Featured
- #361
- Jul 30, 2023
- 2,734
- 8,599
- PADI Divemaster & Rescue Diver, Medic
- 2024 F350 Tremor 7.3 Godzilla - Carbon Gray
- 1985 GMC 2500 4x4 High Sierra
Glad I could help with the design of the brackets...
Fun mods!! Can’t wait to see the lights in person in Sedona!Time to catch up on some recent mods... I posted previously about the custom light bracket @legmar designed for me that allowed me to put two rear facing lights and two lights angled out at 45 degrees attached to the bumper. Finally got these installed and the engineers and Assistant Plant Manager at Ford thought they looked great. The Baja Designs S2 Pros (rear) and S2 Sports (side) put out a ton of light. I'll take photos in Sedona where the contrast between off and on will be much easier to photograph. These are wired up to a single switch on my Switch Pro. I thought about splitting the rears and the sides between two switches, but figured if I need them, I'd likely want the wider field of view.
They were also impressed with the build quality of the Carli Trophy hitch and got an earful from a few of us about how it would be great to have a factory option that would accommodate larger tires. @BLACKCHERRY
Took care of a couple of recent mods from Open Trail Creations. @trmrzla these are easy to install and well made. Thanks for making these for the forum. Between the off-roading in Sedona and Big Bend and long road trips to Louisville and Los Angeles, that prefilter is going to get put through the paces. Gotta figure out how I'll use all the new compartments I now have in my upper glove box.
Dude, the parts list to build your truck is shorter than the list of things you have done/will doLast month's Tremor of the Month contest got me thinking about all of the mods done to the truck (or in some cases, stuff I've purchased for truck). Seeing the lists others put together inspired me to pull together a consolidated list of what I've done so far (including a few pending items that have been purchased, but yet to be installed). I didn't include in the list all of the items I carry in the bed in case of a breakdown or flat tire, or the recovery gear kit I'm slowly putting together. There's still a few remaining items on my list of things to do before my build is "done", and these are all fairly big ticket items that I'm budgeting to get done over the next year or two.
Here's what's been done so far:
Communications + Electrical:
• Votex - 13 3/4 Inch Rubber Antenna• WeBoost Drive Reach Overland Cell Signal Booster• NOCO GCP2 15A AC Port Plug• NOCO Genius GEN5X1: 1-Bank, 5A Onboard Battery Charger• Motohorn 2x 3.0• Midland Radio MXT575 MicroMobile®Two-Way Radioo MicroMobile® MXTA25 3dB Gain Ghost Antennao MicroMobile® MXTA31 Microphone Extension Cableo Midland – MXTA24 Low Profile Antenna Cable with NMO Connector – CB Antenna Cable Extension – 6 Meterso MXTA55 Radio Bracket Mount – MXT575o Bulletpoint Mounting Solutions:- CB Radio Holder with 20MM ball- Matte Color Carbon Fiber Mounting Arms- AMPS Compatible 20mm Ball with Metal Mounting Plateo Bullet Proof Diesel Third Brake Light Antenna Mount - 2017-2025 Ford Super Duty• Z-Flash BCM 2300 Vehicle Flasher• Starlink minio Savage UTV Ford-150, 250-550 - Starlink Mini Mount• Pending: SDHQ Billet Battery Terminal KitExterior:
• Line-X spray bedliner• Llumar PPF full truck• BFN Truck Shop paint matched tailgate applique panel• BFN Truck Shop paint matched tow mirror caps• Signville Tremor bedside decal• Bushwacker Black OE style fender flare kit• Tufskinz hood letter inserts – black/silver American flag• Front license plate relocation bracket• Super Duty 2023-2024 Black 2-Piece Set Front Wheel Well Liners• Pending: TruXedo TruXSeal tailgate seal• Pending: Surface Shield rust protectantInterior:
• BuiltRight rear seat release• 4Knines floor hammock• Canvas back door covers• Tuffskinz door sill protection overlays front/rear doors• Llumar ceramic tint 15% front/30% rear• Llumar clear 80 windshield film• Stickerfab upfitter switch labels• BuiltRight rear seat back storage panel• BuiltRight dash mount• Ford Premium 4pc Locking Bed Cleat Kit• Open Trail Creations GearVault Organizer – Super Duty 2023+ Upper Glove Box• Pending: Desert Does It front multi-mount panelsLighting:
• SwarfWorks Switch-Pros SP-9100 mount kit• BMC Lights Fog Pocket Kit – S2 Pro / Squadron Pro• Baja Designs XL80 + S1 mounted as ditch lightso SDHQ Built A-pillar light mounto Bad Ass Mounts 360 degree swivel mount• Baja Designs 7XL linkable bumper light kit• Legmar Bumper light mountso Rear facing: Baja Designs S2 Pro Flush Mount LED Light Pod, Work/Scene Patterno Side facing: Baja Designs S2 Sport Flush Mount LED Light Pod, Work/Scene PatternMechanical:
