Were you guys able to keep the metal tank protector with the S&B 60gal?
AbsolutelyWere you guys able to keep the metal tank protector with the S&B 60gal?
This is great news since mine goes on tomorrow!! I didn’t want to lose the protection aspect since I use my tremor often Off road in the mountains of Colorado fly fishing and hunting.Absolutely, plus they provide an additional plate to cover the extended lengrh!
Yes Sir, your goodThis is great news since mine goes on tomorrow!! I didn’t want to lose the protection aspect since I use my tremor often Off road in the mountains of Colorado fly fishing and hunting.
I am waiting on my service manager at the dealer to let me know if he can adjust the DTE. Adding the tank either way, just prefer to have it semi-accurate.I believe the DTE adjustment only fully works ending MY22. MY23+ is coded into the firmware and while it can be adjusted with FORscan, it’s not 100% accurate.
The FORscan posts have more details, unfortunately my system is acting up and I can’t grab the direct links for you at the moment. :-(
You need to install the valve. It’s for anti wellback purposes. I didn’t install mine originally too and had the same issue as you.So I was able to adjust my DTE and I ended up just putting 55 gallons as the adjustment because the float doesn’t go all the way to the top of the tank.
I have a 2300 mile road trip coming up this week so I’ll get some good hand heels and really make sure I dial in as fast as I can how much fuel there is for the DTE
Also, if any of you guys had any issues with filling up? I was filling up yesterday and diesel overflowed and ran down the side of the truck after it went to the top.
I called my mechanic and he told me that there was a self check valve that we didn’t install because it doesn’t flow properly and makes it harder to fill up and takes longer to fill up, but I’m wondering if I’m likely gonna have a mess if I don’t install that
I will add to the above, I had mine installed 3 years, never had a problem with it in place. Also it is a SAFETY device that keeps fuel from flowing out of the take in the event of a rollover. I am surprised your installer opted to not install without consulting you!You need to install the valve. It’s for anti wellback purposes. I didn’t install mine originally too and had the same issue as you.
I went under the truck, took off the hose clamp, popped the rubber filler hose off, and inserted the valve easily. Works fine. And be glad you don’t have to drop the tank to install it.
I had a titan tank in my 16 ram, it was very good, no issues. I have the s&b 60 gallon tank in my 21 super duty, it’s a great tank, super high quality. I feel the fit and finish are a bit better with the s&b tank… if that matters for a fuel tank.Titan Tanks were actually the first ones I was looking at, looking first at the spare tire tanks, and then moving onto the full replacement when I got the Tremor.
I still go back and forth between the two for which one I will upgrade to in the future. Fast fill is definitely nice, but I don’t know if will get me over my (likely unfounded) paranoia of the TT being plastic, and having no skid plates.
Yet another thing to consider. Haha
I’m surprised also. I do miss being able to fill up at the fast fill truck pumps. Now I just got to barely click the trigger on the fuel pump otherwise it keeps shutting off. Do you have this issue also?I will add to the above, I had mine installed 3 years, never had a problem with it in place. Also it is a SAFETY device that keeps fuel from flowing out of the take in the event of a rollover. I am surprised your installer opted to not install without consulting you!
is that the SPE or Fleece kit? Looks like 2 cans so assume SPE.Before someone asks, that fuel water separator does not hang below the skid plate, it just looks that way in the pic.
Yes SPE, which I prefer over the fleece.is that the SPE or Fleece kit? Looks like 2 cans so assume SPE.
If you were @Godzilla/Tremornator it would be vulnerable for sure!!Before someone asks, that fuel water separator does not hang below the skid plate, it just looks that way in the pic.
