I had a 60 gallon titan installed and pull a 46 foot 5er with my F250 2022 Tremor. We love it.Did you make a decision on S&B vs Titan? I've been researching (have a 40ft fiver I pull) and would like the extra capacity. I'm leaning towards the S&B.
I added air bags and leveled it perfect it now rides and pulls great."Does the truck sit any different with the added weight to one side?"
Not if you're proactive and balance it with extra beer!
Consider that the difference is a puny 175 pounds or so.
Chump change for a Tremor!
Knowing you dipped the tanks and that they're full and the caps are on only to enter IMC shortly after takeoff and seeing analog gauges start bouncing all over the place in smooth air is a different kind of stress.flying aircraft brought to you buy the lowest bidder you learn to watch for lights and needle fluctuations - how I really miss the days of mechanical gauges![]()
S&B comes with spacers to use the OEM hardware (plate, straps and brackets) and a new front section to cover the extensionFor all those that have done the 60 gallon swap and have a skid plate under the tank, is the same factory skid plate that came with the truck?
If so, what brackets are needed?
My skid plate is long gone and I'm gettign new one but wondering what hardware do I need to install under my 60 gallon S&B.
I'm going to look through my "Tremor scrap" to see if I have any of this still from 3 years ago.S&B comes with spacers to use the OEM hardware (plate, straps and brackets) and a new front section to cover the extension
agree do like the pressure transducers/transmitters to smooth out needle "bounce"Knowing you dipped the tanks and that they're full and the caps are on only to enter IMC shortly after takeoff and seeing analog gauges start bouncing all over the place in smooth air is a different kind of stress.
It really is one of the best mods.The misses gifted me the S&B 60-gallon tank for Xmas. Looking forward to the extended range.
You’re not ever going to go back after this mod. The only complaint I have is the fact that you cannot use a rapid fill pump.The misses gifted me the S&B 60-gallon tank for Xmas. Looking forward to the extended range.
I use the high flow pump and just listen for it to get close and manually stop, or use a lower setting.So don’t lock the lever in the full flow setting?
Remove the check valve, it will fill faster. I did this on my 2025 F450 with the S&B 68 gal.You’re not ever going to go back after this mod. The only complaint I have is the fact that you cannot use a rapid fill pump.
I bought my tank from a vendor on here (Apollo off-road) great bender btw. Locally there is an s&b dealer/installer, I called them, they have installed allot of tanks. I had them do mine, didn’t tank long, they programmed the dte. No issues. I would look around and see if someone near you is a dealer or installer.Has the DTE recalibration glitch been resolved?
I sent S&B an email asking for a quote for them to do the install but never heard back other than a canned response... I've heard horror stories about installs so figured they would be the best to do it.
You can’t even lock it in the first position. I keep my hand on the pump and barely squeeze it. I’ll be honest, this is kinda disappointing when filling 60 gallons, but I deal with it.So don’t lock the lever in the full flow setting?
