DTX2023Tremor's Money Pit Build and other miscellaneous topics
We have two
Tremor and king ranch
😆 We have a 25 toy 4 runner wife’s daily
It’s kinda of a turd we are prob going to replace with
Bronco
The pair of SD are staying forever
It's been a while since i posted an update on what's been going on with the truck. I think a few months ago I posted a question regarding fire extinguishers and it was great to go over my whole first aid and fire response plan with @Camarox2 (who is a seasoned fire fighter / paramedic). I decided to go with two 5lb ABC fire extinguishers that I plan to mount inside the bed of the truck, a Purple K that will be mounted on a Desert Does It seat mount on the passenger seat and then an Element 100 mounted on the Desert Does It seat mount on the driver side.
The logic behind the fire extinguishers is:
- If a fire starts and I can get to it quickly, the Element may be all that's needed.
- If it goes a bit or grows, then jumping to the Purple K extinguisher as it is going to be a little easier to clean up than the ABC
- The ABCs are more to help others. Chances are if I can't put out a fire in my truck quickly, it would likely be a total loss and the bigger extinguishers would be helpful to prevent the fire from spreading beyond the vehicle, rather than to try and save it from damage.
Despite a few carwashes and hosing everything i could get to that isn't the interior of the truck, I am still finding dust in crevasses from Sedona and Big Bend last year. In an attempt to minimize the dust intrusion, I sealed all of the bed seams with a black silicon caulk and also installed the truxedo bed seal. With the added @OmahaBravo Designs security mods installed, I didn't want to uninstall everything so the truxedo bed seal stops short about 2 - 3 inches from the top of the tailgate.
The truxedo bed seal has a thin section and then a thicker ribbed section. The install instructions have you put the thin section towards the left on the driver side and right on the passenger side. This had me removing the @OmahaBravo Designs light guard to put this behind it. Getting the light guard back in pace was a bit challenging as I had to compress the seal significantly (using a 2x4 with my full body weight applied to it) and have it snap in place behind the light, which results in the light guard putting a fair amount of pressure on tail lights. Hoping it won't be an issue, but time will tell if it causes damage to the tail lights. I did find that the power close on the tail gate doesn't do so well with the seal adding resistance, so it will require a bit of force to "slam" the tailgate shut for it to fully latch.
It will be interesting to see how much dust gets into the bed with these changes. I'm not sure how well the Retrax Pro XR keeps dust out, but with so much dust coming in through the tailgate and bed seams, it was difficult to tell what dust was a result of the tonneau versus other entry points.
I've never had a closed bed until I got this camper. Big bend was a massive eye opener on the dust intrusion from a non-sealed bed :oops:
Hope the sealing does it for ya!
Post this image here for one solution to dust intrusion within a closed space. This is 97% effective, if not even more effective than that.
This was it's first real test, and it was even more dusty two days later on the 6-mile run egressing the area.
First you must do as you are doing: SEAL EVERYTHING YOU CAN.
But for the seams, gaps, and cracks you cannot find or cannot access, there is POSTIVE CABIN PRESSURE.
Just a little! is enough. More is better. This is a universal solution. It is not original; only my application of parts.
Note the fresh air scoop made of aluminum ducting affixed to the upper driver side of the trailer. There is a sheet of filter foam in the wall at that pass-through (a 3/5" hole in the wall).
The dust from Big Bend would have made it Into the Artemis II capsule. I am not sure there is a camper shell made that could have kept the dust out on that trip.
Mike,
One thing to keep in mind her since I did the same a while ago. If the bed leaks water there is no where for it to go if fully sealed. So I would suggest leaving a small gap on the four corners of the bed for water to exit and not pool.
Mike,
Thanks... I didn't think it through enough I guess. I sealed all of the seams I could reach (a few inches behind the Retrax canister I couldn't get to). I suppose that puts me on mopping duty whenever water does get in.
I'm planning on doing an overland build and putting a battery system in the bed, so hopefully whatever water intrusion does occur doesn't end up causing a bigger issue. I'm planning to steal an idea from @TellurideTremor and add an additional seal on the end of the cover so that it seals better at the top of the tailgate. That tends to be where most of the water gets in.
Mike,
There are two "exits" at the front of the bed for water drainage. If you just be sure not to seal those, you will be fine. I had to drill a couple holes in my Diamond Back cross-bin toolbox though; it held water and corroded several tools. All channeled now though and tools are in waterproof box.
excited to see how this turns out
Thanks.. now I need to find a massive bag of cash somewhere 🤪 the way I got the wife on board is that an overland build will save us $80k+ over the cost of the RV trailer we've been looking at and give us a lot more flexibility in terms of destinations. The toughest part of the sell is she's never been camping before and it may be something I end up doing alone (which isn't what I'm wanting), so trying to build it out to make it as much of glamping experience possible (which I can't lie, would also be nice for me too).
as my buddy Kyle said it best:
you want to thrive, not just survive.
You could have bought the $80k trailer and then realized you needed the $100k truck to pull it. Not that has ever happened to me…. What happened to my water proof gear bag on my Enduro and sleeping a in a tent. Oh yeah moving out of the mountains and the whole happy wife happy life thing
Alternatively, you could install a sump pump in the bed and apply for most unique Tremor build of the year! 🤪
I hear ya. Recommend you confirm she is okay using a composting toilet and not showering for a few days before you get too committed.
I tried convincing my wife and I think it’s gotta be at least a wet bath bed camper or an overland camping rig towing a travel trailer for her to participate 😆
Yeah, that is exactly the crux of the issue. Found a well rated flushing toilet and a 3 room pop-up tent that has a room for the toilet, shower, and a changing room. Will also add a water heater and a tent heater (maybe a portable A/C for those warmer evenings).
Planning to travel with 20gal of water, but the switch to military showers will take some practice. Figure short 2 - 3 day trips (where I can get water easier in case consumption exceeds capacity) to start to get her used to everything before attempting longer ones.
Worst case, things longer than a couple of days may just be trips with the guys.
Here ya go Mike. Just show here this. I consider this glamping. 5th wheel is just plain luxury :ROFLMAO: I am adding the roof rack this weekend. Next will be the shower. The 270 degree awning is on the other side already.
