Featured
- #321
Looks really good! About a year ago I wanted to the same look for when I was hooking up my travel trailer at night. Went with this bracket and dual lights.Today, I'm really excited to share a pre-mod that I have planned for my truck. I say a pre-mod as this still needs to be fully installed (wired up), but today I test fit a product that I have been working with @legmar to develop.
A little back ground, I had the BMC hitch lights installed on the OEM hitch and those lights worked great for adding rear facing light when needed. I decided to replace the OEM hitch with the Carli Trophy Hitch and, welp the end tubes are capped so the BMC lights unfortunately won't work and I didn't want to have the caps cut off to see if it could work.
Cue @legmar to the rescue. Since he already has a really well designed bumper light mount, I reached out to him to inquire about designing a new light mount. If one light on each side is good, could two lights on each side be better? If you've seen my truck, the one thing it is missing is lighting and I decided that I want two lights pointing aft and one on each side angled out to each side.
@Nick@ApolloOff-Road jumped in to help and provided not only some great guidance on light options, but put together a complete kit with all the wiring and harnesses needed. We landed on Baja Designs S2 Pros facing rear and S2 Sports on the angle out to the side.
Special shout out to @MVI who provided guidance on metal alloys to consider and fabrication to get the design dialed in.
We landed on a marine grade 5052 aluminum, which will resist rust and had the mount powder coated for additional corrosion protection (but more so for aesthetics). This bracket is beefy and incredibly well designed. It mounts to two bumper screws, avoiding the need for any drilling (as with @legmar 's original mount).
Here are some photos of the kit test fit on my truck today. It will be a few weeks before it is fully installed as I'll combine the install with some additional mods to maximize shop time. Wanted to share so that anyone else who wants these brackets can get the kit from @legmar.
Where did you tap into power? I had the ones on my '20 wired to one of the upfitters but wondering about just wiring to the reverse lights this time on my '24
KD Fabeworks definitely makes good stuff. I had seen their brackets and wanted to go with something close, but as you can see different. I would have otherwise gone that route and fortunately know someone who could make my idea come to life. Would be great to see a photo of how yours turned out so others can see the difference between the two approaches. Always good to see options since we all have different preferences and either way are great options.Looks really good! About a year ago I wanted to the same look for when I was hooking up my travel trailer at night. Went with this bracket and dual lights.
DUAL Back-Up Light Mounts - 2017-2025 Ford Superduty F250 F
www.kdfabworks.com
But love the clean look of yours!
Not a problem, I have a picture on my build thread that my youngest took after we set it up.......but it's very blurry and the wiring is horrible. I will take another picture today and send it to you.KD Fabeworks definitely makes good stuff. I had seen their brackets and wanted to go with something close, but as you can see different. I would have otherwise gone that route and fortunately know someone who could make my idea come to life. Would be great to see a photo of how yours turned out so others can see the difference between the two approaches. Always good to see options since we all have different preferences and either way are great options.
I'm going to wire these to my SwitchPro that I also have all the other aftermarket lights wired to. Nice to have as I'm down to one upfitter switch left with the other things I have installed. Apollo Offroad included the wiring harness for power. I don't do the wiring myself, but can ask my shop to take photos of the install when they do it. It won't be for a while as I'm planning to combine that install with another and its not in the budget to do it now (likely mid-to-late summer).apparently I screwed up the quote feature...
Where did you tap into power for the backup lights?
Here's that picture...... Best part of these was the angle of the bend to spread that light out so I can see at night.Not a problem, I have a picture on my build thread that my youngest took after we set it up.......but it's very blurry and the wiring is horrible. I will take another picture today and send it to you.
Such a cool project, man! Glad to be a part of it and glad you're happy with how it turned out!Today, I'm really excited to share a pre-mod that I have planned for my truck. I say a pre-mod as this still needs to be fully installed (wired up), but today I test fit a product that I have been working with @legmar to develop.
First time I jump in your thread - impressive work! Have some reading to digest...Today, I'm really excited to share a pre-mod that I have planned for my truck. I say a pre-mod as this still needs to be fully installed (wired up), but today I test fit a product that I have been working with @legmar to develop.
Totally makes sense. The off roading your truck sees is vastly more challenging than what I expect to see. I spend 95% of my time on roads or unpaved roads. I think on the odd occasion where I might have a clearance issue, I could proactively remove the lights (might do that for Sedona if you think that's wise based on the trails we decide to go on). Although I'd prefer to avoid anything that might scrape the bumpers (or anything beyond what PPF will protect) given I'm still on OEM bumpers compared to your aftermarket set up.First time I jump in your thread - impressive work! Have some reading to digest...
While I believe this is a beautiful set up due to the double angle, which irrates me as well not having a properly lit back area, I would have to agree with @Godzilla/Tremornator, they are definitely not off-road friendly.
I've been known to land on my rear bumper more than once and my policy is, anything below the bumper is simply a no-no.
I have also landed flat on my spare so once again, if @legmar can design something for the rear steps of my bumper as mentioned by Tremornator, I'd be all over it.
The first and only time I tried to use this step for its intended purpose, I just about claimed disability since I could not unhook my boot from the step-hole as I was coming back down. Back to the good ol'way of using the bumper as a step - keep it simple.
I don't see the need to remove them honestly and we can avoid taking any trails that the majority don't feel comfortable doing.Totally makes sense. The off roading your truck sees is vastly more challenging than what I expect to see. I spend 95% of my time on roads or unpaved roads. I think on the odd occasion where I might have a clearance issue, I could proactively remove the lights (might do that for Sedona if you think that's wise based on the trails we decide to go on). Although I'd prefer to avoid anything that might scrape the bumpers (or anything beyond what PPF will protect) given I'm still on OEM bumpers compared to your aftermarket set up.
I am curious your opinion on this setup vs the BMC hitch lights. Both seem to be about as far below the bumper as each other ( I can take some measurements at some point since I still have them), and those didn't seem to be an issue on the trails at Big Bend. Just trying to get a sense of the likelihood I will need to plan for potential snagging when going off-roading.
@AZsurveyor ,I am not going to Sadona, but I just finished reading what you wrote above. I have to tell you, I've never met you, but my respect level for you just increased exponentially. The way you handled your reply to @DTX2023Tremor was masterfully written in a way anyone would want to go off roading with you. Thank you for the concern and respect you have for your fellow forum members.I don't see the need to remove them honestly and we can avoid taking any trails that the majority don't feel comfortable doing.
It would make no sense to me forcing folks to take their rigs where they're simply not going to enjoy themselves.
I am by no means advocating body damage to be fun, simply said if you don't have the experience, you will not enjoy yourself on tougher terrain. There is no fun in feeling concerned and that is when mistakes happen.
For those that want more challenging trails, we have them and we can part ways if that's how we decide to do things.
What isn't fun either is having too large of a group; just think about when you're behind a car or two for miles on end, all your doing is itching to be able to pass so perhaps we should consider this?
As far as which light best suits any off-roading, I would think the hitch lights.
On our last trail run here in AZ with the Tremer group, @Vecman totally missed a ledge that had errored away and drove through it in the coolest fashion. At the time, he had S2 Pros mounted underneath his bumper and nearly crushed it - thankfully he mounted them a little further on the inside than what you seem to have done so he was able espaced with no ill damage.
Your transmission pan would disagree....my goal is to complete the trail with no damage, not even a scratch.
His new trans pan has no clue!Your transmission pan would disagree....![]()
How would you define experience?I am by no means advocating body damage to be fun, simply said if you don't have the experience, you will not enjoy yourself on tougher terrain. There is no fun in feeling concerned and that is when mistakes happen.
