DTX2023Tremor's Money Pit Build and other miscellaneous topics
Those who went to the Moab meet are already well aware of the engine troubles that I've been having since the week of the meet. What started out as an intermittent engine misfire on Tuesday night, ended up with a consistent misfire issue driving home on the Friday following the Moab meet.
I have 62500 miles on it and took it to a local Ford dealer to figure out the issue.
From the service tech:
VERIFIED CUSTOMER CONCERN, FOUND CHECK ENGINE LIGHT PRESENT. RAN SELF TEST, RETRIEVED DTC P0303, P0304, P0306 AND P0300. FOUND EXCESSIVE MISFIRE PRESENT. CHECKED FOR RELATED TSB/SSM, FOUND TSB 26-2256. REMOVE AND INSPECTED OIL FILTER, FOUND EXCESSIVE METAL AND DEBRIS PRESENT. AT THIS TIME WILL NEED TO REMOVE AND REPLACE ENGINE LONG BLOCK PER TSB, THEN RE-TEST. FORD ESP APPROVED REPAIR.
From the TSB they referenced:
Issue:
Some of the vehicles listed in the Model statement above may exhibit an upper engine ticking or tapping noise at idle. Customers may also report experiencing rough engine performance, engine misfire, or a MIL with DTCs P0301-P0308 in the PCM. This may be due to camshaft and/or valve tappet having excess wear within the engine assembly.
So I'm getting a new engine. Fortunately, another dealer locally had one in stock so they've transferred all the parts to my dealer who got everything in today. As you can imagine, they don't have a ton of techs that can do these jobs, so the main one won't get started on it until Friday. They'll have to pull the cab off and they're working with the shop whose done all my mods to minimize any impact to the things I've had installed.
Currently estimating that the new engine will be in place by end of next week.
From there, the dealership is going to chase a few other issues that seem unrelated to the lifter failure - random TPMS errors which said my tires on the driver's side were at 0 - 3 psi (happened intermittently on the drive out of Moab to L.A. and again from the drive to L.A. to Dallas), also occurred on the drive to Dallas a warning that Pre-collision assist wasn't available and separate instance of adaptive cruise not being available.
Batteries were replaced in late January with new X2Power AGM batteries so that's unlikely to be the issue.
good luck. I also just got a warning that Pre-collision assist wasn't available, so I hope it is unrelated to all the issues that led to a new engine.
is the top center of your windshield dirty or blocked?
or you adaptive cruise module blocked?
hopefullly that's it🤞🤞🤞🤞🤞
or just needs a restart (reboot)
About six months ago an OTA update cured this ill for my truck. Do you allow those over-the-air updates for your truck? They typically offer to schedule these for 1:00 a.m. - then again you more than likely know this.
:geek:
Not blocked or dirty,
And I dont have adaptive cruise that i know or.
I do have adaptive lane assist and pre collision alerts
Issue:
I'm assuming you have an extended warranty?
Man that sucks. I feel like mines a baby compared to some of the mileage everyone has on their trucks. Lol I just hit a little over 15k. I'm looking to buy a warranty but I want more years than higher mileage.
Same. Went with 10yr/60k
I was looking at that one as well. Just concerned 60k miles won't be enough for 10 years but then price jumps quite a bit for 75k.
I debated that as well but am currently staying on track with 5yrs and 29k!
Yeah got the 10 yr / 125K warranty. Might see about increasing to 150k as at current mileage trend I'd probably hit 200k miles at 10 years.
The Tremor meet ups chew thru miles Fast
Moab Meet up was 2700 miles RT , and KTP was 2500 miles RT
yeah but????
trips to the arctic ocean really tallies up the miles
yeah but????
Pro tip to keep the miles off the Tremor......
- Ride two motorcycle to Alaska instead LOL
She's alive! More details to come...
^ ^ ^ GREAT NEWS! SUCCESS! (y) 🏁
/borat
Yeahbbut ya kno what they say: "Thems're haghway miles, son!"
Sounds whiny…….
Are you suggesting there's some sort of huffinat0r dee-vice atop that there 445 incher?
I do declare. Our man DTX had spoken of such shenanigans! I had thought it a bit early... but he could (as he always is!) be just one. step. ahead of us all.
:ROFLMAO:
Wanted to share an update on my build now that the Whipple is in, plus a few things I learned along the way that might save someone else some time.