• Transferflow 58 Gallon fuel tank• Borla Cat-back exhaust system S-Type• PPE Sterling 11.6”– 16 Bolt Heavy-Duty Cast-Aluminum Rear Differential Cover• PPE 2020-2024 Ford Super Duty 6.2L/7.3L 10R140 Heavy-Duty Cast Aluminum Transmission Pan• Open Trail Creations AirGuard Pro FilteredSecurity + Safety:
• IGLA• Drone X1 max LTE• Blackvue DR970x 2 channel dashcamo Mounted on Blendmount rearview mirror mount• Talons Garage skid plate / catalytic coverter shieldo Coated both sides with Line-X• Plate Keeper security screws• Retrax Powertrax Pro XR tonneau cover• Geno’s Garage OBD-II port lock/tune saver• Omaha Bravo Designs Hood Guard• Omaha Bravo Designs Tail Guard• Omaha Bravo Designs Cover Guard• Pending: Omaha Bravo Designs Light GuardSuspension / Weels:
• Carli Front Ford Super Duty 2.5" Leveling Coils• Carli Signature Series Custom Tuned Shocks• Carli 17+ Ford Super Duty Front Stainless Braided Brake Lines• Caster Correction Shims• Carli Leveling Front Bump Stop Drops• Carli Adjustable Track bar• Factory Load Scale / Headlight Sensor Lift Brackets (Front/Rear)• Carli Torsion Sway Bar• Carli High Mount Steering Stabilizer• Carli Low-Mount Steering Stabilizer and Front Diff guard• Carli Suspension 17+ Ford Super Duty Trophy Hitch• KMC Mesa Satin Black Wheels with Gloss Black Lip• Gorilla Spline Lug Kit• TOYO Open Country AT3’s 37/12.50/18Miscellaneous:
• Stahlbus Engine Oil Drain Plug Valve• Centramatic Wheel Balancers• Staun Tyre Deflators - Heavy Duty• Rough Country hidden winch mount• Rough Country winch• Wicked Trucks AC drain relocation kit• InfiniteRule hitch lock set• BougeRV Rocky 55QT dual zone 12V portable fridge• Tmat Truck Bed Organizer• Hail ProtectorInstalled + Removed:
• BMC hitch bar lighting kit (due to Carli trophy hitch)• LatchLid tail light theft deterrent (rusted, upgraded to Omaha Bravo tail guard)• Prospeed Rack CB/ HAM Antenna extension bracket (moved GMRS antenna from ditch light mounted to mounted on 3rd brake light)
Love those light brackets and their angles.Time to catch up on some recent mods... I posted previously about the custom light bracket @legmar designed for me that allowed me to put two rear facing lights and two lights angled out at 45 degrees attached to the bumper. Finally got these installed and the engineers and Assistant Plant Manager at Ford thought they looked great. The Baja Designs S2 Pros (rear) and S2 Sports (side) put out a ton of light. I'll take photos in Sedona where the contrast between off and on will be much easier to photograph. These are wired up to a single switch on my Switch Pro. I thought about splitting the rears and the sides between two switches, but figured if I need them, I'd likely want the wider field of view.
@DTX2023Tremor You should take your truck for a professional photo shoot! With a list like that, it has a career in modeling for sure! @Optimus🤖 probably has some referrals…Last month's Tremor of the Month contest got me thinking about all of the mods done to the truck (or in some cases, stuff I've purchased for truck). Seeing the lists others put together inspired me to pull together a consolidated list of what I've done so far (including a few pending items that have been purchased, but yet to be installed). I didn't include in the list all of the items I carry in the bed in case of a breakdown or flat tire, or the recovery gear kit I'm slowly putting together. There's still a few remaining items on my list of things to do before my build is "done", and these are all fairly big ticket items that I'm budgeting to get done over the next year or two.
• Transferflow 58 Gallon fuel tank• Borla Cat-back exhaust system S-Type• PPE Sterling 11.6”– 16 Bolt Heavy-Duty Cast-Aluminum Rear Differential Cover• PPE 2020-2024 Ford Super Duty 6.2L/7.3L 10R140 Heavy-Duty Cast Aluminum Transmission Pan• Powerstop Z36 Truck & Tow Upgrade Kit + Rotors• Open Trail Creations AirGuard Pro FilteredSecurity + Safety:
Yes sir! Once he upgrades the audio, I will send him the referrals. I want those speakers so loud they'd blow women's clothes off!@DTX2023Tremor You should take your truck for a professional photo shoot! With a list like that, it has a career in modeling for sure! @Optimus🤖 probably has some referrals…
Italian job!!!!!!! One of my favs!Yes sir! Once he upgrades the audio, I will send him the referrals. I want those speakers so loud they'd blow women's clothes off!
