I've never seen the Trophy Hitch for less than $2950 and that's with a 5% discount.
Are these steel welded plates we’re talking about or precious metals?Where do you see a Trophy hitch for $2500??? I’d buy one today for that. Seriously. We actually talk about the spare size a lot. Trophy hitch is the answer.
They’re welded plates…. But they say Carli! That’s why I asked where they were $2500. I think most places I see are $3150.Are these steel welded plates we’re talking about or precious metals?
... I have seen some windows get pretty scratched up from sand/mud when using the window after driving on a wet dirt road - hunting season type of stuff. Ford windows (front) seem to have some good crud catching abilities. ..
Yeah this is how I’ve been driving my current truck the last 9 years. 35’s without a full size spare and plug kit/compressor.Any seasoned mudder knows you can't just swing by the drive-thru for a Big Mac after tearing through a field or mud road.
I managed to pressure wash the front windows until they were dirt free, then rolled down the windows while they were still wet to clean out the crud catcher felt. The real challenge was the rear windows—you can't roll them down enough to access the felt wiper, so cleaning those took a lot more time, carefully maneuvering the rag between the window and the felt.
Regarding wheel weights, the 37x13.5r20s (around 80 lbs) with a +12mm offset from Black Rhino (approximately 52 lbs) didn't seem to impact acceleration or deceleration much (2021 6.7). I'm only using a 1.5" spacer with F450 front coils; everything else is stock except for the shocks, which really made the biggest difference. The Fox DSC shocks offer the ability to fine-tune exactly how you want the ride to feel, balancing between planted and soft.
Also, I don't have a trophy hitch. If I get a flat in the rear that I can't fix with my plug kit (another essential tool), then the 35" spare goes on the front, and the 37 is rotated to the rear. I can then drive home at 75mph without limping, just looking a little tweaked from the front.
View attachment 145090View attachment 145092
I have had 37’s for 40k miles and love them.
That aside, I keep the 35” spare. Correct me if I’m wrong, but would it do damage to run the 35” spare for a distance on the front (non drive) wheels, if in 2wd? My understanding is the biggest concern in having mismatched tire sizes would be if they were in the drive axle.
Many AWD cars also do not have full sized spares and are able to use the smaller factory spare for reasonable distances.
In my experience, a full-size spare is essential but carrying it at all times (i.e. having a trophy hitch) is not.
When on the road, I keep my spare at home and carry a plug kit, sidewall patch kit, and cordless inflator. I'm confident that these could get me moving again in almost any situation I might encounter on the road. That said, it's extremely unlikely I will get a flat on the road with such beefy tires (NRGs in my case.)
When off-roading, I put the spare in my bed. The reason I need the spare off road is because flats off-road often lead to or are the result of a bent rim. And there's no patching that.
And even with a trophy hitch, the spare should be riding in your bed off-road.
So far as the question in the OP, no regrets with 37s here. Even with the comparatively underpowered Godzilla, my truck has plenty get-up-and-go. And the stiff sidewall of the NRGs makes the truck feel far sportier than it did stock.
You could run it on the rear too if you wanted so long as you dont lock the dif, but I think its still preferable to be on the front (still cant use 4x regardless).I have had 37’s for 40k miles and love them.
Did you buy road hazard or buy from a TOYO driven dealer? If so should get a big chunk back on road hazardAny seasoned mudder knows you can't just swing by the drive-thru for a Big Mac after tearing through a field or mud road.
You can fit a cooper AT3 37" tire in the stock spare location if you deflate it. For me this is the best solution as I have onboard air already.I haven't gone to 37s because of the spare, that no one ever talks about.
I am not shelling out $2,500 for a trophy hitch to allow a 37" spare.
Winner!You can fit a cooper AT3 37" tire in the stock spare location if you deflate it. For me this is the best solution as I have onboard air already.
They do.It appears Yokohama does not make the MT Geolander G003 in an 18" rim
Evidently 5-seconds of search was not suffice.They do.
