- OP 🔹
- #61
Don't forget the heavier weight of the 37s on the stock winch. You may be able to get it in there, but will it stay in with, um ... spirited... driving? (It might, but just be aware of it.)
Cheers,
-mox
Cheers,
-mox
What is the offset of your wheels?Now the question is, will I have to update radius arms since I am on stock ones with an ICON 4.5" lift?
I don't want to sacrifice turning radius or rub at full turns.
That was the original estimated price from Carli before it went into further testing and they beefed it up even more and added the bigger price tag IIRC.Where do you see a Trophy hitch for $2500??? I’d buy one today for that. Seriously. We actually talk about the spare size a lot. Trophy hitch is the answer.
PM Sent.They’re welded plates…. But they say Carli! That’s why I asked where they were $2500. I think most places I see are $3150.
this is what I intended to test out with my current Ridge Grapplers when I replace them. They’re at around 40k now, so sometime mid this year. I’ll put a worn 37” in the spare location. The wear should give me an extra 1/4” or so. I have an ARB on board to inflate it if needed.You can fit a cooper AT3 37" tire in the stock spare location if you deflate it. For me this is the best solution as I have onboard air already.
This comes up on nearly every "fullsize spare" discussion, but I would be curious if anyone has seen any long term issues from deflating the spare and squeezing it into a space that's not round. Fully inflated there's basically two points on the hitch where the tire binds up, would those be deforming the tread on the tire once it's up there (full disclosure, I havent tried deflating it yet)? I've been doing 5 tire rotations on my truck so the longest it would be up there is 4-6months, but I'd still always be wondering if it was ok. May give it a try next time I have a long trip that needs more bed space.Well I'll be damned, I am going to have to see if a 37x12.50x18 Toyo RT Trail will fit deflated as well. Your Cooper AT3 shows an actual size of 36.54" which is the same as my Toyo RT Trail, so there's hope!
How much did you have to deflate it by?You can fit a cooper AT3 37" tire in the stock spare location if you deflate it. For me this is the best solution as I have onboard air already.
This comes up on nearly every "fullsize spare" discussion, but I would be curious if anyone has seen any long term issues from deflating the spare and squeezing it into a space that's not round (fully inflated there's basically to points on the hitch where the tire binds up, havent tried deflating)? I've been doing 5 tire rotations on my truck so the longest it would be up there is 4-6months, but I'd still always be wondering if it was ok. May give it a try next time I have a long trip that needs more bed space.
What psi is the tire at?You can fit a cooper AT3 37" tire in the stock spare location if you deflate it. For me this is the best solution as I have onboard air already.
You are going to love your new E-Venture suspension. I have a 22 F-350 6.7 - I have 28,xxx miles on my E-Venture system and also went with the 1.5" lift. I have Toyo ATIII 37x12.5x18's on Method 305 HD's - +18 mm offset. I also have the torsion sway bar, dual stabilizers, links, radius arms and full spring pack - so the works from Carli - all installed by CJC.'23 6.7 with Carli eVenture pending, so it will be +1.5" higher. I'm 6'6" so going to 37x12.5 on 17x9 +18 won't bother me height-wise.
But what will bother me is wallowing, tippy-feeling, or sluggishness. 37s are bigger, heavier, taller (CG), vastly more sidewall than the stock 18" Duratracs. 35s likely won't look too bad from the pics I've seen, but I'm curious about the SOTP feelings.
TIA!
Cheers,
-mox
I do use my rig for what it was built for on a daily basis and she is primarly an off-road rig as a Land Surveyor. Having said that, I will not head out to a job without a full size spare and with all the surveying gear in the bed of the truck, I simply do not have any bed space to sit or lay a 37"
I do not understand this. Except for a flat while swamped in mud, if you have to jack in order to swap you have enough room to access it.Even with a trophy hitch I wouldn’t carry a spare under my bed off-road if I was going into situations where I could expect to get a flat and I was counting on the spare to get me home.
Sadly one of the few times I did not buy the road hazard warranty to due never using it :/ go figure.Did you buy road hazard or buy from a TOYO driven dealer? If so should get a big chunk back on road hazard
Very true! A few times I've seen scuff marks on my under bed tire from rock ledges.Very easy to damage the tire/wheel under the bed when on trails.
...More and more I am wanting to move up to 37s but it seems like the ultimate ticket will be having to go with the trophy hitch option although I am not pleased with this extra expense....
Tried to stuff my 37x12.5r17 Toyo AT3 this morning and there’s no way it’s going to happen, deflated to ~5psi and got it about 80% of the way in before it was just too tight to go any further and that was hitting the tread with a mallet where the lugs were getting hung up. By my eye it’s probably .5” too wide to work and the tread was definitely deforming, I would not feel comfortable storing it at that low of PSI and with the tread deformed long term like that.This comes up on nearly every "fullsize spare" discussion, but I would be curious if anyone has seen any long term issues from deflating the spare and squeezing it into a space that's not round. Fully inflated there's basically two points on the hitch where the tire binds up, would those be deforming the tread on the tire once it's up there (full disclosure, I havent tried deflating it yet)? I've been doing 5 tire rotations on my truck so the longest it would be up there is 4-6months, but I'd still always be wondering if it was ok. May give it a try next time I have a long trip that needs more bed space.
Is this a new tire?Tried to stuff my 37x12.5r17 Toyo AT3 this morning and there’s no way it’s going to happen, deflated to ~5psi and got it about 80% of the way in before it was just too tight to go any further and that was hitting the tread with a mallet where the lugs were getting hung up. By my eye it’s probably .5” too wide to work and the tread was definitely deforming, I would not feel comfortable storing it at that low of PSI and with the tread deformed long term like that.
Sigh… back to the drawing board.
No, has about 11k miles on itIs this a new tire?
For those that know me, know that I would never ever feel comfortable heading out to a job, in no man's land, without a full size spare.FWIW, assuming you’re going easy when off-road due to all the expensive gear you’re carrying in the truck, I would personally be very comfortable running without a spare on HD tires if I was carrying plugs and a couple bags of Glue Tread. The likelihood that you’re going to have a failure seems low. The likelihood that you’ll have a catastrophic failure you can’t patch more easily than you can swap the whole wheel out seems very, very low. Again, assuming you’re not doing very high speed over big rocks gardens.
That said, have you considered a tailgate mounted spare as another option? Like this type of thing: https://www.rigdsupply.com/products/rigd-ultraswing-mega-fit-spare-tire-hitch-mount
Even with a trophy hitch I wouldn’t carry a spare under my bed off-road if I was going into situations where I could expect to get a flat and I was counting on the spare to get me home.![]()
Sounds like you’re saying it’s all or nothing for you. So just tally up the full cost with a trophy hitch and decide whether you want to pay for no compromises or not.If I am going go move up to 37s, it'll be done the right way without comprimising any advantages, rather gain one.