Now what movie is that from!?
My wife and I spent some time trying to come-up with a fun name for the truck and we kept joking that this truck is turning out to be a money pit, long before I've even gotten keys. So the name Money Pit has stuck.
Although looks like the name isn't original as someone else on the forum also is calling their truck a money pit. We're calling it Money Pit because it is a well equipped Platinum and I’ll be putting a lot of additional money into it to make it exactly what I want. This will be my first new vehicle in 10 years...
This will be my daily driver, but also want something that has off-road and tow capabilities which is how I landed on a F-350 Tremor. I won't do the type of off-roading that would warrant a Jeep or smaller truck, and I won't tow heavy enough or often enough to warrant the investment in the diesel engine or a DRW. The Tremor with the 7.3l engine is truly the sweet spot for what I need.
One other change in gear for off-roading that I decided to make is to change out my tire deflators. I have the Staun ones and they're great. What was frustrating is that the ring that sets the psi got loose on two of the deflators and they got adjusted from their previous setting. Away from home and needing them to deflate tires, I didn't have the time to recalibrate them to the desired psi, leaving me with only 2 that would get me to the desired level of inflation.
I am loving your thought process here. Great tools and extinguisher you have planned for both seats.It's been a while since I've had a chance to get around to putting mods in. Today, I tackled the Desert Does It Front Multi-mount Panel on both the driver and passenger side front seats. I purchased the standard one for the passenger side and the long arm one for the divers side. Install was pretty easy and made sure to torque the bolts to spec since keeping the seats in place seems like a pretty important thing.
On the driver side, I have planned to mount a multi-tool that has a window break, seatbelt cutter, flashlight on the back side. On the front side, I'm not sure yet what I'll mount there, but do plan to mount a holster (inspired by @Rodd187) once I land on what I want to use for my CCW. On the passenger side, I'm planning to mount a small H3R Halguard Pro fire extinguisher on the front side and a first aid kit on the back side.
I have enough magnet mounts to use these on both sides of each seat and another so open to other ideas or insight into how you're using your mounts.
As an aside on fire extinguishers, I do plan on adding one or two 5lb extinguishers to my bed kit at some point - looking at the H3R MaxOut Dry Chemical, but wondering if any ABC would be just as effective.
Will you be using these to drive over sand or over the stauns?One other change in gear for off-roading that I decided to make is to change out my tire deflators. I have the Staun ones and they're great. What was frustrating is that the ring that sets the psi got loose on two of the deflators and they got adjusted from their previous setting. Away from home and needing them to deflate tires, I didn't have the time to recalibrate them to the desired psi, leaving me with only 2 that would get me to the desired level of inflation.
For Big Bend, I decided to pick-up a set of the Oversand Tire Deflators. The thing I like about these is that the psi are marked on each and it makes adjusting them very easy. I'll be curious to see how accurate they are and might test them out beforehand. The downside for these is that they have only one type vs. Staun which you can get options for different psi ranges for different use cases.
I hear ya brother. When we took delivery my wife and I were both really impressed with everything from the ride quality to the fit and finish of the truck (maybe we've just owned a bunch of shit cars beforehand that the Super Duty's ride felt nice by comparison).lmao! I had the SAME experience with my set of Staun. I miffled two of them myself before I realized what was going on.
I did go straight to a smaller tire's air volume on the wife's car to recalibrate all four just because.
I recently ordered a two-hose deflator setup to do one axle at a time and to have each side's tires pressures set in unison.
You're on the path! Ain't this a blast...![]()
If you replaced those solid half band pieces with something like chain (can lay flat) you could have both top and bottom be releases. One facing each direction.I also test fitted the Desert Does It fire extinguisher mount on the passenger side front seat. Ideally, I'd like the be able to pull the pin and have the brackets open out and down, but with the HVAC tube running beneath the seat, it wouldn't allow them to open enough to make removing a fire extinguisher easy, so pulling the pin from the bottom allows it to open fully. With the test fit, the pin has to be pulled towards the driver side of the vehicle, great if I'm getting the extinguisher before exiting the vehicle, but less convenient if I'm seeking to get it while standing on the passenger side. Not sure what the right answer is on this one, but either way it is easy to pull the pin so figure it will work whenever needed.
