The 23+ trucks still have the max 48 gal setting through Forscan. S&B does sell some programmer for $3-400 think that can adjust it up to 60. Not sure if it came out yet or not.
I have the Titan 55 gal. Can run it on the high flow pumps at max flow rate, but have to catch it before it gets full or it will backsplash a cup or so when it kicks off.You can’t even lock it in the first position. I keep my hand on the pump and barely squeeze it. I’ll be honest, this is kinda disappointing when filling 60 gallons, but I deal with it.
See this the conflicting info I always see. You would think the ability to update your DTE would be included.The 23+ trucks still have the max 48 gal setting through Forscan. S&B does sell some programmer for $3-400 think that can adjust it up to 60. Not sure if it came out yet or not.
I thought this would bother me more than it actually does. Depending on driving/towing, when I fill up all 55 gals, DTE is somewhere around 575 towing and 780-950 without towing depending on how I have been driving. It has worked fine so far. Takes a while before the gauge starts moving, but no real issues other than my OCD sometimes. Lol. Changed my Forscan settings to 48 gals so I am not too far off anyways.See this the conflicting info I always see. You would think the ability to update your DTE would be included.
Why bother with a 60gal tanknif you have to stop often since your fuel gauge can't be trusted.
Correct. I just know I have a 7 gal reserveSo once the gauge starts to drop is it accurate?
I thought, and very well could be wrong but you rent the programmer, they refund you once you send it back, and it doesn’t work for the 23 plus trucks. Again, I heard this, and could very well be wrong.See this the conflicting info I always see. You would think the ability to update your DTE would be included.
Not on the ‘23+. My understanding was it was a hardware solution that gets piggy backed onto one of the control modules in the center dash stack.I thought, and very well could be wrong but you rent the programmer, they refund you once you send it back, and it doesn’t work for the 23 plus trucks. Again, I heard this, and could very well be wrong.
That’s not bad, mine at full says 1057 dte, then after driving around allot (hundred ish miles) it starts to slowly go down. I bet you can’t get a true dte.I have the sb tank. I haven’t re calibrated anything to be honest the truck seems to learn on its own. Though I have never seen dte say above 999 it will stay at that for about 150 miles then start dropping. I have also seen it climb back up while driving. Dmaxryno has a YouTube video of sb installing the module not sure of the outcome yet but I don’t feel like pulling my dash apart to plug it in. I have talked to arod from powerstroke talk and he has gotten the forscan to be somewhat accurate.
Has the DTE recalibration glitch been resolved?
I sent S&B an email asking for a quote for them to do the install but never heard back other than a canned response... I've heard horror stories about installs so figured they would be the best to do it.
Yeah, 22 and below are easy. Ez link or forscan.Horror stories, really? It’s not to hard to install yourself at home. One person can do the job, but a second person really does make it easier.
And if you have a 2022 or older. The DTE is super easy to reprogram with EZ Link.
There is a 60 gallon option.
S&B 60 gal tank
Here’s a few pics of how a stock 34 gal tank looked under my F350 then a S&B 60 gal I installed. Hangs about 1” 3/4 lower.www.fordtremor.com
Not sure why, but not all dealerships can do this. Not sure of the software they use but I was told the tech has to purchase it, and that when I inquired about it, my dealer did not have anyone who could do it for a 23+.@Avslash is correct the S&B solution is a module which is installed behind the AC/Radio control panel this is the link for information on S&B module https://sbfilters.com/products/2023-ford-super-duty-fuel-capacity-recalibration-tool
Was able to have my local dealership in July 2024, set my DTE for 60Gal, being OCD and doing the math for city & highway driving, both fuel gauge and DTE are accurate within 3%. Dealership charged ~$350 and no disassembly/reassembly was required![]()
Yes that is traditionally the case. But several on here have had the 23+ programmed at the dealer. @Tugboat being one of them. My dealer said the capability is there, they just didn’t have what they needed to do it.That’s because it’s not possible for the 23+ trucks other than the piggy back deal S&B is about to come out with.
