So, did the install go pretty simple for you?Got the OEM unpainted mirror caps and Boost Auto Parts smoked mirror signal indicators/spotlights installed. @Vecman Looks much better now than stock with the chocolate dipped mirror caps.![]()
A mixed bag. Was pretty windy and I was fighting to get the wiring harness inside the mirror back in the right spot. Took about 2 hours I think.So, did the install go pretty simple for you?
Well, good! Hahaha! Gotta have a bit of struggle! Looks great!A mixed bag. Was pretty windy and I was fighting to get the wiring harness inside the mirror back in the right spot. Took about 2 hours I think.
ThanksWell, good! Hahaha! Gotta have a bit of struggle! Looks great!
Just ordered my black lug nuts today! Your pictures definitely sold me on them lol. Will have Discount Tire put them on for me whenever I get my new tires.Project black lug nuts is complete. Just waiting on my black zinc Ford wheel locks now.
The rear hubs are painted black, but Ford does not use a very good paint. It will start to rust right away and look dingy in about a month or two. I painted my front and back hubs with enamel to match the black on my Fuel wheels and I think it looks great without the caps.Just ordered my black lug nuts today! Your pictures definitely sold me on them lol. Will have Discount Tire put them on for me whenever I get my new tires.
To make sure, is the rear hub already painted black? Or did you have to paint it yourself?
Ahh makes sense. Thanks!The rear hubs are painted black, but Ford does not use a very good paint. It will start to rust right away and look dingy in about a month or two. I painted my front and back hubs with enamel to match the black on my Fuel wheels and I think it looks great without the caps.
CG Build - Painted Hubs post
As I mentioned later on in my thread, I know my hubs heat up when towing because of the large increase in my tire pressure. (8-10 psi)Ahh makes sense. Thanks!
I picked up some enamel spray paint the other day for something else. It's automotive, but not high temp stuff like you show in your post. Do you think that would be OK? Or should I make sure to use high heat paint?
Gotcha, that makes sense. Thanks! I have some matte black spray paint kicking around, so I'll do some experimenting with that and the enamel stuff I bought to see what looks best with them.As I mentioned later on in my thread, I know my hubs heat up when towing because of the large increase in my tire pressure. (8-10 psi)
However, they are nowhere near approaching 500 degrees or even hot to the touch. I used the medium heat paint (2000 degrees is high heat) because I felt the color and matte consistency was the closest match to my fuel wheels. If you are keeping the factory Tremor wheels, I would get a flatter paint to match the wheels vs a gloss paint.
One of these from here should be close enough: https://tvdvinyldecals.com/collecti...rd-super-duty-tailgate?variant=31300339236979I'm having trouble finding stone gray tailgate letter inserts for my 2022. Ive already ordered the stone gray hood inserts from tufskinz but they dont have them for 2022 tailgate. I found tailgate inserts on Amazon but they don't have stone gray either. I think there is a brown that could be similar. Has anyone found stone gray for tailgate? If so please let me know.
Awesome! Now's the fun part of putting on miles ASAP so you can put it to work at your next oil change!Got my Stahlbus oil drain installed today when I did my 1st oil change at 3500 miles.
Awesome! Now's the fun part of putting on miles ASAP so you can put it to work at your next oil change!![]()
Lol of course. Time to invest in that oil udder!I know! Next one will probably be at 8500 miles. Made a bit of a mess on the oil change as the filter slipped and splashed into the drain pan. Nothing ever goes smoothly with this truck.
Hereβs the thread where BroncoHooves and I discussed and settled on the Stahlbus over other options. Good starting point for your research.Never seen the stahlbus before. Going to have to look that one up. I generally use an EZ Oil Drain with the 90 degree hose fitting.
I did order the oil udder and holy cow where has that been my whole life.
hs-motorsports.com
hs-motorsports.com
