S&S Diesel 6.7L CP4 to DCR Conversion Kit
Contact S&S, the manufacturer. They answer emails within a few hours.
Thanks @Lunch Box 🥩🍔
I pulled the trigger on one this week from a major supplier that sells hundreds of them in the region but they couldn’t tell me if it was the new version or not and I’m not sure if S&S has labeled them as such.
I may be wrong, but I believe they are serialized??
Following this thread and seeing others. Is there a general consensus that that is some sound form the DCR install that will vary based on timing alignment? I ask because I recently had mine installed and there is a "fan on" sounds is the best I can describe it when at idol or coming to light/stop as well as 1 sec after key off.
I dont have this and im about 16k miles on mine, it might have more pumping noises at idle but I only notice it with everything off.
Is this why the engine idles “rougher “ due to the increased pumping power? In theory?
Ok, that could be the sound I am hearing. It can be a pumping sounds and yes it is with everything off. With Radio or AC/Heater do not hear it because it is so faint. However, it is new so thought I would ask since there is not really any video of the sounds or description of that happening that I can find besides timing being off. Thank you @JTredway
I don't have a rougher idle (like choppiness if that's what you mean) It may and I mean "may" be more audible but honestly I can't really tell and don't recall a change. my wife is hypersensitive to stuff and she's not been like this is a noisy diesel. I would say maybe audible of you don't have a piping kit but I gained all my NVH from pusher powerflowkit.
I took a video but can't upload it here, too large, even with it being 16 seconds.
It wouldn't bother me if it did get rougher or louder; my truck is far from stock, so it would just add to the characteristics of it being heavily modified but I was curious if I should expect it after the swap.
I have tried to load small clips as well and it never works. I am not a youtube guy so I just quit trying.
Thanks for attempting however. I should know next week once it's in and I'll repot my observations.
I have tried to load small clips as well and it]never works. I am not a youtube guy so I just quit trying.
I sent it to yt lol
That one worked and yes, I can confirm, it does have more of a "rumble"
Just enough to notice it and I am sure in person, it's more pronounced.
Again, that will not bother me one bit.
Thanks for the vid, btw!
I will upload a video but not sure it will help with the sound. You can really hear the tail end of it once the key off happen.
Like a wuzzzzzzzzzzzzzzzz, only while at idle or stopped at light etc. Since it is making the sound at shut off that is what causes me to think the timing may have been off. Truck runs fine other that that no issues.
I just got my rig back from doing a DCR swap but because I am having turbo issues, I haven't been able to get really pay close attention to the engine noise other than the it does idle slightly rougher (perhaps due to the higher fuel pressure) and when you kill the engine, it is more pronounced -- like a sudden halt (picture shutting off a CAT engine but to a much lesser scale).
I ended up talking to Arod online and he has heard the noise/vibration I have on other trucks that are equiped with the HSM upper relocation kit and lower (mine has these both). He said one the customers switch to fleece the noise went away significantly. Said he may make a video once it warms up.
Interesting but I don't mind it quite honestly.
It more resembles a traditional diesel engine where you can feel the engine, it sitting at idle.
I particularly like when the engine is turned off - I like the feedback it gives when it abruptly just kills the operation.
Price has increased $400
I saw that - glad I acted a few months ago and still scored version 2.
