GVM = Gateway module (GWM?)
If so, I managed to get everything updated, GWM, APIM and TCM. FDRS reports no more updates available. Heated seat/remote start still no workie.
I'm curious now about temps -- in a truck where this works, the seats come on at a lower temp, then go full blast when you key on. I'm sure there's an ambient temp setting in one of the modules. I can't find that documented anywhere, so Jhforman is asking the right question -- what are the temp settings, and my question -- where the heck are they? Looked through the super duty spreadsheets, and Livinitups for F150 and dont see anything.
@georgia350plat sorry for the delay in responding, but the ambient air temp PID is pulled from the PCM PIDs. Screen shot of the PIDs I am using to test, PCM.AAT, SCME.SEAT_CSH_TMP_D, SCME.SEAT_BK_TMP_D, SCME.SEAT_CSH_TMP_P and SCME.SEAT_BK_TMP_P.
When setting up the PDS, you need to select "All" modules, then scroll down to the PCM and SCME modules and select the PIDs above.
I have tested this multiple times, well below 32*F (per for Ford Work Shop Manual that below 32*F will trigger seat heat. As mentioned above, I don't believe the Ford WS manual is accurate as some have reported their seats heat well above 32*F). My RS settings are Climate Control=Auto (options are Auto and Last Used) and Seat & Wheel=Auto (options are Auto and Off). Have run multiple tests with settings of Climate Control=Last Used, still same results.
The below screen shot was with ambient air temp of -4*F, well below the 32*F threshold, Climate Control=Auto and Seat & Wheel=Auto, and same result, no seat heat until PTS. I can't explain why the initial seat heat starts at -17*F, well below the -4*F ambient air temp (which I also confirmed the ambient air temp with a infrared thermometer). Would be great if someone here that uses FORScan to run some tests and post up their graphs to confirm readings.
Over on FTE, I have been collecting data and VINs, so if anyone has a MY22 and can confirm seat heat on RS prior to PTS/Key-on we greatly appreciate you providing me your VIN to compare module firmware and configuration. So far I have received 70 VINs and except for a few MY22 VINs, most have reported no seat heat on RS prior to PTS/Key-on. For the few MY22 VINs that have reported seat heat, we have not found a common firmware/configuration as of yet. Obviously a head scratcher.
Feel free to DM me here or on FTE (same user name on FTE) if anyone is willing to share your data and VIN for our tracking sheet.
