Regrets going to 37s after Carli?
18,200 lbs. is for trucks with 8' box - 15,000 lbs. for Tremor for bumper pull - see attached for specs for F-250 - 350 - 450 - 2022 spec sheet below.
When I installed by Trophy hitch - all bolts and install points are the same - the Trophy hitch is more robust in structure to the OEM hitch, which showed 20k rating on my 2022 Tremor. I know the Carli is rated at 16k with no flex - so it should more than cover the 15k max for the Tremor.
Fair enough, I'm looking at the 23-24 guide, and the ratings have been upped a bit.
I just wish that the Carli hitch would retain the use of the factory cable lower/raise assembly versus the ratchet strap.
It does still use the factory cable/winch to get the tire back up in position, AZsurveyor asked the same question just a few posts ago... the ratchet strap is secondary retainment since most 37-38" tire/wheel combos are considerably heavier than the stock wheels and the assumption is you'll also be bouncing around more offroad it you run one.
It does still use the factory cable/winch to get the tire back up in position... the ratchet strap is secondary retainment since most 37-38" tire/wheel combos are considerably heavier than the stock wheels and the assumption is you'll also be bouncing around more offroad it you run one.
Ok, that's good to know.
Carli hitch "does" retain the factory cable lower/raise assembly - the rachet strap is an "extra" measure they add to provide stability for the weight of the spare for "spirited" off roading - rather than just having it held up by factory cable - so it is a better set up overall.
Well if going by looks the build quality is awesome. Cant wait to install.
Carli Back Country going on 2024 F250 7.3 Tremor with 37x12.50 Toyo At3
Now to get the dang truck.
If needing raceline, method wheels or carli suspension I can drop ship to you!😎😎
I have put 30K miles on my Carli Backcountry with 37x13.4R17 set up. Running Nitto Ridge Grapplers, not a single issue. Full size spare in the bed with a tonneau cover and stand the spare upright with some tie downs when I need the full bed length. I would like the trophy hitch but cannot justify the cost. Go for it, you won't regret it
I think the other thing to consider is whether or not most of you he-men could get that heavy wheel/tire out of the bed and mounted out there in the wilderness. Haha
lol true. Thank god for pro eagle jack and a shovel. Been there.
I’ve got almost 10k miles on my Carli commuter level and 37x13.5 17 wildpeak rt setup
I absolutely love it for highway driving. My dad who is a classic “if ford wanted it to do X they would have made it do that” type even says how nice it rides
Only issue so far is the tires. Took my truck out to Breckenridge this last week and the RTs are definitely not snow tires. Needed 4wd just to pull out of the driveway with 2 inch of powder.
Can you message me I have questions about Carli?
Totally! I used to run a 37x 13.50-20 up on a roof rack on canopy of my super duty with a lift and 37’s and it was a chore to get it down🤪
