S&S Diesel 6.7L CP4 to DCR Conversion Kit
I saw that - glad I acted a few months ago and still scored version 2.
now i think i am more worried about a crank gear slipping, probably big reason I haven't turned up the juice yet lol... That and who knows what the 10r140 would do with itself.
Nothing is ever perfect is it?
A flaw will always trick down to its weakest link.
The DCR makes plenty of pressure for the new commanded fuel pressure. There’s allot of videos online and posts in various forums about newer trucks, even 2024 HO 6.7’s with a DCR. Tech talk with AROD has lots of videos online this long with beared ford tech.
This forum never ceases to amaze me with the collective knowledge and education an individual can get. I was totally unaware of this 6.7 Cp4 issue having been a Navistar 7.3 L guy since 2001 and It’s still running strong but I bit the bullet last year (2024 MY)and ordered my ‘bucket list’ F350 with the 6.7L HO engine. I found this statement in a previous post stating that Ford had moved to the DCR pump on the HO’s but saw no other comments affirming this. Can you experts out there please confirm this for me so I can scratch this Cp4 concern off my list of things to worry about?
Unless this is something that was just announced minutes ago - that would be a negative.
Ford is still supplying the 6.7 PS with the CP4 pump.
Thanks, i was not clear and i apologize for that. What I was not clear about is there are videos with new HO trucks that have had a DCR pump swap. The DCR makes enough fuel pressure for even the new HO. I believe someone was doubtful about the pressure it makes vs the cp4. I was making a statement that even the new HO with. a DCR swapped pump will run just fine as it’s capable of pressures over 30000 psi. The new HO truck comes stock with the cp4.2. Let’s be honest, this and the cp4 pump are not as bad as the internet makes them out to be. Run quality fuel and change the filters often.
No, I cleared it up in my post.
They aren’t bad; they’re just designed differently. Since USLD (United States fuel) lacks lubrication, the pump rollers are sensitive to insufficient lubrication, causing friction as they skid/roll on the cam. This results in glitter or shavings in the filter and throughout the fuel system. Contamination.
If our fuel pumps were supplied with standard diesel like pre-2010, CP4 pumps would work just fine. That’s largely why these pumps are still manufactured overseas and supplied to millions of diesels. It’s puzzling why the engineers haven’t realized they don’t perform as effectively in the US.
Therefore, 25 extra ponies won’t harm your CP4. Instead, it’s the quality of US fuel that’s the issue. It’s well-documented that adding additives to your fuel can easily maintain the CP4 and provide longevity. The biggest problem isn’t added power, but the lack of fuel additives and/or poor fuel filter maintenance.
To make sure there is no confusion, all 6.7L PSD engines come with a CP4.2. A CP4 is a one-piston pump found in smaller engines like the VW TDI.
How sure are you about that?
Ford/Bosch changed the variant of the CP4 in mid 2021 to a CP4.2
The CP4 has been in the Super Duty since 2011.
I am as sure as Luke from S&S is. Start at the 4 min mark to hear it from the source
As stated earlier, the CP4 is a one-piston pump and the CP4.2 is a two-piston pump and all that has been in the Ford 6.7 PSD. Bosch has changed the pump and Luke explains that as well.
Anybody out there have an update on the class action lawsuit that is often referrred to in posts?
I think we can all agree on the fact that VW is not considered relevant in this context and there is a common agreement that the CP4 specifically relates to the SD. There is no need to differentiate between the two.
Just as we understand that the Godzilla engine is a V8, we refer to it as the 7.3L.
Sure, VW is just as relevant to this convo as the CP4 is. I just like to be accurate. And the fact that you thought the CP4.2 was a pump Bosch and Ford designed for later model year 6.7 PSDs shows that there is confusion. 🙃
After this conversation, I will forget WV uses a CP4 pump 😂
Getting ready to install the DCR on my Tremor. I may be lazy & pay someone to install as I'm not sure my back is up to the task. Also, I have a second DCR that I bought for my F450, but sold the truck before I got around to having it installed. I bought them before the $500 price increase last year. I'll be putting it in the classifieds soon...
