DTX2023Tremor's Money Pit Build and other miscellaneous topics
Yeah, that is exactly the crux of the issue. Found a well rated flushing toilet and a 3 room pop-up tent that has a room for the toilet, shower, and a changing room. Will also add a water heater and a tent heater (maybe a portable A/C for those warmer evenings).
Planning to travel with 20gal of water, but the switch to military showers will take some practice. Figure short 2 - 3 day trips (where I can get water easier in case consumption exceeds capacity) to start to get her used to everything before attempting longer ones.
Worst case, things longer than a couple of days may just be trips with the guys.
Fundamentally speaking, truck bed campers like mine are all the same. If you want to spend a night or two testing one out, i'm not too far away. 🤙
The good weather has given me some time to get some things done on the truck.
First up, finally got around to installing the BuiltRight bedside panels. I added 3 additional clamps for my Retrax Pro MX tonneau cover (to provide greater support for a future bed rack and rooftop tent), which require some additional trimming of the panels to make them fit.
I hit all of the places I cut with a shot of SEYMOUR 620-1433 Industrial MRO High Solids Spray Paint, Flat Black. Hoping this will help prevent rusting.
Happy with how this turned out.
Now I've gotta figure out what I'm going to mount on each side. The ProPower and 5th wheel hookups on each side really take away a lot of great storage space.
Today I also took care of service ahead of some upcoming road trips. A few miles shy of 50K miles, so did an oil change and tire rotation. Also changed out the windshield wipers as the PIAAs have started skipping on the window. Not sure why I go through windshield wipers so fast, but could be parked in full sun+reflective windshield screen giving the wipers 2x the sun than normal. Plan to give the truck a "quick" wash in the morning and give the windshield a good cleaning and refresh the RainX on it.
Despite a few carwashes and hosing everything i could get to that isn't the interior of the truck, I am still finding dust in crevasses from Sedona and Big Bend last year. In an attempt to minimize the dust intrusion, I sealed all of the bed seams with a black silicon caulk and also installed the truxedo bed seal. With the added @OmahaBravo Designs security mods installed, I didn't want to uninstall everything so the truxedo bed seal stops short about 2 - 3 inches from the top of the tailgate.
The truxedo bed seal has a thin section and then a thicker ribbed section. The install instructions have you put the thin section towards the left on the driver side and right on the passenger side. This had me removing the @OmahaBravo Designs light guard to put this behind it. Getting the light guard back in pace was a bit challenging as I had to compress the seal significantly (using a 2x4 with my full body weight applied to it) and have it snap in place behind the light, which results in the light guard putting a fair amount of pressure on tail lights. Hoping it won't be an issue, but time will tell if it causes damage to the tail lights. I did find that the power close on the tail gate doesn't do so well with the seal adding resistance, so it will require a bit of force to "slam" the tailgate shut for it to fully latch.
It will be interesting to see how much dust gets into the bed with these changes. I'm not sure how well the Retrax Pro XR keeps dust out, but with so much dust coming in through the tailgate and bed seams, it was difficult to tell what dust was a result of the tonneau versus other entry points.
Maybe try one of these!? 🤪
Where do you think you're going, Mr!? 😁
Been slowly working on getting some smaller things done on the truck the last few days now that the weather has been nice. Got all of my fire extinguishers installed: two 5lb ABCs in the truck, Element 100 under the driver seat and a a 2.5lb Purple K under the front passenger seat.
Also slowly working out how I want to use the BuiltRight bedside panels. Having the 5th wheel prep on one side of the bed and the 2kW inverter plug on the other side hurts the amount of useable space. Got the Crazy Beaver shovel mounted and plan to put a Hardcore Hammer above the shovel. Other side, if I can make it work, will hold a first aid kit that I'll build using a couple Milwaukee packouts.
Finally got around to knocking a to-do item off my list... getting the T-Mat to cover the full bottom of the bed. Even using those adjustable contour guides, made getting the curves of the bed easier, but still had to make adjustments along the way to get each piece to fit.
