S&S Diesel 6.7L CP4 to DCR Conversion Kit
Going on a few days since I had the pump installed. To the folks that have done the conversion, have you noticed more vibration at idle? My side view mirrors shake slightly like I am in a Class 8.
Other than that, everything else seems to be doing great.
Interesting. Maybe the pump gear timing is slightly off. @usafakid09
quickly coming up on 10k miles (Feb/Mar installed), I dont have anything like that. There is more noise that I have noticed if everything is off, HVAC and radio at idle. But its mostly imperceivable.
Gotcha. I saw the following on the RCD website referencing the CPX:
"This CPX keeps the OEM, four pumps per engine revolution that the Chinese eccentric pumps do not. The OEM Bosch system is timed, and designed to pump to the bank that is requesting fuel (firing). This is to ensure peak nozzle pressure and less harmonics of high pressure fuel, having to cross over via the balance tube, from one rail to the other. Eccentric pumps will skip every other firing event. Two pumps per revolution vs the OEM four.."
Wondering if that could explain it. Its not a huge vibration, just slightly and I can see it in the mirrors as if I had the base turned up slightly. I probably wouldn't be able to tell any extra noise if there was any since I had the Pusher pipes installed at the same time.
I believe that's more marketing hype than anything else. There's a reason for the metering valve and balance tube—pressure is pressure, and they're crucial for preventing the rails from deadheading (like the fuel lines in the heads of the old Powerstroke 6.0) and ensuring those last injectors in the rail are properly fed. I also have the Pusher intake system.
Keep in mind that the DCR can move more fuel than the CP4, so your rails maintain optimal volume and pressure. When I installed the Pusher intake setup, I experienced increased NVH (noise, vibration, and harshness). The harmonics it created drove me crazy for about four weeks, and I had numerous conversations with @HeavyAssault trying to figure out what went wrong. It turns out the extra harmonics were being picked up by the buttons on my Uniden R8, causing them to vibrate.
My wife who is hyper sensitive to stuff like that hasn't noticed or said anything other than the drone from the intake sometimes.
My wife who is hyper sensitive to stuff like that hasn't noticed or said anything other than the de ftimes.
I have experienced the same thing as you with the NVH. With the DCR, Pusher, Banks BA Filter and removal of the CCV, it changed the sound some, but it doesn't bother me anymore. I've gotten used to it and only notice a little vibration in the steering wheel when I come to a stop. Nothing major tho.
Follow up: I emailed S&S and they confirmed the timing is purely for harmonics, which aligns with this report from @usafakid09 on shaking in the mirrors.
Interesting. The installer timed it per their metrications…
great to know. makes sense when in reality the pump cycles 2x per rotation (cp4 is 4x) or something like that right and the FMV is still keeping pressure in the system.
Even following the instructions leaves room for some human error if the procedure is to eyeball the shaft dots on a benchtop.
Thanks for posting, this is probably why the pumps were on back order since they were switching them out. I plan on doing the dcr conversion this winter when I install my 60 gallon tank.
I called wondering if I should send mine in for the upgrade and they said the pin in the shaft has nothing to do with strength or anything like that. So I put it back on the shelf and I'm not going to worry about it. Be great if I found the time to put it in...that's what she said.
I got the same problem, no time. I am debating on the DPK, but I may just do the DCR since everything is apart anyway.
Waypoint, are you going to carry S &S products?
Good news everyone!! The problem has been solved by Ford…and it turns out That IT WASNT THE PUMP AFTER ALL!! Ford is now officially blaming all the failing CP4’s on bad diesel fuel caused by the diminished demand because of Covid. And the best part is that we don’t get a new or improved pump (like what Ram did), but instead Ford is offering an ECM flash that will apparently cure all the problems. 😳🤦‍♂️ (I apologize for the sarcasm!). I’ll definitely be buying the DCR when my warranty is up!!
Gotta love the ford executives 🤬
I’m on the fence on doing the DCR. I have a 22 with 28K on the odometer. I have a pusher full kit (intake , hot and cold side pipes) sitting on my bench needing to be installed. Since I’m 7/8th the way there do I say F**k it and put the pump in and not worry about the factory warranty? If I go for a DPK kit it would probably void the warranty anyways, so if I’m going to do it do I go all the way since I’m doing the intake and pipes? Or wait till the warranty runs out and hope I don’t have to deal with ford ?
I was with you guys on waiting with warranty but weighed out the risk vs cost and pulled the trigger in December of 2023. DCR was first, followed by all the pusher pipes, and CCV delete. Mine is a 2022 with 19k on clock. I did it all around the 12k mark. I’m so glad I went ahead and knocked it out. Since then she’s actually lost some weight and runs so smooth!
Warranty, def worth weighing out but after seeing Ford’s absolute stupidity with their asinine solution on this latest “recall Bull 💩” I can actually say I’ll take to a good friend of mine to do updates and any repair work. Ford just proved how dumb they really are and how dumb they think we are. A software update to fix a mechanical problem…PLEASE! I’d rather pay the money and fix it myself! Rant over….. LOL!
I understand your concerns on warranty. These suckers aren’t cheap. This is one of recommend getting done over waiting or even letting them do their update. I’d hate for them to make matters worse.
I’m kind of thinking the same way as yourself, with the pusher system they may deny warranty, might just pull the plug and move on . Damn my truck keeps telling me that it is morbidly obese every time it goes by a scale , but where I live Obzemptics is illegal 🤷‍♂️
I can understand for sure…… you can do a lot to help it since she’s got to hold on to it. When you do the pusher, go ahead and get rid of the CCV box as well. This is the kit I used and go ahead and get about 20ft of the hose (15’extra over what they give) to dump out the rear of the truck. This will keep you from coating the inside or your pusher pipes.
Got this same kit too without the extra hose. Mine was long enough to dump into the frame. Don't really smell anything and a little bit of rust proofing never hurts 😆
