S&S Diesel 6.7L CP4 to DCR Conversion Kit
I emailed them last week and the keyed shaft DCR revision still won't be out until later this year or early next year. I'll order after then and when my PSD warranty runs out.
Can you please expand on why the keyed shaft is better? I would like to understand
Keyed shafts resist the drive gear (pulley, fan, or that's not permanently bonded) to the shaft via friction and pressure from the nut to utilizing an actual keyway. Then the only real way for the pulley/gear to slip would be if the the key sheared.
Similar reason why people weld the crank gear.
Curious why with you having a DPK, why would you do the DCR? Your CP4 may never fail.
If you depend on your truck daily and cannot afford an unexpected failiure followed by potentially weeks in the shop.
Dpk doesnt stop cp4 failiure, it just protects the rest of the fuel system when it does happen.
So I have 0 filters under the hood. All will be under my truck.
I guess if you have money to spend it's a choice. I don't see the DPK filter under the hood a liability at all, especially since you rarely need to change it.
I am totally aware of what a DPK does and doesn't do as I have one. The CP4 may never fail, if it does everything is protected and I can gave a DPK installed I one day. Just don't see the need to replace a the CP4 may never fail.
Correction: DCR installed I one day.
$2000 to prevent a known and potentially catastrophic problem is worthwhile insurance/peace of mind to some.
If your a hotshot guy and your truck craps out in the middle of nowhere towing a 30k lb trailer, the towing alone can easily surpase the cost of the DCR.
I totally agree with your second paragraph. But I do have a DPK, I am not a hot shot, with the DPK in most case's a CP4 failure will not leave you on the side of the road, it will however greatly affect your performance enabling you to get possibly where your going.
S&S actually intentionally compromised a functional CP4 and attempted to tow a trailer 500 miles. They had to unhook the trailer, but were able to finish the trip with the compromised CP4. The reason was a DPK was in place preventing contamination to the fuel system down stream.
Is there a market for used CP4? I swapped mine for the piece of mind at 37k miles. Maybe I can sell it for a core at minimum
FYI, if anyone requires the CARB EO stickers that has already purchased a DCR kit, shoot S&S an email and they will get one out to you; they are super helpful.
If anyone is looking for how much HP these things are good for, I emailed S&S and this was their response. For a 22 6.7.
“Thanks for reaching out. The DCR flows 25% more than a stock CP4. We typically tell people that the DCR is good for about 750hp. There have been some people make close to this power with the pump. There are also people who have gone with the DCR in the valley and ran a CP3 in a dual fueler setup to make big power.”
Hope this helps anyone looking for that answer.
So if I am reading and comprehending correctly, S&S is saying a DCR conversation ALONE will add 250 hp to a otherwise stock 6.7?
no sir, you would need to have all the other supporting mods to get there. the 2020+ trucks are out of air around +150hp tune and is one of the reason we don't have the 2xx HP tunes like the earlier 6.7s did. You're just overspeeding the turbo and getting outside the efficiency map. But yes all things considered there is larger headroom over the stop CP4 in regards to the amount of fuel it can move.
So if I am reading and comprehending correctly, S&S is saying a DCR conversation ALONE will add 250 hp to an otherwise stock 6.7?
No, they’re saying the DCR pump is rated for up to 750 hp. So if you throw a 100hp tune on the truck and get the hp up to 575, you should still be in the clear. Hope that helps.
Lunch Box, I think what he's saying is that it can support UP TO 750 ponnies being fueled by this pump.
If you're pushing more HP, you need another pump.
Ok, I get it now...thank you for the clarification!! Air is KING!!! You can only get so much air without weight loss!!
Going on a few days since I had the pump installed. To the folks that have done the conversion, have you noticed more vibration at idle? My side view mirrors shake slightly like I am in a Class 8.
Other than that, everything else seems to be doing great.
