You hitVery illegal in NY also....more illegal than real crimes at this point
?? Hit the nail on the head?You hit
yes lol?? Hit the nail on the head?
I've nearly been killed on my bike while commuting more times than I can count by folks with a phone in there hand while driving. Unless it's a dire emergency the phone needs to be put away while driving.Remarkably, my phone works just fine when I hold it to my ear to talk. Did the same thing in my prior truck, believe it or not. I must have gotten one of the good ones.
If we're just referring to talking on the phone, then you'd have to go out on a pretty long limb to make the argument that holding a phone to your ear to talk is somehow more distracting than talking to air via the truck's speakerphone. The infotainment systems in modern cars are many, many times more distracting than either of those activities.I've nearly been killed on my bike while commuting more times than I can count by folks with a phone in there hand while driving. Unless it's a dire emergency the phone needs to be put away while driving.
I tried this, and it didn’t make any difference for me. Would you mind letting me know if you simply turn the microphone off to each app and then restarted your phone or if you did some type of reset to your phone? I turn the power off and back on but I didn’t try to reset the phone.I was experiencing same issue. People can't hear me when i call them while connected to CarPlay. Went to microphone settings on iPhone, turned off microphone to all apps, rebooted phone and now it seems to have eliminated the problem.
Same for me Bluetooth works well but out going volume on carply much lower....My family told me that my microphone level was normal if I used Bluetooth for the call and only bad if I used CarPlay.
I drove a new loaner F-150 while my windshield recall was being dealt with and used wireless CarPlay in the Sync 4 system. It was awesome, sounded great, people could hear me very well and system response was far faster than what’s in my Tremor.
MB
Tried both, same result!Has anybody tried the standard USB and the USBc, does that make any difference?
This also seems to tie into the topic of radio issues where there is a Sync 3 updater to version 3.4.21098Yes, I have this same issue. Everything works spot on except the mic volume level exclusively when using CarPlay. There are other forums about this issue. After doing some research, it appears that certain Sync3 builds have a software glitch that causes this problem. Some people have had success with downgrading their Sync3 build to an earlier build that is known to work correctly with CarPlay. I called Ford Customer Service and they told me they had hear of the issue and they suggested I don't use CarPlay for phone calls. Thanks A LOT!!!! I don't really want to downgrade my Sync3 but the only other choices are to disconnect CarPlay for phone calls until they release a new update for Sync3. That could be a year from now and even then we don't know if it will fix this specific flaw. My truck has Sync3 Version 3.4 Build 20196. I've read that Build 19101 works correctly with CarPlay. There is a Ford Ranger forum that talks about how to downgrade. I haven't tried. View attachment 13649
Looks like this is not applicable to 2020 or newer systems. In the video, and the docs, they state that you can brick the Sync if the vehicle is 2020 or newer:This also seems to tie into the topic of radio issues where there is a Sync 3 updater to version 3.4.21098
Syn3 Updater - CyanLabs
Syn3 Updater is a Windows application that will make your life easier when attempting to update your Ford SYNC powered car to version 3.4!cyanlabs.net
docs.cyanlabs.net
