S&B 60 gallon fuel tank
Installed my S&B 60 gal a couple of weekends ago. It’s awesome quality and was a pretty easy install for me and my son. Hadn’t reset the trip since then, so I did yesterday to see if the actual miles come close to what the
lie-o-meter says. Currently showing 1006 after driving 103.7 miles back and forth to work today. The mpg calculation is using 18.3 not what Trip 2 is saying. The 18.3 is what is showing up on the the Fuel Economy screen. Also using Eco mode really helps my mpg.
Does the truck sit any different with the added weight to one side ?
"Does the truck sit any different with the added weight to one side?"
Not if you're proactive and balance it with extra beer!
Consider that the difference is a puny 175 pounds or so.
Chump change for a Tremor!
I usually carry a tapped keg in the passenger seat. That should even it out I guess
Does the OEM bash plate cover the S&B as well as it does the OEM?
Yes the stock one fits perfectly and they provide one to cover the new extended part of the tank.
I don’t have a lift, so I used the strap method as well and still had a 1/4 of fuel in the stock tank. To me the biggest pain in the ass was the filler and vent tubes. I struggled to get the clamps loose. That probably took me 30 minutes at lease to get the clamps loose. Then I struggled to get the rubber Hoses off the metal portion. I got frustrated and came into the house to YouTube it. 2 minutes after I came in my son came in with the metal tubes. He just pulled them straight down kinda leveraged them off the rubber ones. I wouldn’t have tried that thinking I would break something. Putting back together is equally a PIA. We used a bit of Vaseline on them and he did basically the opposite of what he did to remove them. Other than that it’s pretty straight forward. FYI on my 2021 I only needed to change the IPC for the tank size. The spreadsheet says you need to change the PCM as well, but I did not.
This is great detail on your install. Thank you. I'm sure there will be a few difficulties (there always are with things like this).
oh - 1 question - sounds like your truck was on the ground. You were able to slide the old and new tanks under the truck without lifting it at all?
Has anyone with the 7.3L gas found an extended tank? Everything I find is only for diesel.
As far as I’m aware, no. Transfer Tank has now approved a project to design and produce one, but expect it to take some time (months, possibly over a year) before it hits the market.
Yep, truck was on my driveway. No issue either way.
Just a quick update - after a month of waiting for my tank I finally tackled the install yesterday. It was pretty easy and straightforward. I did the install with the rear end jacked up (with 2 jack stands) and implemented the straps method to lower and raise the tank. It worked very well.
The only difficulties I really faced were:
1) getting the filler and vent hoses off and back on (used some water based lubricant to get them back on more easily),
2) some of the bolts holding the OEM tank straps in place were very hard to get off. I broke the retaining clip that has the nut on it but was able to use a nut from Ace instead. There is loctite on those bolts.
3) getting the clips and hoses off the fuel filter/water separator was tricky while laying on my back, go slow
Other than that it was a pretty smooth install with lots of contorting to reach everything. The instructions that S&B provides (via QR code) were pretty easy to follow and honestly it's pretty straightforward to do the install.
I did siphon the remaining fuel from the OEM tank into the S&B before I installed it. I had maybe 2 to 3 gallons to transfer. When I started the truck it fired right up. Didn't seem to have to prime anything (surprising).
Last thing I'll mention - when I filled the truck at Costco I put about 55 gallons in before it auto shutoff. I was surprised to not get the full 60 or at least 57 or 58 into it as I was down to 8 miles to empty left. I did do the update to the IPC via Forscan.
I thought it was actually 57 or 58.
If I had to guess, this is likely reserve fuel on behalf of the truck. Pretty sure the gauge can read 0 miles to empty but you'll still have some range left.
Costco’s around here don’t sell diesel, you are lucky.
1 of the 4 has it and they recently added it, like 2 years ago maybe. Unfortunately it still has a charge cap of $150 so not enough to fill the new tank at current prices here. On a side note - I got a TSD Logistics fuel card to fill up at the truck stops. Much higher limits AND fast filling (but farther away). :)
Put a S&B 60 gallon tank on my KingRanch a couple of months ago. Taking old tank off is a one man job if you use the hang straps and make sure your tank is down to 6 gallons or less. Putting back up with two people is the way to go. Put S&B tank on your reused skid plate and place two jacks under skid plate for support and slowly pump up tank while the other person guides it into place. It is very easy to do. The S&B site has changed the video of the install in the last month and they changed how to replace the pump assembly and the filter. That makes things much easier because many people have broken these four fuel line connections which believe me don’t disconnect very easily. That was the only real challenge with the install so now no problems at all.
Tank comes with new skid plate for the front and you reuse your old plate using provided one inch spacers. So tank sticks one inch lower than the old one.
Make sure you lubricate the new rubber o-ring.
Make sure you do the leak test they demonstrate.
Make sure you zip tie the long fuel vent hose above the tank.
Doing those steps will guarantee you have no leaks.
Use forscan to reprogram tank size. They will send you device and talk you through it if you don’t have forscan or know how to use it.
I can’t say enough about their customer service. You get calls when shipped and also after the install asking how things went and if you have any problems etc.
So to sum things up I think the S&B tank is the way to go and yes you can do it yourself ( with a little help from a friend raising it) with out much problem. With the $500 you save buy yourself a few tanks of gas, and trust me you don’t need a so called professional to rip you off on this one.
With plans to pull our travel trailer on long distance trips I have been toying with the idea of having this 60 gallon tank installed.
Has anyone installed this 60 gal tank on their Tremor? I am wondering what Ford or a reputable shop would charge to install it?
Naturally I would want to have it installed by a shop that has done multiple installs on the SD.
The guy in this video makes it look fairly easy. Thoughts if you have installed this product?
Here is a pretty cool install video -
Does anyone know if they make a 60 gallon tank for the gassers?
Basically how I did it but I only had about 3 gallons of fuel in the old tank that I transferred into the new tank. I was able to raise it mostly into place with the straps, push it up with one hand and secure the screws. Once they were in I torqued them. I'm not sure it would have been easier with a friend as there's not a lot of room under there unless you lift the truck (I lifted the rear only). I think the key is having very little fuel.
But I agree - it's easy and def not worth $500+ to have someone install it and probably not do as detailed a job as you'll do yourself.
One thing I will note - and I'm on my first tank still - when I filled up I was at almost 1000 miles to empty. I'm at about 800 now, having traveled about 150 miles. The discrepancy is not weird to me - I know it fluctuates based on how I drive. What I do find odd is that I know I've used at least 10 gallons but the gauge shows only about 1/8th of the tank used. It seems like the gauge is reading high. I'll watch it and see over the week how it does.
My gauge is just like yours it takes awhile to start coming off full. My other tank did the same but didn’t take as long. I assume it is just because it has more fuel.
