Today, I'm really excited to share a pre-mod that I have planned for my truck. I say a pre-mod as this still needs to be fully installed (wired up), but today I test fit a product that I have been working with
@legmar to develop.
A little back ground, I had the BMC hitch lights installed on the OEM hitch and those lights worked great for adding rear facing light when needed. I decided to replace the OEM hitch with the Carli Trophy Hitch and, welp the end tubes are capped so the BMC lights unfortunately won't work and I didn't want to have the caps cut off to see if it could work.
Cue
@legmar to the rescue. Since he already has a really well designed bumper light mount, I reached out to him to inquire about designing a new light mount. If one light on each side is good, could two lights on each side be better? If you've seen my truck, the one thing it is missing is lighting and I decided that I want two lights pointing aft and one on each side angled out to each side.
@Nick@ApolloOff-Road jumped in to help and provided not only some great guidance on light options, but put together a complete kit with all the wiring and harnesses needed. We landed on Baja Designs S2 Pros facing rear and S2 Sports on the angle out to the side.
Special shout out to
@MVI who provided guidance on metal alloys to consider and fabrication to get the design dialed in.
We landed on a marine grade 5052 aluminum, which will resist rust and had the mount powder coated for additional corrosion protection (but more so for aesthetics). This bracket is beefy and incredibly well designed. It mounts to two bumper screws, avoiding the need for any drilling (as with
@legmar 's original mount).
Here are some photos of the kit test fit on my truck today. It will be a few weeks before it is fully installed as I'll combine the install with some additional mods to maximize shop time. Wanted to share so that anyone else who wants these brackets can get the kit from
@legmar.
