Regrets going to 37s after Carli?
It’s hard to “regret” going to 37s on a new gen tremor. One does need a level nor a lift. With the right 37” tire, the wheel well does not look stuffed nor is there an ass high look with ~500lbs in and on the bed, it levels out organically. All it took was shifting the sway bar precisely 1/8 of inch for full lock to lock clearance, and even that was more for a piece of mind rather than a necessity.
I haven't parallel parked like that in years. Great job! 🤪
I haven't gone to 37s because of the spare, that no one ever talks about.
I am not shelling out $2,500 for a trophy hitch to allow a 37" spare.
I still have my original spare, but plan on swapping it out to match my 37" tires. I am going to deflate the spare tire a little bit like it was mentioned on here.
Besides the price of that trophy hitch, I don't want to lose my 3" receiver.
I also agree that Ford should have gone with 37s stock. I really dig the race truck CJC did with the Carli suspension. I think they put on 40 or 43" tires. Looks super badass.
You can fit a cooper AT3 37" tire in the stock spare location if you deflate it. For me this is the best solution as I have onboard air already.
Did you just get an extra wheel to match your current wheels or did you just mount that tire on the spare rim? I need to do this was planning on getting the same setup so it would be an easy switch in the field if I ever needed to this. Especially with wanting to do long trips off grid.
Lucky you!! Do it daily in Boston. The worst is when you come out to find youve been trapped in!!
So you mean to tell me that the trophy hitch reduces the 3" receiver to a ??
Just another thing to consider and more gear to change!
Really want those 37" but what a royal pain this is going to cause...
Trophy hitch is a 3" receiver, but I think the weight rating at 16k lbs is lower than the Ford 3" receiver
Thanks for the link and clarification.
Didn't understand what they meant by "utilizes factory winch" - for the rear?
Oh thats new I think. When I first saw it I thought it was the standard 2.5" receiver. The weight rating is a big deal for me. I like my 22k rating for more options in the future. Also that one does not let me connect my truck camper tie downs easily like the OEM one.
Cool option depending what is needed. Just not for me. Maybe they will make better from people like this forum looking for certain things.
I've had the 37s in my truck for a week now and love them. I don't notice any "floating" on the freeway from the extra sidewall at all. Granted mine are the Nitto Ridge Grapplers which I've read have a very stiff sidewall.
Got an extra rim and tire. Since my rim size is different from stock. I want to be able to use the spare anywhere without issue since I'm planning some long drives.
How much did you have to deflate it by?
Almost completely. I have beadgrip rims so the bead doesn't come off and onboard air so I can inflate it when I need to use it.
Are you running the new Icons?
Thought the Tremor was rated to 15k bumper pull anyway? I tried to deflate my 37” Falkens and Toyos and they did not fit at all, so I pulled the trigger on the trophy hitch. I like it. It has some “pockets” that allow me to secretly store some things that I’d like to be able to access in the event I can’t get into the truck.
22K appears to be stock.
18,200 per the towing guide. 250/350 either engine.
And if you've swapped out 37s, then you've effectively already lowered that by some amount. Also per Carli's comments, since they had zero deflection at 16k, they surely could have gone higher on the testing had they asked. With all that in mind, for practical purposes I doubt you're losing much if any real towing capacity with their hitch.
18,200 lbs. is for trucks with 8' box - 15,000 lbs. for Tremor for bumper pull - see attached for specs for F-250 - 350 - 450 - 2022 spec sheet below.
When I installed by Trophy hitch - all bolts and install points are the same - the Trophy hitch is more robust in structure to the OEM hitch, which showed 20k rating on my 2022 Tremor. I know the Carli is rated at 16k with no flex - so it should more than cover the 15k max for the Tremor.
