How many total, 2?
How many total, 2?
Only two. We'll see if they fling off after driving.How many total, 2?
Are there any other fittings on the front end?Only two. We'll see if they fling off after driving.
Nope, only twoAre there any other fittings on the front end?
Looks great! How was the install in that location? I’m still searching for a permanent location and have been hesitant to drill any holes in the dash.BD Diesel high idle installed! Just waiting on a Bosch relay to come in so I can wire up an enhancement mod to it.
Is the Li400 grease that comes with this kit generally what is recommended for the front U joints, sway bar end links, etc?Waiting on Lube shuttle grease kit to arrive for greasing the front axle U joints
Lube-Shuttle®: Travel Trailer Greasing Kit
The Travel Trailer Greasing Kit is specifically designed to accommodate greasing travel trailers. The AirTec Fleet Guard grease included in the Travel Trailer Greasing Kit meets the requirements for greasing trailer axles, suspension points, 5th wheel balls/plates, and the drive shafts and...advancedenginetech.com
Install was very good, I watched a video on YouTube that showed mounting it in the same spot on his '22 super duty. I didn't like drilling either but it is a perfect spot for that knob IMO.Looks great! How was the install in that location? I’m still searching for a permanent location and have been hesitant to drill any holes in the dash.
Interested to see what the “enhancement” is, any clues?
Li400 is just a more advanced grease that @ccw found out about after talking to them. It's supposed to last alot longer and has some better properties.Is the Li400 grease that comes with this kit generally what is recommended for the front U joints, sway bar end links, etc?
I’m sure you’ll do a write up, but I’m definitely interested in this.Install was very good, I watched a video on YouTube that showed mounting it in the same spot on his '22 super duty. I didn't like drilling either but it is a perfect spot for that knob IMO.
The 'enhancement' is a parking brake bypass on an Upfitter switch. Great for winching and other use cases. I got all the wiring done today, just need to plug the Bosch relay in when it shows up!
Found the video you referred to, looks like I might have found a location for my switchInstall was very good, I watched a video on YouTube that showed mounting it in the same spot on his '22 super duty. I didn't like drilling either but it is a perfect spot for that knob IMO.
I'm still a ways away from my first oil change, so I'm going to grease them when the kit comes in, and then grease them again on my 2nd oil change.
Ohh that's cool! If they stay on while driving I'll definitely be doing that as well. Where did you get the caps from?Only two. We'll see if they fling off after driving.
Here you go https://www.amazon.com/dp/B0779K66D...abc_9EFTTDX627HRZ2QJX95G?_encoding=UTF8&psc=1Ohh that's cool! If they stay on while driving I'll definitely be doing that as well. Where did you get the caps from?
Will you be posting a write up, and can you share where you sourced the relay from?Got my Bosch relay installed and it worked perfectly as expected. Also was my first Upfitter install utilizing a passthrough wireWas pretty fun.
Basically, that is the post I got the idea from except it's a little out of date for our trucks.Will you be posting a write up, and can you share where you sourced the relay from?
I found this post on one of the other forums, was your install similar?
High Idle during Remote Start w/o setting the parking brake - Ford Truck Enthusiasts Forums
6.7L Power Stroke Diesel - High Idle during Remote Start w/o setting the parking brake - I wanted to do the SEIC high idle mod to my truck but my additional requirements were: high idle had to work with factory remote start high idle had to work without setting the parking brake (I live in a...www.ford-trucks.com
Bronco, is there sufficient space to put the high idle know on the panel below where you installed? The space where the video installs is already occupied!Basically, that is the post I got the idea from except it's a little out of date for our trucks.
I didn't get any pics of the install since I was doing it in the dark with a headlamp.
This is the stuff I bought:
Relay: https://www.amazon.com/dp/B004Z0WMQQ?psc=1&ref=ppx_yo2_dt_b_product_details
Relay harness: https://www.amazon.com/dp/B01KVZ2MCW?psc=1&ref=ppx_yo2_dt_b_product_details
Non insulated splices: https://www.amazon.com/dp/B07HP185C1?psc=1&ref=ppx_yo2_dt_b_product_details
Adhesive heat shrink: https://www.amazon.com/dp/B084GDLSCK?psc=1&ref=ppx_yo2_dt_b_product_details
KNOBBronco, is there sufficient space to put the high idle know on the panel below where you installed? The space where the video installs is already occupied!
I don't see why there wouldn't be enough room in this area. It may be close though.Bronco, is there sufficient space to put the high idle know on the panel below where you installed? The space where the video installs is already occupied!
