This will be my build thread. I'll continue to update this post with completed mods and future planned items. '22 F-350 6.7L Lariat Tremor with black appearance and ultimate packages.
Future:
Future:
- Seven Baja Designs LP4 Pro lights: four clear and three amber
- Starlink Mini with Striker Fab mount
- RockyRoad Kicker full cover sliders with rock crusher package
- Roam 180º awning with Leitner ACS mounts
- Roam 7 gallon water tank
- Roam Desperado tent
- S&B 5.5" suspension system
- G-FX TR16 18x9" 0 offset custom two tone black/red powder coat wheels with BFGoodrich KO3 40x13.50R18 tires
- S&S DCR pump
- Pusher Powerflow gloss black intake manifold with no CCV or EGR bungs
- Locking Diesel fuel and DEF caps: https://subtle.design/products/tankwarden/
- Magnetic hitch tube end covers: https://subtle.design/products/hitchcovers/
- OEM DRW tailgate light bar with brake light function module: https://subtle.design/products/drwmodule/
- Foot rest/dead pedal: https://subtle.design/products/deadpedal/
- Better designed OEM fifth wheel plugs: https://subtle.design/products/fifthwheelplugs/
- OEM-esque ditch light mounts: https://subtle.design/products/ditchlights/
- Momentary adapter for OEM upfitters: https://subtle.design/products/momentary-adapter/
- All upfitters always on, free fuse swap mod with run/start relay removed: https://www.fordtremor.com/threads/upfitter-switches-always-hot.8141/#post-169662 by @MTUcrash
- Leitner ACS roof rack with seven LP4 light mounts
- WeBoost with heavy duty 1/2"-20 black antenna spring
- Course Motorsports direct mount MagSafe phone holder/charger
- New old stock powerstroke door emblems custom painted by BFN truck shop
- Fender vents custom painted by BFN truck shop
- USB C passthrough bulkhead fitting installed in top dash tray; cable ran to OEM USB C port in center console cubby.
- Talon’s Garage transmission skid plate, powdercoated black
- S&S CP4 Gen 2.1 disaster prevention kit
- SPE CCV reroute and internal catch can
- S&B cold air intake with dry filter and filter sock
- S&B hot side pipe
- HSM cold side pipe
- CravenSpeed stubby antenna
- Midland MXT575 radio with MXAT03 3dB antenna; radio mounted under driver's seat
- Samlex NTX-2000-12 2KW pure sine wave inverter, placed in same spot as OEM inverter
- Upgrade OEM dash and console 120V AC power points with 12 AWG SJOOW cord
- Add two 120V AC power points in the bed
- Add two 12V DC power points in the bed
- Add two extra bed light switches and lighting onto OEM circuit
- Tailgate bumper stops shoulder bolt upgrade
- American Racing Baja 17x8 0 offset rims with 37x12.50R17 Mickey Thompson Baja Boss AT tires
- OEM Bronco Raptor wheel center caps installed into the above wheel hub caps
- US Wheel Adapters custom made hub centric rings - 128.2mm OD, 125.0mm ID
- ARB twin air compressor with Dirt Church Industries behind the rear seat mount
- ARB air quick connects; one each at front and rear bumpers
- AMP bumper bedstep
- Odyssey Extreme AGM batteries
- HSM upper and lower fuel filter upgrade/relocation kits
- Custom made rock guard for HSM lower fuel filter relocate
- Stahlbus bayonet oil drain
- OEM unpainted mirror caps
- OEM running board lowering brackets
- Boost Auto Parts smoked mirror signal indicators
- Boost Auto Parts tow mirror turn signal & running light module
- OEM cup holder ambient light with harness from @JHForman812
- BD Diesel high idle kit with parking brake override on upfitter
- BuiltRight rear seat release strap
- BuiltRight bulkhead accessory rail with recovery board mounts
- OP Mustang GT4 MSI dark gray IMSA extended nose wheel studs
- Limitless mirror spot light speed override
- TVDVinyl gloss black tailgate letters
- Truxedo Sentry CT bed cover
- TailGuard tailgate security brackets from @OmahaBravo
- OEM Ford side bed storage boxes
- Putco Boss headache rack
- Putco Venture Tec Quick Rack - Thank you @Vecman!
- Custom Solutions PNW high mount cargo camera relocate kit
- Charvonia Design load stops/tie downs for headache rack
- 3M 2080 M12 matte black vinyl wrap tailgate 'handle'
- ClearVu tailgate camera washer nozzle
- Super Overland black stainless steel tailgate step cover replacement with DIY countersunk screws
- Paint exhaust tailpiece black with Rustoleum high heat 2000º primer and paint
- Noco block heater inlet
- Horn relocate
- Door lock actuator rods delete
- Jimmi Jammer hood kit
- Jimmi Jammer tailgate kit
- Jimmi Jammer taillamp screws
- Jimmi Jammer front doors kit + painted passenger handle for driver's side (see post #417)
- Jimmi Jammer rear doors kit
- Tufskinz gloss black hood insert letters
- Tufskinz gloss black glovebox insert letters
- KJM Vinyl Black Steering Wheel Emblem Overlay Decal
- Visor decal overlays - Thank you @Rodd187!
- Peerless G80 1/2" black hammerlocks
- Husky X-Act Contour front and rear floor mats for OEM vinyl floor
- Carli leaf spring shackles
- Rough Country 9285 1.5" front lift springs
- Apex Chassis draglink and tie rod steering upgrade
- Synergy adjustable trackbar
- SPC 2º caster shims
- Carli front diff guard
- Lubelocker front diff gasket
- Front diff drilled and tapped for 1/8” NPT drain plug
- Steelcraft HD front bumper with Warn 16.5ti-S winch and Yankum Groove Hawse fairlead
- Diode Dynamics Elite Series LED fog lights
- Relocated OEM Ford emblem with camera to front of Steelcraft bumper
- S&B 60 gallon fuel tank
- Ozempic with Shibby Engineering harness caps and factory parts
- CJC rear bumper, powder coated black, with Baja Designs S2 Pro wide cornering lights
- Bilstein 5100 shocks and steering stabilizer (boots removed)
- Ohio Diesel Parts seat spacer kit
- Aggressive lumbar fix (lumbar delete): https://www.f150forum.com/f118/diy-tsb-overly-aggressive-driver-seat-lumbar-relaxed-position-314246/
- Forscan Changes:
- Enabled Operator Commanded Regen
- Enabled Fog lights with high beams
- Enabled Fog lights with DRL
- Enabled Parking lights with DRL
- Enabled DRL 75% brightness with headlights
- Enabled Unreal Engine
- Enabled climate bar on bottom of screen
- Enabled DPF % screen
- Tire circumference: 2785mm
- Disabled factory inverter config
726-66-01 x*xx xxxx xxxx SlaveExists_ICM_Cfg ENUM: 0=ABSENT 1=PRESENT - Disabled fob panic
- Disabled auto engine shutdown
- Disabled 'Full View Not Available' black text box on rear camera
- Disabled door ajar and seat belt chimes
- Disabled triple start-up ding
- Disabled double honk with fob outside of vehicle
- Disabled double honk with fob locked inside of vehicle
- Battery Technology Type changed to AGM
- Turn signal flash count increased to 7
- Lowered TPMS minimum pressure
