I have also been to the frame in deep sand towing my toy box and was able to air down and work my way out. I did not find the fuel tank to be a detriment in that condition. The tank is well above the axels and diff's front and rear. Only place I see an issue is on breakover - you lose that 1.75" +/- at the rear of the tank, so you might not clear something that you would clear with OEM tank.
Also note that the tank drops down from front to back, so as you move towards the rear wheels the tanks drops futher down as it is "deepest" at the back of the tank (that is the point that is 1.75" lower - front is same as OEM). It is above the differentials and the shock mounts, but no question it does sit down - see photos below.
So if you offroad all the time and are pushing the break over angle - then maybe not the best idea. If just offroading once in awhile - then the tank range will pay dividens in so many other ways it will be worthwhile.
