S&B 60 gallon fuel tank
Titan Tanks were actually the first ones I was looking at, looking first at the spare tire tanks, and then moving onto the full replacement when I got the Tremor.
I still go back and forth between the two for which one I will upgrade to in the future. Fast fill is definitely nice, but I don’t know if will get me over my (likely unfounded) paranoia of the TT being plastic, and having no skid plates.
Yet another thing to consider. Haha
Don't ever, ever, ever have paranoia of plastic TT's! Ever!
I’m surprised also. I do miss being able to fill up at the fast fill truck pumps. Now I just got to barely click the trigger on the fuel pump otherwise it keeps shutting off. Do you have this issue also?
Mine is incredibly slow to fill up. Click...click...click...swear alot...click. Common issue. Knew it before I installed the tank. I have a truck stop near me that I try and use as I have found a "sweet spot" on the pump. But the 1000 mile range sure outweighs the fill-ups. I have heard that the check valve has a lot to do with it, but I haven't looked into this much. Sure as heck not removing the check valve though, huge safety concern. Overall, best upgrade I've done. It does hang down about an inch or so, and the skid plates shouldn't be confused for rock sliders!
S&B installed since last July trouble free, the tank being baffled and coming with skid plate were to major features in my decision making
Towing and stopping at truck stops also had to find the "sweet spot," at the time of install had to go to Ford dealership to get DTE and fuel gauge to be adjusted to be accurate for 60 gallon tank -
Forscan 2.3.65 was released Feb 2025 which supports 2025 model Ford/Lincoln so don't know if you can adjust both DTE and fuel guage for 60 gal tank.
Being able to run 800 miles plus empty and 400 miles with toy hauler is really nice :cool:
ForScan does not support changing any 23+DTE beyond 48 gallons. It coded in the firmware.
ZooDad
ZooDad
Is there any confirmation that a Ford dealership can change it? My local service manager has never tried so that has been my hesitation with buying the tank.
Yes I can I have the same Ford software the dealership does FDRS.
ZooDad
yes Ford dealership, Corwin Ford Nampa ID did adjust DTE for me along with fuel gauge just be aware if the system is flashed these settings will have to be reentered as flash puts everything back to stock tank size
Your fuel gage is accurate. The DTE being off is your deterrent no to do the tank? If you fuel at 1/4 tank you still have 15 gallons left. What does the DTE matter?
I like it being visible and accurate. Is that too much to ask?
ZooDad
Am I reading this correctly? FDRS CAN alter the dte settings on 2023-2025 trucks?
If so, you just sold a mongoose cable.
100% agree if it's on the instrument panel it should be accurate, it bothers my OCD when stuff isn't reading accurately 🤪
My statement was yes I can verify that FDRS cannot change the fuel tank size. Therefore not correcting DTE readings.
I also worked with S&B when the 23’s came out to figure out a way to make the adjustment.
At this time there is no fix beyond the long bed 48 gallon value.
ZooDad
ZooDad
I wish I was close to you, I have a few things I’d love to have you program!
Anybody out there running their S&B tank without the neck valve and able to have full flow at truck stop and not getting splash back when full? I hated the slow click click click on my last truck with it on. And had to manually hold the lever the whole time. And if it’s a busy truck stop feel like I am holding up the truckers.
@BroncOh tried it and had to put it back in.
I understand your frustration 🫤 if your on the road all the time and like filling up at truck stops. Beyond that I have the valve in place for safety reasons which is what its for primarily. Also I avoid truck stops as most are 20 to 30 cents a gallon more expensive. If I spend 7 to 12 more minutes filling that is fine.
ZooDad
Thanks for the clarification.
Think I might do the mongoose on this go-round anyway. My 2022 still has never done an OTA update, so the mongoose would at least alleviate those issues on the new one.
Mine is in. I can run full blast on the regular vehicle pumps. I haven't tried the hi-flow truck pumps.
I can also… but not at the high flow truck pumps. It seams like every s&b tank cannot be filled by a rapid flow nozzle at full flow. You would think they would have built the tank to allow that.
I understand the safety aspect of it but I have had 2 trucks now that shut off or have to manually hold the pump as I sometimes cant even put the latch on the first click without it shutting off and it drives me crazy. I mainly use the truck stops when towing and need the space for trailer. I also like truck stops for filling DEF but I have found a solution for that to be resolved soon. I just wanted to nail down a solution for the other problem if I could. I had heard of others in the past leave the valve out and can run high flow with no issues. But the last thing I want is to have diesel gushing out when the tank hits full level and the pump doesn't self shut off.
