Ok, the driver's side Jimmi jammer install with the painted to match passenger side handle is done.
However, no one seemed to mention by doing the passenger handle install it would be extremely difficult doing this, or maybe something changed along the years or more recently with the 22s.
This is NOT for the faint of heart. I was already in and committed, so I was determined to pull it off.
Removing the lock rod was a bit tricky, requiring to turn the rod 180ºs and then 90ºs to get past the bends in the rod. This was not the hardest part though.. more to follow below:
You will need to modify the passenger handle by clipping off the locating peg to be flush. Very easy with some flush cutters.
The most nail biting part, cutting off the painted area where the original handle located within, as this is in the way preventing you to insert the new passenger side handle. There was just no way around it.
You will also need to modify the Jimmi Jammer plate so that it fits around the passenger side handle.
Pics in order from removing the original handle and lock rod assembly to completion at very bottom:
Worth it in the end, but wish I would've known it was going to be a nightmare in advanced.
@ccw
