Featured
- #521
I suspect the door seals are going to become more noticeable as you complete the work above. Look on YouTube for guys that added material to the door seals if they stand out.
Thanks for the tip. I recall @BroncOh addressing door seals by threading tubing inside his to help it create a better seal. I might try that route first before going with other solutions.I suspect the door seals are going to become more noticeable as you complete the work above. Look on YouTube for guys that added material to the door seals if they stand out.
please tell us that you pinned the crank pulley.Wanted to share an update on my build now that the Whipple is in, plus a few things I learned along the way that might save someone else some time.
What's installed:
Huge thanks to Will and his team @Renegade Customs Rockwall for the install and the patience.
- Whipple Gen 6 3.0L Stage 2 (WK-2341-STG2-30), stock pulley
- Stainless Works 1-7/8" long tubes (FT220188HCAT)
- GESi high-flow cats, SKU SWGESI400 (EPA N-GBL-4363-0926). Not listed on the Stainless Works site — ask for it by name. It's the 400-cell, EPA-compliant cat they recommend for forced-induction builds.
- Stainless Works Legend cat-back
- NGK 95822 (ILTR7N8) plugs gapped to .031" — on Whipple's approved list
- Ton's plug wires
- OEM coils (MSD doesn't make a 3-wire coil for this engine)
- UPR catch can with clean side separator
Lessons learned:
1. If your PCM has been reflashed, tell Whipple up front. My truck had an engine replacement, and the dealer flashed every module to Ford's latest software. The Whipple calibration wouldn't load because the truck wasn't configured like a 2023 anymore. Whipple turned around a patch quickly, but it's worth flagging when you order.
2. Brake lights flashing on throttle release. After install, the brake lights flashed when revving in Park and quickly letting off the throttle. We chased the boost-into-the-booster theory, and the tests ruled it out. Best explanation so far is newer Ford software behavior — at least one 2024 owner reported the exact same flash on a stock truck. If anyone with a stock 2024+ can confirm, I'd appreciate it.
3. The 23+ manual still shows the old brake booster routing. The current public manual (R3, Jan 2025) leaves the check valve in the stock location. Whipple has been emailing corrected routing to 23+ customers — ask for it before you start.
4. Catch can on a Whippled 7.3. UPR's instructions assume a stock intake. With the Whipple, the PCV no longer goes to the intake manifold — it goes to the RH top port on the supercharger inlet. So the catch can sits between the RH valve cover and that port, replacing the Whipple PCV hose. The CSS goes on the LH valve cover as normal. I purchased longer hoses to allow for them to route behind the Whipple rather than over it as the provided hoses would require. One of the provided hoses was too short for this anyways, so getting two new hoses made at a shop nearby was the best solution.
First impressions: The truck is quick. Big difference. Oddly, it seems quieter at idle from the front and driver's door than it was with the Borla S-Type I had before, but standing near the tailpipes during a rev is genuinely painful. The whine is noticeable inside and out but not annoying so far. The exhaust note is a different pitch than the Borla and while seemingly tamer at idle, is definitely more aggressive sounding under acceleration (definitely going to create more "smiles per gallon", but more tears at the pump).
Next up: Getting all of the lights and other electronics reconnected that had to be disconnected so the cab could be pulled for the engine swap, and loading the 5 Star custom tune via MPVI4 in the next few days. Looking forward to the long highway run to College Station for the meet-up on December 5 to see how the Legend does for drone at 70–80.
Yes, crank was pinned. I think Whipple include this as part of the kit now.please tell us that you pinned the crank pulley.
