S&S Diesel 6.7L CP4 to DCR Conversion Kit
Yeah. I’m sure not much would be required to get the needed pressure bump
The pressure was bumped in 2020 to ~2500 barr (36,000 psi) from the previous generation's 2000 barr (30,000 psi). So that will need to be addressed and they are already working on it according to the video and other's testing on FB. I'll be in line for this as $2000 plus install is cheap insurance versus fighting Ford for warranty repairs (or out of pocket expenses of $10-12k). I too am planning on keeping this truck for a very long time and don't want any unexpected issues that seem to be popping up even when owners don't put DEF into the diesel tank.
I'm sorry to say this, but serious props to Ram for recalling their issue and going back to the CP3 pump on their newer Cummins Diesels! At least they appeared to back their owners when there was a failure under warranty. It doesn't seem like the same can be said for Ford (shameful) from what I've been reading on multiple forums. That being said, I made the move from Ram and I still love this Tremor!!
While I agree it's awesome the CP4 was recalled, rumor has it that Cummins was the one who put the necessary pressure on Ram to initiate the recall. There were internal emails leaked between Cummins employees stating they were majorly concerned about the damage the failures were having on the Cummins name.
FCA has a lot of say on certain design parameters on the 6.7L version installed in Ram trucks and are ultimately the responsible party for all warranty repairs. Because of this, Cummins couldn't just go back to the CP3 on their own without Ram signing off on the change.
Due to the size difference between the CP4 and CP3 pumps, Ford cannot issue a recall for the direct replacement.
The video clearly mentions the CP3 pump will not fit in the 6.7 engines due to the its size.
I had always wondered the samething, nevertheless.
That is true, but Ford could design their own pump solution to fix the issue given they designed the engine.
I agree that Ford could design a new pump to fit the location, but I don't see this happening. Ford hasn't been quick to find alternative solutions to issues with their diesel engines dating back to the 6L. While I admit that those first few were Navistar engines, Ford should've worked together with Navistar to find better solutions to the problems that they've had over the past 20 years. I think that this DCR pump will be the solution to go with as the talent behind the engineering appears to be superior than what Ford has developed. My true concern lies with the fact that Ford seems to be insistent on finding any reason to deny warranty replacement on these claims. Rather than fighting a huge company, or finding an attorney to do so, this S&S DCR seems to be the logical choice for the most pricey failures of the 6.7. I chased the problems of my 6L to the tune of over $12k over the years. With this system, $2k seems like a bargain!! I've already submitted to be on their list for the MY22 pump and I'll patiently wait for it to come to production (what's another 6-12 months, when I already waited 15 months for my truck to arrive? ;) ).
Cause all the roads and highways are littered with 6.7L trucks and failed CP4's?? I drive around town and interstate plenty so I can tell you what I see.
Okay...props to them for finding/developing a fix.
Almost 18+ minutes of video.....YET....not a single second of a truck/motor running with their conversion. (sigh)
Okay...yea...the glorified FB users are testing them....still ZERO time showing their products are in use/testing in real world time. Really?! Show me some non-IG/FB/TikTok user that's burning fuel driving miles with this kit. Impress me with data....not pretty displays and cut-away "props".
Don’t worry they will, you do know that S&S is one of the best diesel motor sports injection companies on the planet right
My understanding is that the Cummins had such an issue with the CP4 because they didn’t have an in tank lift pump to feed it, and would get air in the lines under certain circumstances that would then cause damage to the high pressure pump. You don’t hear of anywhere near the number of Ford trucks with this issue, as we have in tank lift pumps that feed into the filter unit and then the CP4, while it pushes the air out in the filter chamber. At least that’s my understanding. Could be incorrect in some aspects, but I haven’t done a ton of research as of yet, as I am not changing anything until the extended warranty is up.
Fords got plenty of cp4 failures hence the class action suit but I don’t know numbers of failures and I know there’s been some revisions that have helped but it’s purely a bad design problem there’s videos out there with cutaways showing how the cp4 and cp3 work and explain the differences once you see that you don’t need to be an engineer to see the problem it’s pretty much common sense
I would guess 99% of the CP4 failures are fuel quality related - with good fuel, I don't think there is an appreciable failure rate.
Ford designed a system utilizing the CP4 as part of the fuel system that destroys the fuel system if there is a failure. Ford could have easily designed a "DPK" into the system to avoid total system failure due to a CP4 failure; they couldn't be bothered to incorporate this into the system since we are on the hook in 99% of the failure cases.
I certainly don’t disagree that the design is problematic. I especially don’t like the idea that the roller lifters can rotate freely in the bore. Was it really that difficult to incorporate an anti rotation guide or mechanism? They have been using these types of mechanisms on roller lifters for camshaft lifters for decades! And there should have been filtering considerations given to the fuel exiting the lubrication side of the pump, especially after the issues were well known.
But, with that, I still believe that given good fuel and changing filters regularly, not running the tank extremely low, and even using lubricating additives (I always do, and always did with my 04 6.0L), I think a failure is a rare occurrence.
I'll be keeping my eye on this one as people get them installed. The CP4 seems to be the Achilles heel in these trucks; seems we're on the cusp of a solution vs. the existing disaster prevention kits.
Will be putting this in my 2020 ASAP!
WAY TO MUCH INVESTED NOT TO!
Putting it in my 2020 ASAP.
Way too much invested not to!
If you look at the number of 6.7's out there versus the number of CP4 failures, I think the CP4 failures are blown way out of proportion. The majority of the CP4 failures were caused by bad fuel or DEF in the fuel. Good to see there might be an alternative option in the works, just not convinced it is really all that necessary.
I actually work at a local Ford dealership and own a 2021 tremor with a 6.7l and can say i have not seen 1 truck come thru the shop for this failure. If you hear about the stories and actually listened to what happen for the failure, its most likely a human error. Now that being said. It can happen.
Other than bad fuel, improperly changing fuel filters is one of the hardest things on a pump. Most guys are so focused on fuel never realizing the procedure they're following when changing out the fuel filters, or lack thereof, is ultimately leading them towards a pump failure.
Air is a pumps enemy so making sure to prime at least 6X then idling for 10 minutes to completely work out any remaining air is imperative. How many guys or dealerships do you think follow this to a tee?
Just FYI: I'm on my 6th Super Duty, 5th Powerstroke....yea...I know a bit about the aftermarket companies out there.
We know how "touchy" this subject is with people. I'm just disappointed when they leave out key details to include a truck running their product in an 18 min video.
