S&B 60 gallon fuel tank
That’s what I’m talking about! The only problem
is that I might need to spring for a bigger bladder.
I just stop every 2 hours at the state rest stops ... hit the head and am on my way in about 5-10 minutes ... good to stretch on long trips!
For those of you that have replaced your fuel tanks, what did you end up doing with your stock OEM tank?
I put mine in preservation( fogged the tank and sealed all the ports.) its now in the attic with all my other stock parts.
Does anyone have photos of the S&B tank showing how much lower it hangs compared to stock? Perhaps before and after photos of the install?
Here's one of mine installed. Sorry, don't have a similar before pic.
Found a before pic but not from the same angle. I think it's only 3/4" lower but extends towards the front quite a bit.
I installed an S&B in my 21. Couldn't get the truck in my shop at the time so I did it in my driveway. Took about 2.5 hours going back and forth for tools. I've been really with mine so far.
A must have for hauling long distances.
Got mine installed last week and updated the tank size with FORScan. I’m liking it and it will make life a lot easier when trailering the RV. Moving from an overlanding build to RV-centric build, I didnt mind the slight loss of ground clearance.
It's no more than inch lower.
View attachment 44463View attachment 44464
Very cool! 1,000 miles to empty would be a dream, especially with the RV!
the extension blocks that the stock fuel strap are mounted onto are 1.75"
Yeah, you can't use the high flow.
Wish I would have known that in advance. I likely would have “skipped” that install step and just not planned on ever rolling the truck over! Too late now because the filler neck was a PITA to attach and I don’t want anything to do with doing it again!
Yes - pump shuts off as soon as the flow starts at high velocity.
Dang. I just submitted a contact form to S&B asking for a response. I have to use the big rig pumps on my fleet card to get the deep discounts.
I'm surprised that little check valve would cause the high flow pump to shut off - I debated putting it in when I installed my tank... Anyone remove it and have the high flow pumps not shut off? Manually hold the pump handle to reduce the flow to a point it doesn't shut off? I have to do that on my '97 Powerstroke when using some high flow pumps... No choice but to use the semi lanes on the interstate (unless the station has an RV lane) hauling my Momentum 5th Wheel...
