Today got another mod checked off the list - getting Starlink installed. One of the other items I wanted to accomplish with this mod was to relocate my GMRS antenna.
At last year's Big Bend meet-up, I found that the antenna being mounted on my ditch light resulted in a significant loss in range.
@speeddev who was right behind me would have to relay nearly every communication from me to the rest of the group so those in the back could know what was going on. Hopefully a new location for the antenna will improve signal range for the next Big Bend meet-up.
I decided to go with a Starlink mini mounted on a
Sage UTV Ford-150, 250-550 - Starlink Mini Mount. I added the optional hail cover, not really because I want hail protection (not that it would hurt), but because it is black and would make the dish blend in ever so slightly better. While Sage redesigned the mount to accommodate the single antenna Bullet Proof Diesel mount, they didn't adjust the hail cover, so it had to be notched to accommodate the GMRS antenna.
Between the Sage mount and the third breaklight I added the
Bullet Proof Diesel Third Brake Light Antenna Mount - 2017-2025 Ford Super Duty. I don't plan on adding any additional wireless communications, so went with the single antenna mount. I considered the ones with the added light, but didn't see a need for me to add them as I already have sufficient light on the bed between the OEM lights and the one included with the Retrax cover. I figure the GMRS antenna moving to the roof would give it a better plane from which to broadcast off of that it didn't get being mounted to the ditch light mount, floating in the air.
To power the Starlink, I used a
12V to 48V DC Step UP Converter for Starlink,ELFCULB 6A 288W Power Supply Voltage Booster Converter Regulartor to step up the power from the battery to the dish. The transformer was mounted to the BuiltRite panel behind my passenger rear seat.
To connect a Starlink power cable to the transformer, these
10A DC-099 DC Power Jack Cord Socket 5.5x2.1MM Threaded Female Mount Connector Adapters worked great.
Used
9.8' / 3M cable. The cable was routed so it is between the Bullet Proof Diesel mount and the Sage UTV mount. Both mounts have a foam gasket that helps to prevent water intrusion and nicely surrounded the cable.
A bead of
5200 Marine Sealant - Fast Cure, High Bond Strength, UV Resistant Underwater Sealant help to further prevent water intrusion.
Overall, really happy with how this turned out.
