Stabilizer and Front Diff guard
  • KMC Mesa Satin Black Wheels with Gloss Black Lip
  • Gorilla Spline Lug Kit
  • Centramatic Wheel Balancers
  • TOYO Open Country AT3’s 37/12.50/18
Towing
  • Carli Suspension 17+ Ford Super Duty Trophy Hitch
  • B&W Trailer Hitches Tow & Stow Adjustable Trailer Hitch Ball Mount - Fits 3" Receiver, Dual Ball
  • InfiniteRule hitch lock set
  • Factor 55 Locking Hitch Pin
Miscellaneous:
  • Hail Protector
  • Tire Lift Caddy
  • Motohorn 3.0 (x2)
  • Starlink mini
Exterior:
Interior:
Lighting:
Mechanical:
Recovery Gear
Security + Safety:
  • IGLA
  • Drone X1 max LTE
Suspension / Weels:
Towing
Miscellaneous:
  • Hail Protector
  • Tire Lift Caddy
The hail protector is my favorite 🤪.
I thought I'd take a few minutes to go through my list of mods and gear for the truck...
Holy smokes.
I'm a one-man show, and I'm slow about it.
It'd take me another lifetime to accomplish what you have done to your truck. This is just one of the things about what I read of yours that tells me how hard you work when you're not at work! You have my respect, sir.
Another thing, and the reason for quoting you, are your Recovery Gear chapter and your Roadside Assistance gear: I have some of this stuff; I have more recovery gear than I do Roadside Assist gear, but, it is such a pleasure to read of another Ford owner who THINKS AHEAD. Hahaha!
I believe we may get along quite well, if only I weren't such a slacker.
:ROFLMAO:
Holy smokes.
:ROFLMAO:
Thanks! We'll definitely get into some fun shenanigans in a few weeks.
I keep the roadside assistance gear full-time in the truck and it is typically below the Retrax canister. The recovery gear gets added for off-road trips as I don't expect to need it for road trips or around town. On top of all this, I still keep the RV coverage (despite not having an RV) with AAA as it comes with 200 miles of towing per issue. Figure if the truck breaks down, I'm likely within 200 miles of a Ford Dealership in most circumstances. Funny thing is that I have been a AAA member 4 years longer than I've been alive :ROFLMAO: My mom had a membership and added me on it when I was 16. When I turned 18, they moved me to my own membership and I kept her sign-up date.
@Apples .... so here's the pending list (95% of which needs to be purchased), a few things I have and it's on the pending install list. I think that's another 63 items to buy and install... There's a few things that I haven't included like tire chains (unsure if I'll buy them), and I'm planning on turning two Milwaukee packouts into custom first aid kits I can mount to the bedside panels of the truck (on regular first aid, the other for more severe injuries).
I think my truck's name - Money Pit - is fitting. There's nothing wrong with the truck, yet I keep spending lots of money on it.
Pro tip: Never come to me for financial planning advice. Want ideas on how to spend your money? I'm your guy.
