ajos0512
I have as well, twice, with no response back from s&b.Dang. I just submitted a contact form to S&B asking for a response. I have to use the big rig pumps on my fleet card to get the deep discounts.
Right - it does work but only with very little pressure and you gotta stand there and hold it. Annoying.I think you can use the pumps, just don't have them on the full flow.
This is definitely a good piece of information to know. Right now this makes me lean towards not getting the s&b tank.Right - it does work but only with very little pressure and you gotta stand there and hold it. Annoying.
Have to agree, this should be stated by them in their manual. I was thinking of getting this tank as well.This is definitely a good piece of information to know. Right now this makes me lean towards not getting the s&b tank.
Just ordered a 2022 Tremor, and may add consider the S&B install. I don’t think you can go wrong with the S&B.Did you make a decision on S&B vs Titan? I've been researching (have a 40ft fiver I pull) and would like the extra capacity. I'm leaning towards the S&B.
We are referring to the nozzles for diesel fuel that you typically find at truck stops. The nossles are about twice as wide and pump fuel much faster. My preference for fueling when possible.I have no idea what you guys are talking about with this pump
business. All I know is that my S&B has been flawless and it
provides extreme accurate readings for Distance Til Empty.
I pulled into a station with it reading 11 miles til empty!
Hey, I don't claim to be the sharpest tool on the bench, although
there were extenuating circumstances.
This is a deal killer for me not working with high flow! Why have a 60gal tank if the high flow doesn't work. Trying to fill a 60gal at a normal stop would take forever and probably involve multiple sales at the pump. Not to mention the time the 60gal tank would be the most convenient to have is on the interstate pulling trailer and truck stops are the best fill up options.They do mention it in the "before you start" section of the install:
What I liked about the S&B is that they also include an additional skid plate to cover the added tank length. I may be wrong, but I did not see that Titan added an extra skid plate. Also there is about a $800 price difference...This is a deal killer for me not working with high flow! Why have a 60gal tank if the high flow doesn't work. Trying to fill a 60gal at a normal stop would take forever and probably involve multiple sales at the pump. Not to mention the time the 60gal tank would be the most convenient to have is on the interstate pulling trailer and truck stops are the best fill up options.
Guess I'll look into the titan and see if has the same issue.
I think im going to do the same. This sure would be handy with the camper.Just ordered a 2022 Tremor, and may add consider the S&B install. I don’t think you can go wrong with the S&B.![]()
im expericencing the same issue... and im stuck holding it at 1/4 pump throttle.. its about the most annoying thing everAnyone figure out a way to keep the high-flow diesel pumps from shutting off after installing the 60gal s&b? I can only imagine it’s b/c of the check valve in the filler neck. Annoying!
It doesn't include an additional one and I don't think you can even use the factory skid plates on it.What I liked about the S&B is that they also include an additional skid plate to cover the added tank length. I may be wrong, but I did not see that Titan added an extra skid plate. Also there is about a $800 price difference...
The S&B does yes, I believe he is referring to the Titan.I believe my factory skid plate went back on without any probs.
