Red Zeppelin Build
I ordered some 3M translucent black vinyl wrap to experiment next for the cab lights. If it looks good, it will hold up much better than the spray tint. 3M Scotchcal part #: 3M-3630-22
This is the alternative I'm shooting for rather than going with aftermarket cab lights, which I don't want.
You might also consider spraying the inside of the light cover vs. the outside. Had a buddy do this on an old Blacked out Acura Integra. He said it held up well. Just a thought for your experimentation.
The lenses are permanently attached to the cab light base; no way to really remove them without destroying.
They are sealed and dont have removable lenses like the old ones did. This is why there are no aftermarket tinted ones like the old models had.
Unfortunately the 3M translucent black vinyl (3630-22 sku) doesn't allow enough light to pass through. Noted in the datasheet that 3M says the black is largely opaque instead of translucent, so it may be worth considering a gray color next. Was a cheap experiment and good info to rule this specific color out for any future projects.
Just ordered 3M slate gray and 3M silver gray colors to try next.
If this next experiment with these colors fails, I'll probably be doing the spray tint with a clear vinyl overlay to keep the spray tint from flaking off.
3M-3630-61 - Slate Gray
3M-3630-51 - Silver Gray
Pretty cool! I recently wrapped a driver's side mirror on my car, and that was difficult. I cannot imagine a running light with those groves - and I was using a heat gun too.
Right! I just slapped this on haha. I'll probably hire the local vinyl shop to do the wrapping if it pans out on the next colors I ordered.
On a positive note, I've been getting better at applying the spray tinting. It wipes off with 99% isopropyl alcohol easily when the tint is dry, so it's easy to start over and practice. This actually looks alot more OEM than the black vinyl previously posted today.
This looks very nice.
How are you planning to reach up there to wrap all 5. Ones closer to the middle would be most uncomfortable to get to, even using high steps or a ladder.
First mod is diamond plate on the hood to reinforce it and give a good place to stand for roof access. :P
This is why I bought a cab light to do experiments on and why I'll pay a tint/vinyl shop to do the wrapping of the real ones, since the ones on the truck have an adhesive gasket on the bottom.
Installed the BuiltRight rear seat release strap today. You will need a T30 Torx bit.
I had to tweak the bracket slightly; the bracket was binding against the plastic part that snaps onto the pin, thus preventing it from returning into it's normal state via the spring. Was easy enough.
Like you i bought the builtright latch, but once i opened and looked behind there realizing that there is just no space to store anything meaningful, i did not see the value in installing the latch. And opening the Ford latch isnt that challenging either, to be honest, if you do it once you know how to do it next time. So my thought was, unless one is going to open that latch often, there’s no point of the install. At least for me there wasn’t one, so i didn’t bother.
I wasn't going to buy the BuiltRight seat release strap either, but after dealing with inspecting the cab vents, figured it will save me some time in the future haha.
And i thought we took care of the vent problem once and for all with our hoses! 😂
(That other part of my brain is nagging me... i have the part i paid for just sitting in a box, might as well just bolt the damn thing on even if i never reach there again)
Next time you try to open that, and it takes longer then 30 seconds, you’ll be like “dang it, I should just install the release!”