What's installed:
  • Whipple Gen 6 3.0L Stage 2 (WK-2341-STG2-30), stock pulley
  • Stainless Works 1-7/8" long tubes (FT220188HCAT)
  • GESi high-flow cats, SKU SWGESI400 (EPA N-GBL-4363-0926). Not listed on the Stainless Works site — ask for it by name. It's the 400-cell, EPA-compliant cat they recommend for forced-induction builds.
  • Stainless Works Legend cat-back
  • NGK 95822 (ILTR7N8) plugs gapped to .031" — on Whipple's approved list
  • Ton's plug wires
  • OEM coils (MSD doesn't make a 3-wire coil for this engine)
  • UPR catch can with clean side separator
Huge thanks to Will and his team @Renegade Customs Rockwall for the install and the patience.
Lessons learned:
1. If your PCM has been reflashed, tell Whipple up front.
My truck had an engine replacement, and the dealer flashed every module to Ford's latest software. The Whipple calibration wouldn't load because the truck wasn't configured like a 2023 anymore. Whipple turned around a patch quickly, but it's worth flagging when you order.
2. Brake lights flashing on throttle release. After install, the brake lights flashed when revving in Park and quickly letting off the throttle. We chased the boost-into-the-booster theory, and the tests ruled it out. Best explanation so far is newer Ford software behavior — at least one 2024 owner reported the exact same flash on a stock truck. If anyone with a stock 2024+ can confirm, I'd appreciate it.
3. The 23+ manual still shows the old brake booster routing. The current public manual (R3, Jan 2025) leaves the check valve in the stock location. Whipple has been emailing corrected routing to 23+ customers — ask for it before you start.
4. Catch can on a Whippled 7.3. UPR's instructions assume a stock intake. With the Whipple, the PCV no longer goes to the intake manifold — it goes to the RH top port on the supercharger inlet. So the catch can sits between the RH valve cover and that port, replacing the Whipple PCV hose. The CSS goes on the LH valve cover as normal. I purchased longer hoses to allow for them to route behind the Whipple rather than over it as the provided hoses would require. One of the provided hoses was too short for this anyways, so getting two new hoses made at a shop nearby was the best solution.
First impressions: The truck is quick. Big difference. Oddly, it seems quieter at idle from the front and driver's door than it was with the Borla S-Type I had before, but standing near the tailpipes during a rev is genuinely painful. The whine is noticeable inside and out but not annoying so far. The exhaust note is a different pitch than the Borla and while seemingly tamer at idle, is definitely more aggressive sounding under acceleration (definitely going to create more "smiles per gallon", but more tears at the pump).
Next up: Getting all of the lights and other electronics reconnected that had to be disconnected so the cab could be pulled for the engine swap, and loading the 5 Star custom tune via MPVI4 in the next few days. Looking forward to the long highway run to College Station for the meet-up on December 5 to see how the Legend does for drone at 70–80.
With the Whipple and Stainless Works long tubes on, the next big project is the cab. The truck spends 90%+ of its miles on pavement, most of it highway. Between tire roar, wind hitting the roof rack, and the extra exhaust note, I want a quieter cab for long days behind the wheel. My goal is to have it done before the end of December.
THE PLAN
Each layer does a different job:
- Damping (CLD): Second Skin Damplifier Pro at about 60-70% coverage to stop the sheet metal from ringing. I chose it over the budget butyl mats because of how hot a cab gets in a Texas summer.
- Decoupler: Second Skin OverKill closed-cell foam at 100% coverage, so the barrier layer floats instead of touching the metal.
- Barrier: 1 lb mass-loaded vinyl (Second Skin Luxury Liner) on the floor. ResoNix Barrier on the transmission tunnel and the firewall, since it handles heat better than vinyl.
- Absorber: 3M Thinsulate SM600L on the roof, cab back wall and firewall. It's too thick to fit under the Carpet Delete floor panels, so the floor stops at the MLV.
- Pillars and roof cross-braces: filled with Thinsulate strips. I considered using Rockwool, but it has to be wrapped to keep fibers out of the cab, so I ruled it out.
DOORS
I picked up the MTI Acoustics Stage 1 SuperCrew bundle on sale: access cover panels, 44 sq ft of SoundShield mat and their speaker contour kit. I'm adding 72 BlackHole Tiles from Sounds Good Stereo for the outer door skins.
ORDER OF WORK
1. Rear floor, cab back wall and C-pillars
2. Front floor, firewall, transmission tunnel and A/B pillars
3. Roof (headliner out) and roof cross-braces
4. Doors
I'll post pictures and lessons learned as I go. If you've treated the roof or tunnel on a 2023+ Super Duty, I'd appreciate tips, especially on headliner removal and clearance under the Carpet Delete floor panels.
