Oil Shortage is a Real Thing
If you are needing to use a heater on a flash bang engine, there is something else going on.
My bad. Not a need, but a want. My mistake was reading a book written by an SAE automotive petroleum engineer AND HE SAID (lmao - it's just another opinion, I get it) that any time you can start a cold engine with just that --->||<--- warmer oil, it's a good thing. That's all.
Meaning, I wanted to order a truck w/ a factory block heater but was too late to do so for a '25, then found one already built and in local inventory.
Gotcha. Whew. You had me head scratching.
For craps and chuckles, I’d like to see a Cst chart that shows the kinematic viscosity change between 30*f and 0*f on the oil. Then, the difference in engine oil temperature between the oil when using/ not using a water jacket heater.
I bet it’s not much. Water jacket (“block” heaters) don’t warm the oil except what lays in the valvetrain above the heater.
What you would want is an immersion oil pan heater. Also one in the transmission pan, transfer case and differential. Folks forget that the engine heater (immersion, water jacket, magnetic) only heat a very small portion of the moving parts.
Yes.
A fella has to start somewhere, and when I saw the option for factory-fitted block heater I wanted that.
Just ordered 5 gallons of Motorcraft 10-W30 from Walmart. $26.97/gallon. Should be delivered this afternoon. Its $36/gal at Advance Auto or O'Rielly's if you can get it.
I had an oil change scheduled for my truck for next week and the dealer called and said they don't have any oil in stock and will let me know if they need to cancel.....
Anyone else seeing or hearing this? Specifically in So Cal....(yes, I know)
I hope you are changing your oil ahead of the recommended frequency, allowing some extra miles to be put on without harm while you wait for the dealership to get oil in stock.
Just one more reason to do this yourself and have a supply on hand.
Those are 1.25 Gallons so 5 QTs each. You should get 1 more and have 2 complete oil changes.
Edit:
I just ordered 6x myself and 1x filter as I already had an extra one.
I have been looking for 4 gallons of T6 5W40 for my upcoming oil change.
Sams, Walmart, Autozone etc have been out of stock for months.
I did buy 3 gallons of 10w30 T6 when I came across it.
I finally found T6 5W40 at my local Napa, $165 for 4 gallons, which really sucks.
I came across something about Rotella going thru new oil spec certification, I hope that is why the supply has been limited. My wife works for 1 of our 3 local Wal-marts, she logged into her system, it didn't show any incoming T6 for the foreseeable future.
Ok,
If you choose Napa, and have never bought online from them, they sent me a 20% off $125+ moments after I placed my order. I might use it to buy another 4 gallons of oil for my next change. So maybe place a small initial order to see if they will send the coupon code after initial order.
Back when i owned a diesel, i dont think i ever bought rotella WITHOUT some form of rebate.
Always found them here: https://www.atwoods.com/mfg-rebate-forms/
I noticed my local Tractor Supply is out of the T6 5w40 over the weekend. Interesting.
Over the past 3-4 weeks, I have looked at Menards, HD, Meijer, Wal-Mart, all the larger stores in my area. Sams doesn't even list it available in store anymore.
I hope they flood the market soon with the new spec. CL-4/FB-4 (01/01/2027)
The pearl refinery in the Qatar was struck and has suffered extensive damage and will not be back to full capacity sometime in 2027. That plant, owned by shell converts natural gas to liquids, that’s why 5w40 t6 is out of stock, you will also notice that penzoil ultra platinum has quietly removed the “made from natural gas” label from its bottles.
Here are a few options for you… order and have at your door by the end of the week.
Just ordered 5 gallons of Motorcraft 10-W30 from Walmart. $26.97/gallon. Should be delivered this afternoon. It’s $36/gal at Advance Auto or O'Rielly's if you can get it.
The shortage is effecting rotella t6 5w40… everything else is still around.
With that TRIAX stuff are people really doing 25k Oil changes?!
I wouldn't by anything from Walmart online.
All 3rd party sellers and a few people have gotten counterfeit filters from them.
I bought in-store for the same price. Also bought a motorcraft filter at the same time. Will compare to a dealer-purchased filter. I will post any irregularities i find.
Any more details you can share on the counterfeit filters . . .
People are running extended drain intervals with quality synthetic oils with testing and proper filtration. Unless you are testing your oil and running quality bypass filtration, change your oil and filter every 5k.
