S&B 60 gallon fuel tank
Yes that is traditionally the case. But several on here have had the 23+ programmed at the dealer. @Tugboat being one of them. My dealer said the capability is there, they just didn’t have what they needed to do it.
Still can’t do it through forscan.
I have talked to multiple dealers, and I have yet to be proven that it can be done on a ‘23+. I’d love to be proven wrong with hard proof. The DTE would need to read 900+ miles on a ‘23+ in order for it to be recognizing a 60 gallon tank at a 15mpg+ average.
If it has been done then it would benefit the community to be told what exactly needs to be done at the dealer in order for others to be able to do it as well. Bogarting this info is pathetic.
All i can offer is that at Corwin Ford Nampa - service writer asked his senior technician if DTE could be adjusted response was yes using the Engineering Test Module.
Looking up on my RO from Corwin, price was $295 in August 2024, max DTE reading would be 999 as it's limited to 3 digits, and if PCM was flashed I'd have to have DTE reset.
Current weather intown mpg being ~15ish - DTE @ 60gal reads 890 this is with BFG K03 37's Tremor weighs ~9500lbs know for sure and certain mileage will vary
Hope the above is useful and it is annoying that info varies from dealer to dealer
I know this isn’t the 23+ thread, but to continue the discussion. I entered Engineering test mode on the truck by holding the brake and “OK” button for 5 seconds, then continuing to hold after starting the truck until “ETM” pops up in the lower right. I see some areas to maybe do some editing but I’m not sure what to do.
They told you it's limited to 999? Show them the pic from S&B and watch their reaction!
My bad assumption of 3 digit limit on readout and ass-sumution can make an a$$ out of me and with my leadfoot I've only seen a max of 900+
Proof of leadfoot tendency
I’ve never seen my project more than 1k miles either lol
Can anyone point me to a metro Atlanta area source/installer for this?
Leadfoot Diesel in Monroe, GA.
Another company did mine locally and ended up having issues with my sending unit, went back to Leadfoot Diesel (as I should've done in the first place) and they fixed me up and got it working again as well as a slew of other items while I was there. I mention "back to leadfoot", not as the original installer, I am in Smyrna/Mableton and used a local shop bc I was lazy and didn't want to drive to Leadfoot whom has done all my other work on my diesels from three previous powerstrokes (2004, 2005, and a 2005 Excursion) over the last 15 years.
It’s really pretty easy to install at home in your garage, shop or driveway.
It would help to have a second person helping you.
With plans to pull our travel trailer on long distance trips I have been toying with the idea of having this 60 gallon tank installed.
Has anyone installed this 60 gal tank on their Tremor? I am wondering what Ford or a reputable shop would charge to install it?
Naturally I would want to have it installed by a shop that has done multiple installs on the SD.
The guy in this video makes it look fairly easy. Thoughts if you have installed this product?
Here is a pretty cool install video -
If you are local to us. We are happy to get that installed for you! We have installed quite a few of them with excellent results.
Random question on the install. I had an issue at full articulation where the draft shaft touched the tank skid plate in stock form. Assume this would amplify the problem given it hangs down lower? Something you've run into?
So their website didn’t inspire confidence
That tank doesn’t show up, the page is not found when clicking on the super duty image, and I can’t submit an inquiry on the contact page because the required fields aren’t free type and no options populate
I can appreciate that, and I’ve done my share…swapped the cam and everything in my z28 in the garage before YouTube existed even…but messing with my daily driver in the driveway (in a way that has it not functional during) just isn’t my lane right now
They don't update their webpage often, they're active on Facebook and calling in. You won't go wrong with Leadfoot Diesel they're well known and built some very nasty trucks. Sport (the owner) had the first ever manual converted 6.7 pulling truck years ago.
They're also the ones servicing a keeping brutus on the road which is a 6.7 about to cross a million miles.
Luke is my mechanic.
@CharlesC am interested where you ran into issue of drive shaft touching tank skid plate. Haven't had this issue been on Sedona meetup, and Christmas Mountain @ Big Bend
BLM Land 5 minutes from my house - Drive over to Eagle and we can hit the dirt together.
Did ping Carli about it when I was trouble shooting the sound and they noted that it could be the skid plate. Evidence below - apparently at full flex this can be an issue (full progressive spring and carli shackles on mine). Notched the skid plate a bit to get some more clearance. Pre-fab below.