I'm also slowly working on an overlanding build out, so started with adding a Leitner roof rack on the truck.
Installing the roof rack isn't complicated, but it is a pain to get screws in and torqued to spec.
I had to remove the Savage UTV Starlink mini mount to get the roof rack on, so added the Leitner Starlink mount. The Starlink mount sits between the two rooftop gear pods, at the rear of the rack. Hopefully the boxes won't have a major impact on the signal. If it does, I'll have to move it up to the front of the rack.
The down side of removing the Savage UTV mount is that it has a gasket on both sides, and I had the power cord for the Starlink going between the Savage UTV and the Bulletproof Diesel antenna mount, so the gaskets on both mounts wrapped the cable, creating a pretty good seal (no water intrusion over a year on the truck). With the power cord now coming out between the antenna amount and the cab, I didn't seem like the single gasket would create a good enough seal. I explored the idea of adding a bead of silicon caulk around the perimeter of the antenna mount, but it seems that if I tried to remove it in the future, the caulk could remove the clearcoat and paint.
After doing a bit of research, I landed on using 3M Window-Weld Round Ribbon Sealer. This product is typically used to seal windshields, so figure it would work to create a gasket. The nice thing is that it is easy to mold so I thinned it out from the 3/8" thickness to about 1/8" and created a gasket on the back of the antenna mount. Once the antenna mount was installed back on the cab, I took some additional pieces of sealant and added it to close any gaps and create a smooth transition from the antenna mount and the cab as well as surrounding the cord for the Starlink. I'm cautiously optimistic that this will work to keep any water out of the cab.
Oh boy, going down the overlanding rabbit hole! Did your wife approve of this new rack!? 🤪
Yes! Rack was approved on "her truck" ;)
One of the main reasons we had looked at 1-ton trucks a few years ago was we were thinking of getting a 5th wheel. While there are many places you can go with a trailer, there are many more that they are not able to go or can only go with a much smaller off-road trailer. I still want to be able to use the bed of the truck for hauling when needed, so a slide-in camper didn't make sense for us either.
Running the numbers between a full overland set-up versus the 5th wheel we had out eyes on, it will save us about $65K* as well as avoid storage fees and other ongoing expenses that come with owning and maintaining a trailer.
*Savings were reduced significantly thanks to @FuelTankReInforcedSkidPlt who showed me the difference between many of the top brands for roof-top tents and awnings versus those made by The Bush Company. The Bush Company gear is 1.5 to 2x the cost of everyone else, but wow, the quality of their products are better than anything else I saw at the Overland Expo last month. They literally had someone doing pullups on the awning arms (that do not have/require support legs). I fortunately had good presence of mind at the Expo to not take advantage of their show discount as the wife would not have approved that purchase. If I hadn't, I'd probably be living in my tent. 😝
I'm not planning to keep the boxes on the roof rack full-time, only adding them when going off-roading as that's were I plan to store my recovery gear in one of the pods and haven't figured out what I will put in the other. Plus of not having them on full-time is that I only lose 0.5 mpg vs. the 1 - 1.5 mpg I've read others report as losing due to the added wind resistance.
I do have to say, that at highway speeds, I can definitely hear the roof rack and the wind buffering against it. It's almost like when you have just one window cracked. Figure with the stereo up, it will drown it out until I can tackle the interior sound deadening project planned for some point in the future.
Do you hear the rack when it is empty or just when you have the boxes up there?
I haven't driven with it with the boxes on. There was a lot of wind noise coming from the rack on the highway this morning.
I ended up getting the Leitner roof rack because I'm also installing the Leitner bed rack and the entire ecosystem worked for what I was looking for. What I particularly like about the Leitner Roof Pods is that they open on the side, versus other brands, the rooftop boxes open from the top. Given how tall these trucks are, It seemed like trying to get into boxes with a side opening would be much easier than a top opening.