Audio
  • Front & Rear Door Speakers: Kicker 51KSC6504 — KS-Series 6½" 2-way coaxial — 2 pairs
  • Dash Corner Speakers: JL Audio CF-350mt — 3½" midrange/tweeter
  • Dash Center Speaker: Dayton Audio PS95-8 — 3½" full-range, 8-ohm
  • Subwoofer: JL Audio 10TW3-D4 — 10" shallow-mount, dual 4-ohm
  • MTI Acoustics behind-seat enclosure — single 10", driver side, ported + sound-treated
  • Factory sub block-off plate — oval, B&O Unleashed
  • Subwoofer Amp:
    • JL Audio RD500/1 — Class-D mono, ~500W @ 2Ω
    • Kicker KeyLOC — DSP signal interface
Exterior
  • Dirtcom TrailGuard – Stage 3
  • BrokenRock Hitch Roller
  • Stapll Fender Racks
  • Foutz Motorsports 2023+ Super Duty Rear Differential Skid Plate, Sterling 11.6 Rear Axle
  • Foutz Motorsports 2017-2025 F-250 Super Duty Rear Shock Skid Kit
House Electrical System
  • Battery Bank
    • Epoch — 12V 300Ah Essential Heated Bluetooth LiFePO4 battery (×2)
    • Blue Sea Systems — 5191 Class T fuse holder (×2)
    • Blue Sea Systems — 5135 300A Class T fuse (×2 + 1 spare)
    • Blue Sea Systems — copper 2-stud negative busbar
  • Inverter & AC Distribution
    • Samlex — NTX-3000-12 3000W pure sine wave inverter, NEMA L5-30R outlet + built-in GFCI
    • Samlex — NTX-RC LCD remote control (×1, included)
    • Leviton — 20A GFCI duplex receptacle
    • Hubbell — weatherproof in-use box + cover
    • Southwire — 10 AWG SOOW 3-conductor cord, 20 ft (NEMA L5-30P plug on inverter end)
  • Alternator (DC-DC) Charging
    • Victron Energy — Orion XS 12/12-50A DC-DC charger (×2, paralleled for 100A)
    • Ablemail — AMC-12-S Battery Master, starter trickle-maintain
    • Victron Energy — 150A MEGA fuse holder + fuse
  • Solar Charging
    • Lensun — 200W flexible panel, RTT-mounted (×2)
    • Lensun — 98W custom F-350 hood panel
    • Victron Energy — SmartSolar MPPT 100/50, RTT
    • Victron Energy — SmartSolar MPPT 75/15, hood
    • MC4 — Y-branch parallel adapter + connector kit (×1 set)
  • System Integration & Distribution
    • Victron Energy — Cerbo GX MK2 integration hub
    • Victron Energy — SmartShunt 500A battery monitor
    • Victron Energy — Lynx Power In main busbar
    • Victron Energy — Lynx Distributor fused branch distribution (×1–2)
    • Blue Sea Systems — 5026 ST 12-circuit blade fuse block
    • Blue Sea Systems — 400A Class T holder + fuse, inverter feed
    • Victron Energy — MEGA fuses, 100/80/80/60/50/20A (per fuse map)
  • Lighting Control
    • sPOD — BantamX Touchscreen kit, 8 channels + touchscreen + harness
    • sPOD — BantamX expansion source module, +8 channels
    • sPOD — HD 6-switch panel, tailgate control
  • Under-seat battery tray:
    • custom U-shaped 1/4" 5052-H32 aluminum,
    • 3/8" 60A EPDM underlayment
  • MTI amp rack behind rear seat (replacing BuiltRight MOLLE panel)
  • SDHQ Billet Battery Terminal Kit
Lighting
  • Upgrade XL Linkable Sport to XL80 Linkable lightbar
  • Baja Designs S2 Pros (x6) – 2 on each side of bed rack for camp lights
  • Baja Designs S1 (x2) – one on each front corner of the bed rack for near field ditch lighting
  • Baja Designs S2 Pros (x2) – installed on Dirtcom TrailGuard
Overlanding Gear
  • The Bush Company TX27 RTT
  • Bush Company 270 XT MAX Awning Mk2
  • OPENROAD 10-gal pressurized tanks (x2)
  • Propex PS2000 suitcase heater
  • Leitner GearPOD Dual + single
  • GP Propane Tank Mount (11 lb)
    • Mounted on a Leitner Universal Mounting Plate
  • Anderson STAX levelers (×2)
  • Hardcore Hammers Camp Companion Axe
Performance / Mechanical
  • Stainless Works 1-7/8" long-tube headers w/ integrated high-flow cats (FT220188HCAT)
    • DEI Titanium 2" exhaust wrap + HT Silicone Coating
  • 5 Star Tuning custom calibration, HP Tuners (3 tune files)
  • Ignition refresh:
    • Motorcraft SP-589 plugs
    • MSD direct replacement coil packs for 7.3L Godzilla
