Featured
- #921
@BroncHo my DEF won't unlock when I stick the key in I cannot turn it either way to release the cap, any ideas or anybody else who's had the issue before?
Push down on the cap at the same time (if possible). I’ve not had this issue, but that may work.@BroncHo my DEF won't unlock when I stick the key in I cannot turn it either way to release the cap, any ideas or anybody else who's had the issue before?
Will be happy to get you squared away! Send your order # and I will send you a label.Have had the caps since release. Currently only 44 where I'm at in missouri. I was up in Illinois in negative 15° weather a couple of few weeks ago. But after gently holding cap and exercising the lock mechanism it released but not as it should have. Dark droplets did come out of the bottom and into my hand.View attachment 197509View attachment 197510View attachment 197512
Sorry I missed your mention, looks like the username was incorrect.@BroncHo my DEF won't unlock when I stick the key in I cannot turn it either way to release the cap, any ideas or anybody else who's had the issue before?
You are a class act! Greatly appreciated! Love your caps!Will be happy to get you squared away! Send your order # and I will send you a label.
Agreed. If you’ve not bought a set - you should. Thankfully, my beautiful wife hooked me up. I’m such a kept man. lol. Not!@BroncOh et all.
That was a Class Act response from everyone! All in less than an hour resolution! In under an hour I had a return label to get a new DEF cap! Thank you for being solutionary, what a great community!
Sorry, that's my other username. I sent him a PM with a bunch of chick pics but it fell on def ears
When I had my OEM water separator on at the time I never had any issue. The amount of fuel drained was the amount within the OEM plastic housing. If you're concerned with it, just drain one quart, then close the yellow valve.Question for all the people that have these caps (like me!). Has anyone had issues when draining the fuel/water separator to do a filter change?
In my owners manual, it sez this (on page 387 for the 2021 MY: "For 2018 models and later, skip this step but insure that the fuel filler cap is closed before draining the filter. Failure to close the fill cap results in the siphoning of the entire fuel tank contents when you open the drain screw."
Since the cap (for the diesel and DEF) is vented through an "open hole" (vs. a vacuum breaker), I was wondering if the diesel tank would be siphoned to empty when you attempt to drain the water separator.
Thanks...
