S&B 60 gallon fuel tank
I have a Titan 55 In my 2020 F250. I had a Tundra with a transfer flow 46 before this. Both trucks had a driver side slight lean when tanks are full. The only thing I can think of is the extra weight. If you didn‘t notice it before and do now I’m sorry as it can really mess with your OCD!
I have the Titan also ... love it!
I bought the S&B tank in early January and it was backordered for a month or so.
When it shipped, besides the automated UPS email, I also got a phone call from S&B letting me know it had shipped and asking how I planned to have it installed and if I had any questions. They really try to make sure any questions or concerns are answered and taken care of ahead of time.
Once the tank arrived, I installed it myself. Took 3-4 hrs going slow and taking breaks to work and answer the phone. I ran my factory tank down until it had about two gallons in it and was going to transfer it over but decided to install the S&B tank empty and pour 5 gal from a container into it once done. I cycled the ignition a few times and it fired right up. Didn't skip a beat.
I used forscan to change the tank size and am now close to 1,100 miles DTE on a full tank.
S&B called again after a few weeks to make sure all was well, they and even offered to send a way to change the tank size in the computer.
No problems, no leaks, EXCELLENT customer service, and a great product as well.
Best mod I've ever done to any of my trucks.
That's great to hear. I'm getting ready to pull the trigger on ordering one and will be installing myself.
My only hesitation is what to do with the original tank. What did you do with yours? Not sure if there is much interest in it if I list it for sale.
Relentless, I'm concerned about scraping it while off-roading.
1. Does it really hang below the frame?
2. Does anyone offer a bash plate?
3. Hard do you think it would be to have one made?
I'm looking at the same tank, model is 10-1004. My understanding is that S&B developed the tank and mounts to reuse the stock skid plate on the rear part of the tank and they PROVIDE a front skid plate. I also found THIS VIDEO on Youtube for a 1-man install. Looks very doable.
Yes, see the video in my OP ?
I started to but I got tired after 30 seconds of watching him work.
So has anybody figured out if this could cause warranty issues?
I doubt I'll be able to sweet talk my dealer's service dept to do it.
If I have it done, I want the install done by a shop that does this install all the time all day long. Almost like they could do it blind folded...well...not blind folded on my truck, but you get what I mean.
I doubt Ford would install it, but they might.
I had my S&B installed by a shop that does a lot of both Titan and S&B tanks. It was worth the $500 to me. Really happy with the tank so far.
I started by looking at the reviews online for my local diesel shops, then I emailed several about the install/quality of the tanks, I followed up with a phone call to the final two and asked about the tanks and how many installs they had done, how long they had been in business. Then I asked my local dealership about them. Sounds like a lot as I’m typing but it really wasn’t.
Just got a quote from a reputable diesel shop of $500 to install an S&B, including reprogramming the puter. Sounds a little steep for a 3-4 hour job but they are reputabl.
With plans to pull our travel trailer on long distance trips I have been toying with the idea of having this 60 gallon tank installed.
Has anyone installed this 60 gal tank on their Tremor? I am wondering what Ford or a reputable shop would charge to install it?
Naturally I would want to have it installed by a shop that has done multiple installs on the SD.
The guy in this video makes it look fairly easy. Thoughts if you have installed this product?
Here is a pretty cool install video -
I must be getting old as I welcome getting out of my truck and stretching my legs at least once every 3-4 hours.
I hear ya, I like to stretch as well after a long drive of 3-4 hrs. Just not at a gas station having to refuel. ??
Installed my S&B 60 gal a couple of weekends ago. It’s awesome quality and was a pretty easy install for me and my son. Hadn’t reset the trip since then, so I did yesterday to see if the actual miles come close to what the
lie-o-meter says. Currently showing 1006 after driving 103.7 miles back and forth to work today. The mpg calculation is using 18.3 not what Trip 2 is saying. The 18.3 is what is showing up on the the Fuel Economy screen. Also using Eco mode really helps my mpg.
That's great to hear. I have my tank sitting in the box awaiting time to be installed. Any tips you think are worth mentioning? I watched a youtube video on the install, looks pretty straightforward. Will try the ratchet strap technique to lower the old, raise the new tank. Plan to change out the fuel filter at the same time (have 10K miles on the truck).
Does the OEM bash plate cover the S&B as well as it does the OEM?
I don’t have a lift, so I used the strap method as well and still had a 1/4 of fuel in the stock tank. To me the biggest pain in the ass was the filler and vent tubes. I struggled to get the clamps loose. That probably took me 30 minutes at lease to get the clamps loose. Then I struggled to get the rubber Hoses off the metal portion. I got frustrated and came into the house to YouTube it. 2 minutes after I came in my son came in with the metal tubes. He just pulled them straight down kinda leveraged them off the rubber ones. I wouldn’t have tried that thinking I would break something. Putting back together is equally a PIA. We used a bit of Vaseline on them and he did basically the opposite of what he did to remove them. Other than that it’s pretty straight forward. FYI on my 2021 I only needed to change the IPC for the tank size. The spreadsheet says you need to change the PCM as well, but I did not.
