Has anyone with the 7.3L gas found an extended tank? Everything I find is only for diesel.
No. However, following is my 2 + 3 = __ answer. You can fill in the blank after reading my comments. In early 2020, I looked up the Ford OEM fuel tanks for both diesel and gas trucks using VINs from 160 WB trucks listed for sale on CarGurus. SAME Part Number, which indicates the diameter / size of the opening for the pump / sender assembly is the same.
After that, I called S & B and talked to an engineer to ask questions. During the conversation, he stated there is a lot of government red tape obtaining approval and very expensive. I mentioned extra capacity fuel tanks for gasoline engine trucks were available back in 2007 and prior years. Why not now? He stated the CARB and other EPA emission regulations along with DOT safety concerns of gasoline being more volatile (combustible) than diesel fuel. He was very cordial and informative. On the other hand, a couple of my questions he responded by saying "no comment"...which in turn basically answered my question on whether the tank they market for "diesel engine" trucks...would actually work in a gas engine truck. After my conversation with the S & B engineer, I would fill in the blank above with the number 5...but, I could be wrong. To say it plainly another way, I think the diesel fuel tank marketed by S & B would actually work in a gas engine truck.
Although other questions inevitably pop up.
1. What about the internal baffles...the same or different between diesel and gasoline tanks?
2. What about the capacity and size of EVAP canister required? In other words, is a larger EVAP canister needed to support a larger gasoline fuel tank?
The safety / volatile concern is also seen in all the aftermarket "auxiliary fuel tanks". Evidently, it is OK to use a "transfer fuel tank" to transport and transfer gasoline, but it is not OK to use an aftermarket auxiliary fuel tank whether gravity or pump fed to supplement gasoline fuel capacity.
There is a thread on this forum with information about Transfer Flow...a company in California...a tank for gas engine trucks now in R & D and possible production. The Transfer Flow tanks are made from steel, while the Titan and S & B tanks are made from High Density Cross Linked Polyethelene. (XLHDPE).