That said, the Sherpa roof rack was a very, very close contender. The wind faring options from Sherpa are better designed and are well thought out. They have a regular full faring for those who do not have the marker lights, a half faring for those who want to install a light bar on the roof rack, and a full faring with cut outs for the marker lights (well at least the three in the middle). I definitely recommend the Sherpa racks for anyone looking at getting one.
Beds, racks and boxes; loving this thread more and more.
One other adjustment I made while doing all of this was to uninstall the weBoost as the antenna was installed in the Retrax t-slot and would get in the way of the bed rack. Not sure I'll reinstall it as I'm not sure I ever really got any benefit from the weBoost when it was installed. I could never tell if the weBoost was doing anything as (if I understand correctly) the antenna meter on phone only shows the strength of the signal from the cell tower, not the strength of the signal I'm transmitting to the cell tower.
For those who are unfamiliar with weBoost, it has an antenna inside the vehicle that picks-up your cell signal and transmits it using the large antenna mounted outside the vehicle, which can significantly increase your useable 2-way range of your cell phone. These however do not work if there's no signal from a cell tower and your phone needs to ideally be 3 feet from the interior antenna.
The interior antenna was installed at the top of my b-pillar, which would work well if I held my phone in my hands when talking, but my phone is in the center console compartment, connected for Android Auto and charging, and all calls are taken hands free. So that's a bit further than 3' from the interior antenna for me and even farther for my wife when she's in the front seat. If I end up deciding to reinstall it, I'll put the interior antenna on the middle of the dash on the BuiltRight panel which would keep phones in the front seat generally within the ideal 3-foot range.
With having the Starlink installed, it makes the weBoost a bit redundant, if not obsolete as I rely on Starlink wherever there isn't a cell signal.
I had the Webooat intererior attenna in the center of the console on my Ram and worked good if I had the phone in the nearby cup holder.
I haven’t bothered on the Ford as we tend to run the starlink instead.
When I had my Weboost, I had the interior antenna mounted just below the center console lid, I ran the cable through the bottom the center console (drilled a small 1/4" hole). It worked really well in that position for the driver and passenger and it was completely out of the way.
Like you, I now have a Starlink, so I removed the Weboost completely. I kind of wish I would have kept it, especially now that Starlink has removed the ability to use internet while driving. :mad:
They only removed the ability to use the standby mode while driving. Just last week I was using my starlink while moving.
IMO, starlink makes weboost a relic.
True about standby, but it was really nice when you could use it while moving in standby mode. Of course they changed this after I removed my Weboost.
Yeah, seems that may have been the key issue with my weBoost install that the transmitter was not in the right place for it to really benefit me.
I'm debating on reinstalling it as I have to figure out where I want to put the antenna if I do put it back on. Roof top rack or swapping out to the dual antenna 3rd brake light mount from Bulletproof Diesel are options I'm considering....
The cell signal output level of the phone is controlled by the cell tower in all cases. The tower determines on how much the phone will be able to transmit via a digital handshake. The WeBoost is as you say, an amplifier for the cell tower to help find it. The phone is merely responding to the demands of the tower. If the tower cannot "see" the phone, no connection is established, even though the tower has all the power in the world to reach your phone. ("Bars" are not a good indicator of signal.)
The WeBoost works best if the phone is literally next to the transmitter/receiver internal antenna and at least 5' away from the outside antenna. I mounted a phone holder on the dash that holds the pickup antenna with the Built Right panel and the phone sits directly in front of the pickup. I use Android Auto for talking, etc. and use the phone menu as my auto screen. I would imagine that the passenger would also have some benefit even though not as close to the pickup, it's closer to the passenger side than the driver's side.
I still use the WeBoost because it doesn't cost anything to operate (though fits in the money pit category. :sneaky:) It works really well in forested canyons, which is where I usually am and doesn't rely on a satellite view. (Tested this on several occasions) Even so, it can still lose connection if too far from the transmitting tower. For now, the WeBoost works for me; Starlink is best (probably only choice) if you are in remote areas where there are no cell signals. If I were to install the Starlink, I would still keep the WeBoost and use the Starlink in the rare instance the WeBoost can't find a signal.
