Red Zeppelin Build
The reason im not doing this install is simple. Why go through all the trouble if a thief can simply break a window and get in that way. So he either breaks a window or he breaks a door handle, but he gets in either way if he really wants to.
What happens once he is in is a different matter. Thats kill switches, ravelcos, diskloks and other security measures to make sure he doesnt drive away. But this jimmy jammer door thing seems rather pointless to me given above windows are an easy target.
True, need to figure out a kill switch, something james bondish would be preferred. In defense of the JJ you do draw more attention breaking out a window than looking like you have a key and busting the lock with a screwdriver
I am curious what the thought behind the AirTag is. My guess is if the truck is stolen. However if they have an apple device, it will notify them there is a tag traveling with them. Then it will allow them to find it with their phone using wide band.
Well, it might take them a damn long time to find one. I have two now and my goal is 3-4, all hidden behind panels, inside hood, etc, i’m willing to bet to rid of all 4 might take them at least a couple of days of searching and a lot of frustration. And i think they still wont recover all 4. For $100 for 4, that’s a pretty good safety feature.
Some reason for this is that when the door is opened by turning the lock cylinder, the security system will give you a certain amount of time to place the key fob into the little spot in the center console before the alarm sounds. If they have access to the cab, they can disconnect the BCM and swap out for one they have a key for, without the alarm going off. If you break a window, the alarm will sound immediately, drawing lots of attention. Of course, if they cut the horn cable, then it doesn’t matter.
Installed 3/4" Neoprene foam cord between the bed and cab today. Posted here as well for context as to the reason behind the mod for bulk water diversion away from the cab vents: https://www.fordtremor.com/threads/2022-water-leak.8706/page-2#post-234571
It rained pretty hard after I installed it, so it was meant to be! :D
Just curious on the use case for this product?
Yes, and there are multiple YouTube videos showing how to physically disable the speaker inside an AirTag. This will make finding them even more frustrating for the unsuspecting thief.
On a funny side note, when we were at Disney two months ago, I put an AirTag on my rental car keys so I would not lose them. We were in a rush getting back to the airport, and I forgot to remove the AirTag from the Avis key fob. :D
For the last two months I have been tracking whoever rents the car I was driving and so far, not a single person has thought to tell Avis or remove the AirTag from the keys. I just checked this morning and the car is in downtown Orlando. I am sure most of the renters have Apple or Android phones, so apparently people do not care when their phone tells them an AirTag is following them. :ROFLMAO:
This will be my 'build' thread. I'll continue to update this first post with completed mods and future planned items. '22 F350 6.7L Lariat Tremor with blackout package
  • DONE - Custom developed Diesel fuel and DEF locking caps https://subtle.design/products/tankwarden/
  • DONE - HSM upper and lower fuel filter upgrades
  • DONE - Stahlbus bayonet oil drain
  • DONE - LatchLid tailgate security https://latchlid.com/buy-latchlid
  • DONE - OEM front bumper filler panels
  • DONE - OEM unpainted mirror caps - Thanks for the idea @Vecman
  • DONE - Boost Auto Parts smoked mirror signal indicators
  • DONE - Boost Auto Parts tow mirror turn signal & running light module
  • DONE - OEM cup holder ambient light with harness from @JHForman812
  • DONE - BD Diesel high idle kit with parking brake override on upfitter
  • DONE - Paint front hubs satin black
  • DONE - Removed OEM hubcaps
  • DONE - Ford wheel locks
  • DONE - Black, non-swelling lug nuts
  • DONE - Limitless mirror spot light speed override
  • DONE - Signville Tremor bed decals - black with clear overlay
  • DONE - TVDVinyl gloss black tailgate letters
  • DONE - Truxedo Sentry CT bed cover
  • DONE - Black Plastidip 6.7L and Powerstroke badges
  • DONE - 3M 2080 M12 matte black vinyl wrap tailgate 'handle'
  • DONE - Paint exhaust tailpiece black with Rustoleum high heat 2000º primer and paint
  • DONE - Noco block heater inlet
  • DONE - Jimmi Jammer hood kit
  • DONE - Jimmi Jammer tailgate kit
  • DONE - Jimmi Jammer taillamp screws
  • DONE - Jimmi Jammer front doors kit + painted passenger handle for driver's side (see post #417 )
  • DONE - Jimmi Jammer rear doors kit
  • DONE - Tufskinz gloss glack hood insert letters
  • DONE - Tufskinz gloss black glovebox insert letters
  • DONE - Peerless G80 1/2" black hammerlocks
  • DONE - CravenSpeed Stubby brand antenna
  • DONE - McMaster-Carr receiver tube end plugs - thank you @Lunch Box !
  • DONE - Husky X-Act Contour front and rear floor mats for OEM vinyl floor
Future Items:
  • Odyssey Extreme Group 65 AGM batteries
  • Toyo MT LT315/70R18
  • Sharptruck.com or Talons Garage Skid Plate
  • BuiltRight bed panels
  • Putco bulkhead panel
  • Putco 'Boss' headache rack
  • ARB twin onboard air compressor
  • AMP bedsteps
  • S&B 60 gallon fuel tank
  • HSM hot and cold side pipe upgrades
  • S&S CP4 Gen 2.1 disaster prevention
  • High wattage power inverter or small diesel generator
  • Factory winch with Factor55 rope end
  • Carli upper and lower steering stabilizers
Forscan Items:
  • DONE - Nav while in motion
  • DONE - Operator Commanded Regen
  • DONE - Bambi Mode (Fog lights on with High beams)
  • DONE - Fog lights with DRL
  • DONE - Turn signal flash count set to 7
  • DONE - Disable door ajar and seat belt chimes
  • DONE - Disable triple start-up ding
  • DONE - Disable double honk with fob outside of vehicle
  • DONE - Disable double honk with fob locked inside of vehicle
  • DONE - DPF % screen
I can't find those plastice piece you put in the front fender to block stuff from going inside the front bumper. I want to add those. do you have the link? I know it's in here somewhere, but I am hoping you can help me find it quickly. Thanks!
You strangely deleted your two questions that I answered previously with the Tufskinz glovebox letters in addition to the Hammerlocks. Not sure what's going on, but it's confusing for our forum members to not have context.
Sorry, I am still learning how the forum and posting works. I found the answer on one of the questions I asked, so I thought I was doing the right thing to avoid unnecessary questions. I do see now how that would mess it up. Won't happen again. Thanks for letting me know. Do you have the link to buy the plastic covers that go under the front fenders to prevent stuff from getting into the front bumper? Those look perfect and I would like to grab them. Thanks
Links and quantities here:
Qty: 1 https://parts.ford.com/shop/en/us/filler-6588815-1?pdp=y
Qty: 1 https://parts.ford.com/shop/en/us/filler-6506519-1?pdp=y
Qty: 2 packs https://parts.ford.com/shop/en/us/screw-6355699-1?pdp=y
Qty: 2 packs https://parts.ford.com/shop/en/us/nut-hex-u-bolt-6533153-1?pdp=y
Here's some comparison photos after two coats, probably on the heavier side figuring out how the 'paint' comes out and lays. I may just do two light coats.
Any idea how much that level of coating impacts the brightness of the lights?
I ordered some 3M translucent black vinyl wrap to experiment next for the cab lights. If it looks good, it will hold up much better than the spray tint. 3M Scotchcal part #: 3M-3630-22
This is the alternative I'm shooting for rather than going with aftermarket cab lights, which I don't want.
