S&B 60 gallon fuel tank
Was thinking about this today whether my dealer would install it.
Probably not but I will ask.
I have a Titan 55 In my 2020 F250. I had a Tundra with a transfer flow 46 before this. Both trucks had a driver side slight lean when tanks are full. The only thing I can think of is the extra weight. If you didn‘t notice it before and do now I’m sorry as it can really mess with your OCD!
Did you make a decision on S&B vs Titan? I've been researching (have a 40ft fiver I pull) and would like the extra capacity. I'm leaning towards the S&B.
I thought the S&B have problems and the titan was flawless. IDK ?‍♂️
I was thinking going this route also and again I thought more complaints with S&B.
I would love to hear more reviews
Not yet, I have put it on the back burner for now. Still something I am considering and have been researching a few shop(s) in the area that have plenty of experience installing the S&B or Titan. Jury is still out.
Great point @KrazyCajun, hmmm?? Not so sure I want a drivers side “gangsta lean” with a larger fuel tank, my OCD would severely struggle with even a slight lean.? Thanks for posting. ??
I have the S&B 60gal & transfer pump sitting in the bed right now, hopefully going to install later this week...
They called yesterday following up and asking if I had any questions or troubles with the tank and if I needed help setting up the distance to empty... pretty great customer service really.
I wouldn't think another roughly 160 pounds of fuel would cause an even measurable lean in a rig with a 3000+ payload. Plus it isn't that far outboard from the centerline.
I’ve been wanting to do this also. Do a lot of RV’ing and need more gas! Has anyone called their local Ford dealer and ask if they would install and how much? I would do it to but without a lift it’s not doable for me.
The gas tank is a much bigger deal and sadly no option exists for it right now.
I had the S&B 60 gallon tank put in my truck 2 weeks ago. It's awesome!
I dropped it off at a local shop and they had it installed 3 hours later. I didn't know I had to notify S&B that I needed their laptop for resetting the distance to empty. I called and they sent it to me. I couldn't get it to work so I called them. Camen facetimed me and he walked me through it in about a minute. I love seeing 1200 miles to empty. I'm not sure what the ground clearance was before but right now its 14".
Highly recommend this tank. S&B has been great to work with and I have had ZERO issues.
I don't get it, is there a puter chip on the S&B tank that has Bluetooth that you send a wakeup call or something to?
And it must connect to the truck's ECM, right?
I believe its for the ford computer to recognize more gallons of fuel and give you the correct readout on the gauge. I think you can do it via forscan as well.
I get that the ECM needs to know there's a bigger tank. I'm just trying to understand the actual process.
I'm highly doubtful a dealer will do it.
It does not have any computer chip or bluetooth in it. I just needed to update the truck computer to show the correct distance to empty. You can use FORSCAN. I did not have FORSCAN so they sent me a laptop with with it already programmed to change my DTE. All I had to do was open the file on the homepage and click ok. Very simple process.
They sent you a whole laptop? ?
How can they do that for every tank they sell?
Sounds like I can fuggetabout having mine installed at
Bubba's Shade Tree Garage.
for those of you that put the 60 gallon tank on, what did you do with the original fuel tank? If you sold it, what did you get for it?
I have titan tank on my 2007 f250 and previous 2004 f250. They are awesome tanks, never had any issues or leaks. They both seem to very good quality products. For these 2021's, I will look further to determine if the $1200 price is worth it over the long term. For me it's about the Ford warranty mainly. Not too concerned about the extra 160 lb or so weight taking from the payload. 34 gallon tank on these trucks is not too bad, especially if you have patience, you could probably get an additional 4 gallons in the tank. I look at it as while your traveling, your usually stopping for every 200 or so miles for a break, opportunity to get more fuel. Personally I only stop at big truck stops when we are traveling.
I will wait until I get a definitive answer on the warranty question.
