S&B 60 gal tank
Am I the only one that had to cut bolts to get the original tank off? We didn't have a heat gun handy to try to melt the threadlocker that was on two of the bolts, so we ended up having to cut them because they would not turn. We even broke the J-clip/nut clamp thing that they use, with just a ratchet (because the directions were very clear using an impact would definitely do that!).
I did not have any issue. I used an extension and a ratchet to undo the bolts. Took a little extra force to break the thread lock loose but I took my time, turned them slowly. Reused all the factory bolts and J-Clips.
No, I did not lift the truck at all, both tanks clear without lifting anything. Two 6' ratchet straps hooked around the tank to help lower slowly and raise/hold in place the new tank. Ran the OEM tank down to about 3 gal of fuel left to keep things as light as possible.
You have the stock 35" Duratrac tires as well?
Any concerns with fuel prices rising and these tanks having an easy access drain plug? I’m not worried and plan to upgrade but I think if someone knows you’re rocking this tank it would be an easy theft of fuel. Maybe I’m overthinking the possibility.
Just installed the S&B 60 gallon tank. Took about 3 hours - no lift needed, but did need to jack up rear tire to get the tank to slide under the frame. Used an ATV lift to raise the new tank into position. A heat gun made the tank strap bolts easy (ier) to remove. Hardest part is removing and replacing the fill and vent hoses - very little room to get to the clamps.
No issues with Forscan reprogramming. I used the IPC module settings, changed the tank size to 60 gal and the source from PCM to IPC.
Paint that MF’er bright orange, the drain, and prey the methhead stealing your gas uses it instead of drilling a hole in the exposed side.
If someone is out to steal your gas and your truck provides them an opportunity, they’re going to be successful.
Serious, hope they use the drain.
they still have to drill out the plug, the drain isnt ported out. If you read the directions they do that on purpose and it's left up to the enduser to drill it completely through in the event they want to use it as a fueling source. No different honestly that anyone drilling your tank to steal fuel.
Ahh well that’s awesome then. I didn’t know it wasn’t drilled through already. Then that makes it a little nicer knowing it’s not just an easy socket wrench to crack that tank open. I personally don’t think it’ll be an issue but was curious what others thought.
Just installed the 60 gallon on my '21. It has stock tires and stock suspension. I didn't need to lift the truck. There is a vertical metal plate towards the back that hangs lower than everything else. The directions said you can take it off (3 bolts) if you need. I was able to just slide the tank around it instead.
I used a floor jack with a piece of plywood to lower the old tank and lift the new tank. Lifting the new tank in was slightly tricky. I just went slow to make sure nothing was getting pinched.
The hardest part was removing the filler neck from the filler tube and vent tube. I just worked at it for probably 15 minutes with a flathead screwdriver and my thumbs, and they eventually popped out. It's in a position that makes it hard to apply much pressure. Putting them back in was very easy though.
Removing the tank strap bolts with the blue loctite was pretty easy. I didn't heat them up or anything. Had a bit of trouble putting a couple of them back in.
Also tightening the lock ring on top of the sending unit / fuel pump slowed me down. Once I had the right tools (deadblow hammer and giant flathead screw driver) it was easy. A regular hammer and small screwdriver doesn't cut it. Also, none of the chain auto parts stores had the correct lock ring tool to use with a breaker bar. Deadblow and giant screwdriver is the way to go.
Gauge stays on full for a long time due to there being more fuel above the gauge sender than a stock tank so MTE reads 1138 for about 200 miles. MTE changes more quickly than actual miles put on the tank from full to 1/4 tank on the gauge due to the miles put on the tank before the gauge starts to register a decrease.
I've noticed this as well with my titan tank.
Glad to see it was a relatively easy install for you! That's awesome to hear.
Thanks for the info. Did you get the tank to about empty before starting?
I’ve never been able to get it to be accurate once it gets low. I recently adjusted the AFE so my computer should be a bit more accurate. I’m going to keep track still, and see if it brings it more accurate. If not, then I know when it hits 0, time to fill, vs 50 miles to empty
I am also now using "0" miles to fill as my guide to fill the tank - I have had between 2-4 gallons left on my last few fills. Last week I towed my 10k toybox home from Sand Hollow to S.Cal - 421 miles at 8.9 mpg and still showed 125 miles to empty. Then towed the next morning 62 miles to drop trailer off at my strorage garage in San Diego (now about 7.5k lbs in weight without RZR) and it showed 65 miles to empty when I filled at 65 miles to empty it took 53 gallons - so @ 8.9 mpg that indicated I was pretty much right on with the miles to empty - having 7 gallons left.
Regardless - love the tank and the fact that I can drive from my home in S.Cal to Sand Hollow with no required fuel stops. Was nice to fill up in Huricane UT and pay $4.79 per gallon for diesel, after paying $6.49 per gallon at home in S. Cal! When I filled up yesterday prices back down to $6.09 per gallon, here, but man was $4.79 fill of 57 gallons nice!
nice! I just did my first fill after changing my AFE bias. Filled at just under 50 DTE, still had about 7-8 gallons in the tank. So I think using 0 DTE as my fill time is doable, if my OCD mind will allow it
I actually had perfect timing and got the old tank down to 0 miles til empty right as I pulled in the driveway. There was still fuel in there, probably 2-3 gallons.
For those of you who have installed the S&B 60 gallon, how noticable is the reduction in clearance? I think these are 1.75" lower than stock, which is quite a bit. Has anyone had clearance issues, or was it a bigger drop than expected?
Originally the literature was that it was 3/4" lower and not 1-3/4" lower, so at some point they corrected/changed it. I haven't bought or installed one yet. I think it would be great for long road trips.
If the skid plate spacers provided are 1”, as per the website, I don’t see how the ground clearance can be 1.75” less.
