Wow! I can't believe a year has gone by and we've got running trails with everyone in Moab next week. I'm leaving a bit earlier (tomorrow actually) so today has been a total scramble to get everything done to be gone for about 2 weeks.
I knocked out one mod I've been sitting on for a bit - where to install my traction boards. I could put them on top of the rooftop boxes, but that makes them a bit of a pain to get down when needed, and I didn't want to tie up actual rack space or store them in the bed, so went searching for a solution. I came across the Stapll (pronounced like staple)
bedside molle panel system. The also have parts to install them on t-slot rails, so figured win-win... well sort-of.
Before I get into that, I must say these are really well made and a genuinely great design. So looking at the Leitner bedrack, the t-slots on the bottom of the rail face into the bed and out to the side, rather than up, so the Stapll t-slot solution won't work for me, but if you're someone with a bedcover that has a t-slot, it would work for you. Wanting to find a way to still use the panels, I reached out to Stapll and, well, never got a reply. I've emailed them a few times prior and that seems to be a weak point for them - zero responsiveness to emails. In all fairness, I could have called, but whose got time for that?
So in the middle of the night, when I couldn't quite shut my brain off, I started searching for a solution that would work and here's where I landed:
I started off with looking for a bracket that I could attach to the T-slots that I could then attach the top piece of the Stapll mount to and found these:
10 PCS 2" x 1-7/8" Heavy Duty L Bracket, Slotted Corner Brace, 3/16" Thick. They're supposed to hold 400lbs each, so figure 2 on each side would be sufficient to hold the 10lbs or so that the Maxtrax recovery boards weigh. There are several options out there and my concern was I needed it to have holes large enough to accommodate the size screw that Leitner uses for the t-slots. I like that these also give me some room to adjust things as needed.
Test fitting everything together, the screws that came from Stapll that go into the back plate looked like they'd be a little too short for a nut to spin fully on, so ordered a set of
1/4-20 Bolt, 1/4-20 x 1 Inch Flat Socket Head Screws 15Pcs, 304 Stainless Steel 18-8 Countersunk Bolts, Black Zinc Finish, Full Thread, with Hex Spanner and
1/4-20 Nylon Insert Hex Lock Nuts 50Pcs 304 Stainless Steel Locknuts, Hex Drive, Bright Finish, Black Oxide.
I think it came together nicely. Not sure I'll leave the on the truck full-time, but it did take a bit of work to get the spacing just right. That said, I'm only a few times a year somewhere where I'll want to have them with me, so it probably makes sense to remove these between trips.
View attachment 270455View attachment 270456View attachment 270457
