Upfitter Switches, What are you using them for?
So far
1. Reverse lights on hitch
2. 40” curved light bar on grille.
I do not have upfitter switches, but a Switch-Pros 9100.
1) Compressor
2) A-Pillar lights
3) 2 x 6" amber light bars installed in grille
4) Rear bumper pod lights (bright)
5) Rear bumper pod lights (low-light)
6) Soon to come train horn
7) Soon to come front light bar on bumper
8) tbd
I am installing a second switch panel inside my truck camper. So, all of these are soon to come:
1) 4 x WIFI cameras
2) 4 x Flood lights for emergency situations
3) Train horn (for emergency situations)
4) Starlink Router (with POE)
5) Cell phone booster
6) Outside lights (low-level/mood lights)
7) tbd
8) tbd
@soulezoo
I second that request. I'd like to see pictures, hear about the gas transfer tank. The more detail, the better.
1) Radar Detector
2) Raptor Lights
3) Baja Fog Lights
4) ARB Air Compressor
5) Ditch Lights
6) Armored Ridgeback Hitch Lights
where are you guys grounding your stuff when using the pass through wires in the passanger kick panel area?
Depends. Usually you want to connect to chassis ground near your device, but if you run a harness to the battery you can ground there too. There is a chassis grounding screw near the passenger side fender next to the battery. Make sure your wire does not go through the CT. There are several chassis grounds inside the cabin as well.
1) Compressor
2) A-Pillar lights
8) tbd
1) 4 x WIFI cameras
7) tbd
8) tbd
So over the top. Wait, did that sound jealous?.🤪
So far
Which light bar did you install? Any photos?
If you are referring to the radar detector, I just grounded under the dash on the cab side. I did this awhile ago but I think there is a bolt in the passenger footwell that you can use and don't have to use a pass through for the ground.
I don’t think anybody would suggest using a pass through for a ground. Big waste
1. Z- Flash
2. Front/rear bumper side lights & auxiliary
back up lights
3. Fender vent lights
4. Amber fog lamps
5. Front bumper 36 inch light bar
6. Fender ditch lights
CORRECTION! 30 inch light bar #5
Me, directly to the negative battery terminal passenger side battery.
I hear you brother and completely agree, there are some on this forum who are new to the SD and with differing skill/experience levels so I am just making sure they know and trying to make life easier.
I see, trying to over sell those 6"
Hmmm, well was just going over my post, I saw 36", then realized 😳 no, no, no.....it's not 36". LOL
Care to share what gas transfer tank setup you have to include pics?
@soulezoo
I direct copied another member here on that. He posted some pics and I feel like he should get credit for the idea. I will find it and link here. Or just go out and take pics. 🤷
See this thread here:
This 42 gallon tank fits perfectly under my Diamondback cover. It's strapped in, not bolted, so if I need to remove it for bed space, I can in about 5 minutes providing it is empty. I used bayonet connections in the wiring for fast removal and reconnect.
