I just have the dealer do it. I don't have to mess with this nonsense.
One less thing to worry about.
I've not changed my own oil in at least 35 years. It's their problem if they screw it up.Till you need to change your oil and have to get out a impact to back out your oil pan drain plug.
I wonder how much dealerships are charging for a 15 quart oil change on the HO 6.7 right now?Luckily I've got ~50k more miles to worry about that on both vehicles. Prepaid service plans.
5W40? Did you use rewards points or have a discount code because it’s showing $145.Order triax online, I just bought 4 gallons for $115 with free shipping.
You say you don't want to cause panic buying followed up by immediately suggesting people start panic buying.
Regardless of the motor...if you don't have on-hand 2-3 oil changes worth of supplies I'm not sure we can be friends.![]()
$145 seems normal. Usually they run a 15% off every couple months. Labor Day was the last. Waiting for another.I might have had a discount/promo code at the time. $145 is what I normally pay though. Still a good price.
We balance each other out, then, because I've NOT let someone else change my oil in 44 years since I learned how at age 10. Got a 80cc dirtbike at 10 years old and haven't had anyone change the oil in a vehicle ever since.I've not changed my own oil in at least 35 years. It's their problem if they screw it up.
I've got enough oil and filters on hand for about 18 oil changes...does that mean we're best friends?Regardless of the motor...if you don't have on-hand 2-3 oil changes worth of supplies I'm not sure we can be friends.![]()
Proud to say I have never paid for an oil change in my lifeWe balance each other out, then, because I've NOT let someone else change my oil in 44+ years. Got a 80cc dirtbike at 10 years old and haven't had anyone change the oil in a vehicle ever since.
That being said, I will reluctantly admit that I let someone else do the bearings on my tandem axle trailer a couple years ago when I was pinched for time.
adding to your statement...The Motor Oil Geek warned of this back in April after the Shell plant in Qatar that makes a lot of base oil... for the world... was knocked off line by the Iranians.
I took his advice and stocked up then.
Whats wrong with running the 15w 40?Amazon did not have 5w-40 Rotella T6 but plenty of 15w-40 at a reasonable price. It took me 3 trips to Walmart to find 5w-40 in stock. $33 a gal![]()
