This weekend I also took 5 - 10 minutes to install the
Builtright rear seat release. It is a really simple mod to do and great to have the ability to lower the driver side seat easily. Although, you could just use the closed end of a wrench to access the pin, I like that this makes it quite a bit easier and the convenience factor.
I also installed the factory front license plate holder. Hopefully Ford (or someone else) comes out with one that will offset the license plate when I get the winch installed. Odd that Ford continues to sell the winch kit, but doesn't offer the the license plate holders for the 23+ model years.
Lastly, I added tubs under my Retrax cover to store a few items. Thanks to
@modified for finding these. They fit perfectly.
All of the following fit in one of the tubs:
HULKMAN Alpha100 Jump Starter 4000 Amp 32000mAh Car Starter
SUERCUP 1/2-inch Drive Torque Wrench - my regular Torque Wrench is too long to fit in the box, so found something shorter that would be good enough for when I need to change a tire on the side of the road
USB Rechargeable LED Road Flares Emergency Lights
SAFEMATE 3 Pack Warning Triangle DOT Approved, Foldable Emergency Safety Reflective Triangles
PITTSBURGH PRO 1/2 in. Drive 25 in. Breaker Bar
- I have a single 21mm thin walled socket in the kit right now, but want to add a set in case I need to help others with changing a tire. Appreciate any recommendations on a good set as the ones on Amazon don't seem that great (when reading the reviews).
- Factory bottle jack
I'm thinking of putting my BADLAND 3 Ton Off-Road Jack next to the container, but taking the wheels off is a pain to get the jack to fit under the cover and only one piece of the arm will fit in the storage tub under the cover. Trying to decide if I should forgo the jack unless I'm going somewhere offroad and use the second tub to store recovery gear (planning ahead for when I get a winch installed).
