S&S Diesel 6.7L CP4 to DCR Conversion Kit
So the 2020+ pumps are available and there's just a line modification coming?
I've seen mixed comments online stating that it's the same pump as the <=19 trucks and it already supported the higher pressure (the 20+ trucks just command more) is this true (sounds like you have a direct in/source)?
Correct, same pump 11-22.
The guy in the video mentioned the owner didn’t have a WIF sensor installed, which is not good. On my HSM kit, the sensor is still utilized..
On my Donaldson lower filter I have a clear sight bowl so I can easily see if water is present.
That’s what I was searching for. Appreciate that.
Could you post a pic if you don’t mind? I don’t think I’ve seen a lower filter with a sight bowl.
We can all pull different thoughts and ideas from the video. I'm pretty happy at this point to NOT have bought the fuel filtering kits I was planning on using for the future. My idea moving forward is now #1 get the DCR done at some point, #2 spend the rest on OEM fuel filters.
FWIW doing oil, oil filter, and both fuel filters during the same interval seems pretty damn cheap. Even better carrying a fuel filter kit "just in case" in the truck.
Can you send me all part numbers and where your ordered from please.
Lower fuel filter – Donaldson P553203
Lower fuel filter sight bowl – Donaldson P569758
Replacement drain valve – Donaldson P571330
Can’t remember which site I purchased them from. Some industrial diesel site IIRC. I avoid Amazon so I don’t get counterfeit stuff.
So you remove the drain valve from the filter, then reattach it to the sight bowl?
I had to give this a minute to bake.
Can anyone give me any other example of a fuel filter that will have this issue? I don't need to see pics, just tell me the equipment, filter, and fuel type. I'm racking my brain trying to recall ever seeing this issue on any other type of fuel filter, even more so with water in the system.
I think it comes down to some what of Lunchbox said. Like you and many of us, we've ran those filters and other metal "canned" filters for decades. I think they're may have been a lack of maintenance (in some capacity) and shit fuel.
You still need to do proper maintenance OEM filtration or otherwise (drain the filter monthly, change at least every 10k, and drive the truck regularly) Nothing was mentioned in the video about any of that regarding the subject truck) Heavy machinery all use the canister type water separating filters for years, so it is confusing to a point.
Lack of maintenance would need to be better qualified.
Shit fuel is an easy answer.
So if one gets a dose of "crappy fuel", how long is the dwell period inside the filter that causes the problems? 1 week? 1 month? 3 months?? Cause if one changes their filters today, gets a does of bad fuel, then they drive for (insert period of time here) before next filter changes.....when is the problem at it's worst??
I never saw anything like what's presented in the video at any time in my Dahl/Baldwin setup on my 2015. I had to stop and think : When have I ever seen this in any other fuel filter?
Ask yourself the same question. What other equipment do you run, that you have seen this kind of problem??
If you got what I saw in shit fuel, man there was a lot of crap in there. I have never seen anything like that.
not sure as I have had many 6.0s, worse yet my excursion (loved that turd) but it was used mostly for travel so it would sit (a handful of tanks a year). I would change filters on time not on mileage just out of sheer 6.0fear and never saw anything like that in the secondary fuel bowl furthermore I even ran an aftermarket lift pump that ran those "blurry" filters.
CARB compliant on a fuel pump??
It's a fuel pump for crying out loud.
You mean to tell me there are non-CARB compliant out there, that what - work cleaner?!
We're getting out of hand with this nonsense or I am not understanding the compliance measure.
Once vehicles are certified 50 state legal, any vehicle that received modifications that are registered in CA or one of the states that follow them can only have modifications that are CARB compliant. So in order for S&S to be able to sell this kit in all 50 states, they had to go through the ________process of gaining CARB compliance. Can only imagine the costs associated with this.
I understand what CARB complaint is.
My question is: how can there be a toxin free fuel pump and toxin fuel releasing pump??
We're talking about fuel pumps here -- it's made to pump fuel. Fuel that has already been processed to meet emission demands. Then it gets cooked in an oven these same complaint vehicles have.
They're becoming simply obnoxious with this compliance make believe world.
Same reason you have carb/EO Numbers for Intakes and such. While I understand your sentiment, it's all about acknowledging a part doesn't increase emissions and getting that stamp. Without it, CA can/will fine you.
California sucks.
@BroncOh Just over 8k mi on mine.i probably wouldn't wait on the keyed version unless it was 100% this year. Your sanity improves greatly.
I remember them testing it for the HO6.7 and they published that video claiming how much extra headroom it has. This will be around for a longtime.