    • Ton's Performance 10mm Ceramic Spark Plug Wire Set with titanium sleeve, 11" leads, for 2020+ Ford 7.3L Godzilla
  • Whipple supercharger (probably the very final mod, if I ever get to it)
Recovery Gear
  • MAXTRAX MKII pair
  • AGM Heavy Duty Scissor Jack (7,000 lb, drill-operated)
    • This will replace the Badlands rolling jack
  • Winch line extension
  • Snatch block
Sound Deadening
  • Stage 1 — engine bay Thermo-Tec heat barrier
  • Stages 2–4 — cab rear, cab front, roof (ResoNix CLD/Barrier, CCF, MLV, Thinsulate, Rockwool)
  • Stage 5 — doors + audio: MTI Acoustics Stage 2 SuperCrew Bundle
Suspension
  • Carli 05-26 FORD F350/350 4X4 FABRICATED LEAF SPRING SHACKLE
  • Carli 17-26 FORD F250/350 4X4 FULL PROGRESSIVE LEAF SPRING KIT – 3″ LIFT
  • Carli 05-26 FORD F250/350 4X4 FORD PINION SHIM KIT, 2 DEGREE
  • Carli 23-26 FORD F250/350 4X4 FABRICATED RADIUS ARMS – 3.5″ LIFT
  • Carli 23-26 FORD F250/350 4X4 RADIUS ARM DROP BRACKETS – 3.5″ LIFT
  • Carli 23-26 FORD F250 TREMOR, HIGH CAP TOW & F350 SRW 4X4 LONG TRAVEL AIRBAGS
  • Carli Pathfinder shock system
Miscellaneous
  • Grove Fabworks 1.5" Y-strap spare-tire tie-down
  • Surface Shield rust protectant
  • Wicked MFG Auto Level Headlight Scale Provisions Brackets
Good God, man. :oops:
We are not worthy. :ROFLMAO:
I have this as per @Optimus ' recommendation... but the hex head cap screws (the larger half of a bolt assembly) are threaded well into where they pass through the shock lower mount eye bushing itself!
I have been meaning to ask a machinist if this is acceptable. I'd think a full diameter, non-threaded screw shank should be the only fastener structure to pass through the shock mount.
I've been wanting to get these little steel boats mounted, but keep forgetting to ask the right persons.
As for the rest of your kit, I though I think of "everything"... newp. I am just a piker.
I may tow behind to Moab my little "squaredrop" rather than my new-to-me, used toyhauler. In the squaredrop is a scrach-built solar electric system reduced in scale to what you're planning, but I think you might geek on it just the same.
Oh boy, neat trucks, some trails and some "Oooh, wait. Look at this, here..." goin' on!
Might hold off until you see @MDethloff shock skids :cool:
Thanks, OB.
I already own these. It's the bolt threaded length that bothers me is all.
Naturally, I remain curious about the Dethloff pieces. Thanks!
Getting some things dialed-in and added-on ahead of the upcoming trip to Moab.
Stopped by @Renegade Customs Rockwall to have Will and team install the Dirtcom Trail Guard. The trail guard is engineered so that is sits pretty flush against the front bumper. Taking advise from @Tugboat, the Trail Guard was shimmed to create a small gap between the guard and the bumper. The main issue was the outer corners of the trail guard rest on the bumper, which made me concerned that vibrations between the two would cause paint damage to the bumper. Addressing this does require sourcing longer carriage bolts as the supplied bolts are not long enough to allow for any shimming.
Installed in the Trail Guard are 2 amber Baja Designs S2 Pros, angled down about 10 - 15 degrees to not only help illuminate the ground in front of the truck, but to also avoid blinding oncoming traffic (since these are not the SAE lights). Overall, really happy with the fit and finish of the trail guard and hopefully will not need it, but glad to have the added protection up front.
The next thing will be to find a fairing mounted license plate holder. I've got one on order, and am hoping that it will clear the bumper so I don't have to install the front license plate on the holes provided by Dirtcom on the Trail Guard.
Glad the shims worked for you it seems with the winch that extra 1/4 inch was needed as you noted to have clearance between trail guard and bumper
