S&S Diesel 6.7L CP4 to DCR Conversion Kit
I'm also trying to find someone who has had a cp4 failure that was equipped with a DPK to see if the DPK was 100% effective as it's represented.
I have a feeling that those folks conscious enough to get a DPK never experience a failure with their cp4s. You yourself said many a times that most cp4 failures are operator error. It doesn’t happen to folks who are already invested in some protection and practice diesel fuel safety😉
Also those people will also be on top of maintenance and well aware of the other safe guards. But I'm still curious 🤔
The DCR makes plenty of pressure for the new commanded fuel pressure. There’s allot of videos online and posts in various forums about newer trucks, even 2024 HO 6.7’s with a DCR. Tech talk with AROD has lots of videos online this long with beared ford tech.
My truck commands 36k pressure or slightly more when worked hard. Would like to know what the DCR pump is capable of producing orher than “plenty”. I recon I’ll call S&S this week and see what its max FP spec is.
Regardless of the hows and whys and how many CP4 failures exist, I am curious about those folks who have installed the DCR pump on a 2020 and newer 6.7. I am aware that those with 2019 and older trucks have had good luck with them with no downside as far as power output etc. However, the 2020 model year brought increased injection pressure from somewhere around 28,000 to 30,000 psi for the 19 and older trucks, to somewhere around 36,000psi for the 2020 and newer trucks. I am aware that the DCR pump produces increased (and sufficient) volume for 2020 and newer trucks. But are the DCR pumps for 2020 and newer applications capable of producing the increased fuel PRESSURE called for by the newer trucks? So basically, to those with 2020 and newer trucks with DCR installs, have you seen any decrease in power or fuel mileage after the change? Injection pressure increase is one of the redesigns responsible for the power increase of rhe 2020 and up 6.7 trucks. I would argue one of the most important. When people mention that the DCR’s are “over” a certain percentage, that “over” is a function of volume, not pressure, from what I can gather. Also posted in the CP4 recall post.
I’ve had the DCR on my 2022 for a year now and have noticed no problems. My FRP has topped about around 37k. Zero loss in in power and no issues. The pic is before she lost weight. She does have pusher pipes and Banks BA filter done at this point.
Hey everyone. Finally got my DCR installed on my 22. Does anyone else who’s had it done hear a quiet but high pitched buzzing(humming sound) coming from the engine bay when the truck is off? Only started happening once the DCR pump went in. Disconnected the batteries and the sound went away but came back after reconnecting them. I’m at a loss here. The truck starts and runs fine. Also the sound lasts for about 2.5-3 min then stops.
Either the headlight fans, or the EGR valve. Sounds more like EGR valve humming, which is pretty normal. Should eventually shut off though.
Def not the EGR… but could be the fans thn. Never heard it before. Prob just never paid attention till now after putting the pump in haha. Love the pump though. Feels like I gained some pickup and the engines quieter.
Just finished installing the DCR on my truck. While I was at it I went ahead and installed the S&B cold side pipe and did the H&S upper fuel filter relocation kit.
Now you need the matching S&B hot side pipe. 😬
Only one worth getting.
The stock cold side pipe on my truck was very flimsy. I’ve seen a few crack. I replaced both with S&B, the hot side had a leak at the rubber portion near the pipe.
After doing the cold side pipe I now want the hot side pipe too. At first I didn’t think it was necessary but now I want it. As far as I know, the truck is officially “bulletproof” with the DCR swap, cold side pipe and tuned and deleted.
Following this thread and seeing others. Is there a general consensus that that is some sound form the DCR install that will vary based on timing alignment? I ask because I recently had mine installed and there is a "fan on" sounds is the best I can describe it when at idol or coming to light/stop as well as 1 sec after key off.
Can anyone tell me if all DCR pumps now sold are the new variant? As in Version2? I’ve been peer pressured to do one, so I’m going for it.
Contact S&S, the manufacturer. They answer emails within a few hours.
