I know a bunch of people run without front license plates in states that require them, but I figure better safe than sorry. Especially, since I'll have an out of state plate in many areas where they're required and don't want to make myself an easy target for citations.
Putting on the Trail Guard, meant that the alternative OEM license plate holder won't work for me anymore. So, the search for a new license plate holder began. Before the alternative OEM mount was available, I tried a few other options, that while made, didn't work for one reason or another. Mostly, they cause the front parking sensors to alarm due to the proximity of the mount to the sensor.
I decided the best solution is a fairlead mounted license plate holder. The vast majority of the ones on the market are for externally mounted winches, and difficult to find an example of one mounted on a hidden winch mount in a Super Duty.
After examining a bunch of the designs out there, one concern kept coming up - would the mount clear the bumper or be obstructed by the bumper in some way (especially the flip up designs).
I ultimately landed on the one from Rock Hard 4x4:
Hawse Fairlead License Plate Mount w/ Cable Lanyard [RH-4004]
I imagine that having to remove two screws to get the plate out of the way, and have it hanging by a cable, would be something some might not like. As I considered it, I realized that I have never used my winch in the 2 years it's been installed, so the odd instance where I would need to remove the plate would be fine for me.
The mount is well made. I did need to modify the bracket as the cutouts for the tabs that go behind the fairlead and around the bolts was too shallow for the bracket to fit into the bumper. I ended up needing to extend the channel on each side about an inch or so and the bracket fit perfectly.
View attachment 267618View attachment 267619
