S&B 60 gal tank
Adding photos here of the check valve closed and opened on the old tank.
Also YouTube video of an install - about 43 minutes and 40 seconds he talks about the check valve on the original tank:
Thanks! This is interesting! The ability to fill up to the fuel cap then must mean the extra fuel is coming up the vent side of the filler neck, bypassing the check valve.
I’ve been filling at 50 miles to empty regularly, and regularly it was only taking about 52 gallons to fill. Ran it to zero the other day. Hit zero with 2 miles to go to the gas station. I was confident I had gas, but my OCD was making me sweat!! Still only took 54 gallons to fill.
As a side note - my buddy was teasing me saying it would take 10+ min to fill this gigantic tank. I decided to time myself. I didn’t rush. I have to swipe twice to fill. Regular gas station, two swipes, took 6 min 45 sec total to fill the truck. I’m okay with that.
Just got mine in. Gonna install it in a couple days. That will be a bit disappointing if it can't read the fuel level semi-accurately. Having 6 gallons to spare while on E is a pretty big discrepancy.
I’ve never been able to get it to be accurate once it gets low. I recently adjusted the AFE so my computer should be a bit more accurate. I’m going to keep track still, and see if it brings it more accurate. If not, then I know when it hits 0, time to fill, vs 50 miles to empty
Anyone concerned about having fuel sit for to long having the added gallons if you’re on vacation? Just curious if there’s any possible issue of fuel separation not going through a full tank that often.
Wouldn't this be an issue with a stock tank as well?
The verdict is out on the accuracy of the S&B 60 gal. I finally made a road trip this weekend on a Turkey hunt. It normally takes me about 11 gallons each way to camp. I’ll fill it up this week sometime and let ya know how many gallons it takes. My previous f250 was a 2012 and it showed gallons used which I liked seemed accurate too. And my f250 previous to that one was a 2005 and it had that feature plus ac fan control on my steering wheel 🧐. It it just me or are they getting wayyyyy more expensive with less options. Sorry I kinda got off the fuel topic.
The same 50% on the gauge is not 50% in the tank but the DTE is pretty close to accurate.
The better question is are you guys programming it to be 60gallons in ForScan or are you leaving some headroom and telling the computer it is a "58" gallon tank or similar. My DTE has always seemed accurate be pretty close with the FORScan changes and I did program both locations as outlined in the guide.
I had the S&B tank installed and I love it. I get close to a thousand miles per tank when doing highway mileage of 17-18mpg. I made the changes via FORScan to get accurate fill level as well. Great upgrade!
Forscan - told it 60 gallons
So after back and fourth with S&B, and my installer, I have come the conclusion that the miles to empty is correct and the truck real does "learn" and that number changes with every tank fill. The biggest factor is tire size and driving speed. As long as you use the ezlink or Forscan to change the size of the tank and the litters...your good to go. This is just my opinion and the results I'm seeing.
@GT350 Have you been able to fill up at any of the high-flow diesel pumps? The video Colt (from Colts way YT channel) said that once he switched to the S&B, the high-flow pumps wouldnt fill the tank. Likely something to do with back pressure.
I would hate to go from filling 34 gal fast to 60 gal slowly...
I did the SB60 and have no issue filling it completely, I do have to slow down for the last few gallons but not bad.
I love my S&B Tank. Easy install - 3 hrs on the floor of my garage without a lift. I get 1050 miles to a tank on average with 5 gal left in the tank when I fill it at between 50-80 MTE on the gauge. Gauge stays on full for a long time due to there being more fuel above the gauge sender than a stock tank so MTE reads 1138 for about 200 miles. MTE changes more quickly than actual miles put on the tank from full to 1/4 tank on the gauge due to the miles put on the tank before the gauge starts to register a decrease. MTE becomes very accurate within the last 1/4 tank with probably a 40 mile fudge factor built in from my average 55 Gal fill up out of 60 gal capacity with 50-80 miles left on the gauge. Used Forscan to set tank size to 60 gal. No problem filling it all the way up to the top of the fill tube even with the check valve installed. Much less foaming of diesel in the tank than on my '97 Powerstroke's duel tanks so topping off is much quicker. Haven't used the high flow pumps at a truck stop yet but had to throttle those way down on my '97 - I expect the '22 will not fill at full throttle as there is a tube about the same diameter as a high flow nozzle between the cap and tank restricting flow. Not like filling my CAT - dumping directly into the top of a tank with no filler tube. Don't have to fill up very often and can put in a full 8 hr drive pulling my Momentum and only have to fill up when I stop for the night to sleep.
Did you need jack stands at all or is there enough clearance to drop the OEM tank and install the S&B tank without a floor jack?
I actually backed mine up on my bricks in front of my parking spot in my garage and it was plenty high enough. I’d say 6” max but probably didn’t need to. I have 35” tires also. Hope that answers your question. Good luck 👍
No, I did not lift the truck at all, both tanks clear without lifting anything. Two 6' ratchet straps hooked around the tank to help lower slowly and raise/hold in place the new tank. Ran the OEM tank down to about 3 gal of fuel left to keep things as light as possible.
