+ 1 for no seat heat after remote start activation until I push the engine start button. I was also seeking resolution on another forum and based upon the responses there and here, this appears to be all over the board.
Rig: 22 F350 Limited, 6.7 PSD, CCLB, SRW
Built 9/2/22 (MC seat delete)
Dual Climate Control w/Heated/Cooled Seats and Heated Steering Wheel
Outside Temp this week during testing <30ºF, rig parked outside
Remote Start Setting: Instrument Cluster menu: Settings/Vehicle/Remote Start/Climate Control=Auto; Setting/Vehicle/Remote Start/Heated Seats Steering Wheel=Auto; Setting/Vehicle/Remote Start/Duration=15 minutes; and Setting/Vehicle/Remote Start/System=box checked
No FORScan changes have been made
Issue: No driver's side heat after remote starting the rig. Various tests I have tried this week and basically, remote start the rig, let it run for 10 min or so. No heat felt by hand on driver's seat. Steering Wheel is warm. I've tried "auto setting" and "last setting" etc., and neither makes any difference and still no drivers seat heat. What is puzzling me, is when I jump in the cab and push the start button, I can feel the seat starting to warm up after 1-2 minutes. Also when driving out and about, and I engage the seat heat, I can feel it get warm pretty quickly.
22 F350 Manual: Reviewed manual, page 146-147, and everything I am reading seems to suggest after remote starting the seat should start to heat. Specifically, p.165 has a note that states "Note: The heated seats
may remain on after you remote start your vehicle, based on your remote start settings. The heated seats may also turn on when you start your vehicle if they were on when you switched your vehicle off." Not sure what "may remain on" means, but taken in context with other sections of the manual, I would think the seat should start to warm. If it was designed to not start to heat after a remote start, then
why have the settings in the instrument cluster menu? Makes no sense to me.
I'm a newbie to FORScan, but watched a few YT vids, so I configured PIDs in FORScan to monitor the temp of drivers seat back and seat bottom. Ran another test as described above, temp outside <30º, and let it run for 10 min, and then I pushed the start button, and as you can see from the graph from FORScan, seat stays at a constant temp around 52º (note I started this test after the heated was a bit warmer from prior tests), and then spikes right after I push the start button to 100º.
Local dealer had my rig for 4 days and could not figure it out and apparently the tech has reached out to Ford engineering for testing as the service manual apparently does not have a testing procedure for this issue. We shall see.
Just wanted to contribute to this thread with actual PID data for those that are experiencing this too.
